Yokomo MR-4TC SD >
Yokomo MR-4TC SD
Like Tree12Likes
Yokomo MR-4TC SD
Old 06-09-2006, 09:35 AM
  #15256
sosidge's Avatar
I've said it many times before in this thread, and I'll say it again - it only breaks if you crash!
Over three years of ownership I doubt I have had more than half-a-dozen races spoiled by crash damage.
Many of the parts that were supposedly fragile have been updated anyway, the newer c-hubs have more material, the G (grpahite) parts seem a little more durable and less sloppy, there are also heavy duty wishbones.
Other than a few steering knuckles, C-hubs and wishbones I think the only parts I've broken have been a diff screw, bumper mount and a few slightly bent hinge pins.
sosidge is offline
Old 06-09-2006, 09:44 AM
  #15257
b-man777's Avatar
Default team
hi allther than masami hirosaka and now billy easton why doesn't yokomo have as big a factory driver presence at both on and offroad electric races outside of japan as many other companies do.also why haven't they gotten more factory drives in the usa?yes they show up at ifmar worlds events,but thats about it.just a thought any info would be great thanks
b-man777 is offline
Old 06-13-2006, 12:08 PM
  #15258
olhipster1's Avatar
Trader Rating: 102 (100%+)
Default LCG ???
Hi guys,
Just wanted to see if there is a way to stiffen up the LCG the top deck in specific. LCG is a great car but just flexes a bit too much at times.
I do have the optional steering posts installed ..that helped a bit..but it seems most of the flex occurs at the motor mount, the double deck doesn't help it..
any help/infor would be appreciated.
Thanks all.
OL>
olhipster1 is offline
Old 06-13-2006, 01:02 PM
  #15259
Originally Posted by olhipster1
Hi guys,
Thanks all.
OL>
Here is a picture of Dave Goss' LCG. He used shock towers to stiffen the chassis.
pops is offline
Old 06-13-2006, 01:10 PM
  #15260
MrUnlimited's Avatar
Looks good but wouldn't make siderails like the Baracuda Stinger stiffer?
Also anyone has a good setup for slippery asphalt? Tyres/inserts, ride height droop?
MrUnlimited is offline
Old 06-13-2006, 01:11 PM
  #15261
Wow, that was creative. Does anyone make a stiffer upper deck?
DOTMAN is offline
Old 06-13-2006, 04:25 PM
  #15262
olhipster1's Avatar
Default creative
that's quite creative...
I had a friend make a thicker top deck, only the front section...but it still had flex..
has anyone tried to link the both top sections together..and possibly use the SDW motor mount to lift up slightly.
Old 06-13-2006, 05:19 PM
  #15263
Dave's LCG is very stiff.
pops is offline
Old 06-13-2006, 05:41 PM
  #15264
I'm sure it is, but that looks like it took a little work. Plus, I don't want it too be REAL stiff, just stiffer. Right now, my car feels like rubber when I flex it.
DOTMAN is offline
Old 06-13-2006, 05:58 PM
  #15265
I think by removing some of the posts it becomes more flexible.
pops is offline
Old 06-13-2006, 06:01 PM
  #15266
Gotcha
DOTMAN is offline
Old 06-13-2006, 06:07 PM
  #15267
Oasis's Avatar
Trader Rating: 38 (100%+)
If you want it stiffer you can "modify" a Rayspeed top deck. It's 2.5 so it's a little stiffer. I have noticed that the LCG does flex..a lot. I don't think it would be an advantage on a high bite track ( ) I have noticed that all the LCG parts will fit right on a Rayspeed chassis. The only modifying you would have to do is drill a few holes for the steering or you could use the Rayspeed steering..I don't really see an advantage in using the LCG steering over the Rayspeed..Oh you do need to modify the battery slots if you want to use 3800 or larger batteries.
Oasis is offline
Old 06-13-2006, 07:31 PM
  #15268
Oasis's Avatar
I don't think David had a good weekend, Has he been racing much lately? I'm used to seeing him place in the A at Speedworld..
Oasis is offline
Old 06-13-2006, 07:57 PM
  #15269
Dave said his car was great, but he felt that he was not.
pops is offline
Old 06-13-2006, 08:24 PM
  #15270
olhipster1's Avatar
Default hey
