Old 06-24-2006, 12:57 AM   #15301
SpeedTech's Avatar
Originally Posted by vtl1180ny
Who is carrying parts for the SSG/CGM these days online? I've delegated my CGM to parking lot duty and need a few little bits that aren't in my bag o parts.... Speedtech doesn't seem to carry much Yok stuff anymore...
Parts are coming in next Monday/Tuesday
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 06-25-2006, 01:23 AM   #15302
tom235's Avatar
i checked and double checkedno flashing and the gears on the shafts are seated. how many shims do you guys run on the input shafts
tom235 is offline   Reply With Quote
Old 06-25-2006, 02:44 AM   #15303
sosidge's Avatar
Enough shims for the input shaft to spin freely without play.
Old 06-25-2006, 07:30 AM   #15304
Whats the final gear ratio for a Yokomo SD?
7 celler is offline   Reply With Quote
Old 06-25-2006, 07:45 AM   #15305
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Thanks Steve....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 06-25-2006, 09:37 AM   #15306
The Transmission Ratio is 2.353 go to www.gearchart.com and you can find the final drive ratio of any combination of pinion and spur gear.
pops is offline   Reply With Quote
Old 06-25-2006, 12:13 PM   #15307
tom235's Avatar
i will recheck the shims
Old 06-25-2006, 12:43 PM   #15308
Sometimes a little nick in the ring gear or drive gear can cause the same problem check both ends of the car for that.
Old 06-25-2006, 10:12 PM   #15309
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
SD CGM/SSG has the same final drive ratio as the LCG? just wanted to confirm.
thanks!
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 06-25-2006, 10:31 PM   #15310
Revox's Avatar
Send a message via MSN to Revox
Hey guys, I just bought a MR4TC-SD a week or two ago and was wonderin if anyone drifts with it? And if anyone know of some drift settings for it? Thanks.
Revox is offline   Reply With Quote
Old 06-25-2006, 11:07 PM   #15311
Tek Nickal's Avatar
Tom, also try shimming the diff itself, by putting shims before the bearing. That worked for me, and now I have a super free drivetrain. I also recently replaced the front bevel gear.
Tek Nickal is offline   Reply With Quote
Old 06-26-2006, 06:08 PM   #15312
tom235's Avatar
i will try that i thought they felt good but maybe im wrong hope so thanks for the help you guys rock
Old 06-26-2006, 07:06 PM   #15313
Thumbs up SPOOL IN LCG
Just sharing this with others. I fitted the Yokomo plastic spool to the LCG and ran it last night. The car was easier to drive with spool than the one way. I am running a CO27 stock motor and using 4200 batteries and the car has great acceleration.
The only hitch for the night was the CVD pin moved after a hard contact and bound up the front left wheel. I am going to remove the drill blank and put a notch half way along the pin, so that the grubscrew locates into this. A tip I read in XRC Cars.
I will be sticking with the spool,as it provides great pickup out of the corners. With the spool fitted you have to change other settings on your car. Even though the left front bound up, the spool did not get chewed up.
Thanks to Pops for the advice and assistance with setup.
Cheers
Calvin.
caltech1 is offline   Reply With Quote
Old 06-26-2006, 07:42 PM   #15314
can the kawada spurgear fits in my LCG and BD?
skamolly is offline   Reply With Quote
Old 06-26-2006, 07:49 PM   #15315
ernestf's Avatar
Send a message via ICQ to ernestf
thanks!
I have both SD CGM and SSG, the internal gear ratio are the same from stock kit.
ernestf is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
