Old 05-17-2006, 08:35 PM   #15196
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
whoops now im giving away secrets
naa i doubt it makes much difference really. It was something someone told me for 540 off-road racing where all the extra power you can get is a help I've never noticed a problem doing it on my on-road cars so i just kept doing it when I built the diffs for them too.
v0rtex is offline   Reply With Quote
Old 05-19-2006, 05:55 PM   #15197
tom235's Avatar
ok the rear diff was melted down that explaned alot
then i broke a ball end but the person replaced all the ball cups with rpm so i dont have any ball studs to fit doe anyone have who make a 3mm ball stud that fits a rpm cup
tom235 is offline   Reply With Quote
Old 05-19-2006, 07:19 PM   #15198
team green's Avatar
Has anyone tried the new center one-way shaft yet ? Part# SD-644TS. If it does'nt rain here Sunday I will test it out on my 540 spec car. I'm hoping for more corner speed being it is a spec class car.
team green is offline   Reply With Quote
Old 05-19-2006, 08:06 PM   #15199
The RPM ball cups will fit the yokomo ball studs. They are a little tight going on put work fine. They won't come loose as quickly as the Yokomo ones. You can just replace the ball cups with new Yokomo ones and the fit is still good. I just received the new Yokomo BX ballcups and ball studs and will be installing them this weekend. They are supposed to be an improvement.
pops is offline   Reply With Quote
Old 05-19-2006, 08:33 PM   #15200
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
guys, was wondering which shock to upgrade from my current stock. can anyone help? my using drift package
uniquexme is offline   Reply With Quote
Old 05-19-2006, 09:04 PM   #15201
Trader Rating: 17 (100%+)
hi every body, i have a mr4tc sd black special roller for sale at sale forum
http://www.rctech.net/forum/showthread.php?t=114266
EngTat
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 05-19-2006, 10:09 PM   #15202
tom235's Avatar
thanks pops for all your help
Old 05-19-2006, 11:32 PM   #15203
Oasis's Avatar
Trader Rating: 36 (100%+)
Quick question..What shocks should i be using for my LCG? The reason why i ask is I'm converting my Rayspeed over to an LCG. The Rayspeed uses the Longer shock end. How long is the shock suppose to be?
Oasis is offline   Reply With Quote
Old 05-19-2006, 11:44 PM   #15204
Thumbs up LCG SHOCKS
XXXKAT,
I run the yokomo shocks with short shock end. Onto this I use the Rayspeed spring retainers and use Rayspeed springs. I have all four of my shocks measured at 61mm. This total length when fully uncompressed. I am running white springs at the front and green at rear. I have a stock motor fitted at present and 2 degree rear toe out.
Pops,
Thank you for the BD stuff will give it a try next time I race.
Hope this helps.
Calvin.
caltech1 is offline   Reply With Quote
Old 05-20-2006, 01:09 AM   #15205
You want the shocks to be long enough to fully extend so you can add the proper amount of droop from where you mount the shock on the tower. It is a good idea to have the piston positioned somewhere near the middle of the shock body when the car is at rest. I think it was covered earlier in this or the BD thread to cut the little hat that goes in the bottom of the shock and position it upside down. This allows more shock fluid to be under the piston.
Old 05-20-2006, 01:10 AM   #15206
no problem, hope it helps.
Old 05-20-2006, 01:11 AM   #15207
Originally Posted by caltech1
XXXKAT,
Pops,
Hope this helps.
Calvin.
Good luck!
Old 05-20-2006, 10:43 PM   #15208
Send a message via MSN to ickvanovs
hey guys, i finally pickup my cgm kit
actually its not a brand new kit, the owner built a kit from his spares
he told me that the kit included few optional parts
i just wondering, can you guys tell me what kind of optional parts do i get from this kit? (plz check the pics)
ickvanovs is offline   Reply With Quote
Old 05-20-2006, 10:44 PM   #15209
blue motor mount
Tamiya TB Evo 5
Old 05-20-2006, 10:47 PM   #15210
two more pics
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
