Old 05-20-2006, 11:06 PM   #15211
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Lightweight chassis & blue motor mount
v0rtex is offline   Reply With Quote
Old 05-20-2006, 11:11 PM   #15212
And Rayspeed shock towers.
caveman is offline   Reply With Quote
Old 05-20-2006, 11:50 PM   #15213
Send a message via MSN to ickvanovs
thx for the info guys
ickvanovs is offline   Reply With Quote
Old 05-21-2006, 01:17 AM   #15214
lem2's Avatar
I have rayspeed shock towers!!!
lem2 is offline   Reply With Quote
Old 05-21-2006, 01:51 AM   #15215
is it good?
Old 05-21-2006, 03:35 AM   #15216
and blue alloy split suspension mounts. and maybe a front spool?
agower is offline   Reply With Quote
Old 05-21-2006, 04:41 AM   #15217
LCG STEERING QUESTION
G'day All,
Ran my LCG today and noticed that I have more steering throw one side than the other. When I check the steering rack itself I notice that the centre ball cup on the steering rack binds on the post on the right front,(looking from the front of the car) whereas the left does not bind. I had adjusted on the EPA, however this placed to much stress on the servo. The steering rack is the standard one that came with the conversion kit. I think that the steering rack with 1.5 degree ackerman will do the same.
I am wondering if I move the steering servo saver over more will this fix the problem, I believe it is over more than the one spline to the right.
See attached photo's, any assistance appreciated. As seen in first photo the steering rack is central and car tracks straight. Minimal servo trim being used. Second photo shows central steering rack binding on post and still missing full steering throw.
Pops,
Running the 2 degree rear toe sure gave the car more steering and felt alot more stable on the track. Just need to fix the steering throw and it will be on the money.
Cheers
Calvin.
caltech1 is offline   Reply With Quote
Old 05-21-2006, 09:23 AM   #15218
when i had my lcg i noticed the same problem, there was no way of sorting it out apart from filing the belcrank down so it didnt touch, you cut abit off the end of the balljoint but then you risk it popping off
Old 05-21-2006, 11:09 AM   #15219
Oasis's Avatar
Trader Rating: 36 (100%+)
Originally Posted by caltech1
G'day All,
Pops,
Running the 2 degree rear toe sure gave the car more steering and felt a lot more stable on the track. Just need to fix the steering throw and it will be on the money.
Cheers
Calvin.
I checked mine and it does not hit. I don't run my car with the steering lock to lock either. Something that i did notice years ago was when I had run my steering lock to lock I actually had less steering than if i dialled some out. Lock to lock will introduce "push" because your tires are at such an extreme angle they will not have a good contact patch so your rear tires overpower the front..push. On top of that to much steering throw will also scrub off a lot of corner speed.
Oasis is offline   Reply With Quote
Old 05-21-2006, 12:16 PM   #15220
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
pardon the noob question... but wants the max size i can run the spur gear on an LCG?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 05-21-2006, 02:25 PM   #15221
Oasis's Avatar
I'm running a 98(64 pitch)It seems to be a good size as far as the ratio's go. I would think that you would run into a clearance problem with anything larger than a 102..This is 64 pitch. When I was running 48 pitch gears I was using a 78 and I don't think you could any larger than an 82 without clearance problems.
Old 05-22-2006, 05:28 PM   #15222
tom235's Avatar
this may sound like a domb question but do you need that triangle limiter in the shocks or can i run with out them.
tom235 is offline   Reply With Quote
Old 05-22-2006, 06:06 PM   #15223
I think that triangle piece adds support to the shock shaft. I wouldn't remove it...but that's just me
DOTMAN is offline   Reply With Quote
Old 05-22-2006, 06:35 PM   #15224
Yes you need it, it keeps the shock shaft centered in the shock. Tip, cut off 50% of the little tube and then install them upside down in the shock.
pops is offline   Reply With Quote
Old 05-22-2006, 06:41 PM   #15225
tom235's Avatar
thanks pops & Dotman you guys are great. .
pops why do you put them upside down
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
