Old 05-07-2006, 04:00 PM   #15166
I run my SSG with 86/34 using an Orion 23-turn. Speed and acceleration seems fine but after the run, the motor's too hot to touch, running on asphalt, so probably I have to use a 32 or 30 pinion.
macgyver1432000 is offline   Reply With Quote
Old 05-07-2006, 05:55 PM   #15167
tom235's Avatar
since i dont have many 64 pitch pinion maybe i will go down on the spur
thanks guys
tom235 is offline   Reply With Quote
Old 05-10-2006, 01:17 PM   #15168
Tsquare's Avatar
Has anyone ever run the Yokomo CGM with the "shorter" front control arms from the Yokomo Worlds Edition car? If you have, how was the steering? "Pops" if your out there any input would be greatly appreciated.
Tsquare is offline   Reply With Quote
Old 05-10-2006, 06:24 PM   #15169
No haven't run it on the CGM, but it did help with more steering on the BD.
pops is offline   Reply With Quote
Old 05-10-2006, 08:03 PM   #15170
Tsquare's Avatar
Thanks for the Input Pops, I'm going to give it a try with my CGM, i'll let you know how it turns out.
Old 05-10-2006, 11:29 PM   #15171
tom235's Avatar
what body do most people like to run on there yok
Old 05-11-2006, 10:06 AM   #15172
Tsquare's Avatar
What type of racing do you do?
Old 05-11-2006, 10:34 AM   #15173
I think Dodge Stratus or Mazda 6 is best for the SD...any other suggestions?
Old 05-11-2006, 10:58 AM   #15174
Send a message via MSN to ickvanovs
does body make huge difference?
ickvanovs is offline   Reply With Quote
Old 05-11-2006, 11:25 AM   #15175
sosidge's Avatar
Yokomo Euro Truck vs Protoform Mazda 6 = big difference
Protoform Mazda 6 vs Protoform Stratus 3 = small difference, but a difference nonetheless.
Old 05-11-2006, 03:54 PM   #15176
Tsquare's Avatar
It can, depending on the bodys and the track. I have found for my driving the body can make a material difference in my lap times. I usually run the 190MM Protoform Mazda 6. I have not run the Stratus 3.0.
Old 05-11-2006, 10:16 PM   #15177
Aries326's Avatar
Trader Rating: 19 (100%+)
Anyone here have links to some setups for the Yokomo Rayspeed? Syracuse, NY is finally getting a carpet track at Walt's Hobbys. Yay!!!! I can't wait to do some TC racing. I picked up my Rayspeed a few months ago thinking I was going to drive an hour to the TeamCRC track then gas went through the roof. Now I've got a chance to race it!
Anyway, does anyone here have some complete SSG rollers or SSG pieces they want to get rid of? LMK. I'm looking for some friends of mine. Thanks.
Point1Drift
http://www.driftercentral.com
Aries326 is offline   Reply With Quote
Old 05-11-2006, 10:22 PM   #15178
Aries326's Avatar
Originally Posted by caltech1
Well I have just finished rebuilding my LCG from the ground up. I covered the bottom of the CF chassis with some 3M clear adhesive. This adhesive should protect the CF from scratching as it is about 1mm thick. While I was at it, I rebuilt the rear diff with carbide bearings and placed the bevel gear covers SD-302LDC to both front and rear. I have also fitted Rayspeed springs and retainers to the car. I also added SD-202LPL to the front steering rack. I will be trying the car out in the next few days.
Has anyone been able to translate the LCG setup sheets used by the factory drivers for Yatabe Arena? From what I can make out they using the SD A-arms (possibly CGM graphite), front and rear. They are also using the Tamiya TRF pistons in the Yok shocks as well, I believe. Can anyone advise further as would like to try this setup or something similar.
Will try and add some photo's.
Cheers
Calvin.
Where'd you get your 3M clear adhesive from? I'd like to protect the bottom of my chassis too since I'll be racing soon.
Point1Drift
Old 05-11-2006, 11:57 PM   #15179
Cool 3M CLEAR ADHESIVE
ARIES 326
I purchased the 3M Clear adhesive from a motorcycle accessories shop, here in Australia. The sheet is big enough to do two chassis's and costs about $20 Aust. It can also be purchased in colours for the matching Bling Bling. Colours are Pink, Blue, etc.
Vortex,
See you got your LCG. Once I have some time will send you a copy of my latest LCG setup for asphelt netball court. Track is tight. My setup is for running STK.
Cheers
Calvin.
caltech1 is offline   Reply With Quote
Old 05-12-2006, 04:10 AM   #15180
Aries326,
Try to look at www.yokomousa.com , then try click "set-up" subtab. There are set-up sheets used my M.Hirosaka at the Yatabe Arena using his SSG. There are some oether set-ups, too.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
