Old 04-30-2006, 11:54 AM   #15106
Tsquare's Avatar
Originally Posted by rc_bam226
There are mixed opinions on this one, its an aluminum drive shaft, IMHO you are better off using the steel drives up front and the aluminum ones in the rear. For durability sake.
I agree with Bam, especially for Yokomo CVD's. I always run steel in the front, in the rear I will run aluminum or titanium.
Tsquare is offline   Reply With Quote
Old 04-30-2006, 03:12 PM   #15107
Thought I would let you guys know about a parts sale at Yokomo USA. Buy $100 get 10% off, $200 get 20% off and $300 get 30% off. That's a pretty good deal.
pops is offline   Reply With Quote
Old 04-30-2006, 05:21 PM   #15108
Racingbod85's Avatar
Originally Posted by tom235
is anyone running the graphite ring and pinion
yup no worries wiv them so far!
RC12L4
Novak 4.5R / 10.5R
Sanwa/Futaba/Much More
Carpetwars/Sidcup RCC/Maritime Racing/7oaksmcc
Racingbod85 is offline   Reply With Quote
Old 04-30-2006, 07:25 PM   #15109
Aries326's Avatar
Trader Rating: 19 (100%+)
Originally Posted by macgyver1432000
Can I also convert my SSG to Drift version? What part should I replace aside from the tires? I'm using an Orion 23-turn motor..What's the ideal motor for drifting?
The Stage 3 upgrade for the Yokomo DP is in fact the SSG chassis. Since you already have the SSG chassis, you're in business! Just put some ABS tires on, set the camber to 0 all around, no toe in front, 3 degrees toe-in read, try using Yokomo black springs in front and blue or white in the rear. Tighten up your diffs with the rear being tighter than the front. That motor will do you fine. I used to drift with a P2K2Pro which was more than enough. I switched to brushless only 'cause I couldn't pass up on a good deal and I didn't want to mess with anymore motor maintenance.
Point1Drift
http://www.driftercentral.com
Aries326 is offline   Reply With Quote
Old 04-30-2006, 08:38 PM   #15110
But Aries326, having a one-way diff would be suitable for drifting? Or do I have to change the one-way diff to ball diff in front?
macgyver1432000 is offline   Reply With Quote
Old 05-01-2006, 03:21 PM   #15111
tom235's Avatar
do they make less noise than the plastic
tom235 is offline   Reply With Quote
Old 05-01-2006, 04:27 PM   #15112
Tsquare's Avatar
I Have run them for quite a while. No problems to report.
Old 05-02-2006, 04:56 AM   #15113
honestly couldn't tell the difference!!bought them cos i was bord and it said "graphite"
RC12L4
Novak 4.5R / 10.5R
Old 05-02-2006, 07:34 AM   #15114
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
graphite in our industry typically refers to a carbon impregnated plastic. isn't carbon highly abrasive? i have stayed away from these for that reason. the standard gears seem to be working fine. perhaps we will do a comparison. and i would also guess that the standard gears are quieter if they are indeed softer.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-02-2006, 09:00 AM   #15115
chicky03's Avatar
Send a message via AIM to chicky03
Does anyone know if Tommy Kramer attended the LRP Masters or were any of the Tommy Kramer edition car's run there?
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 05-02-2006, 10:02 AM   #15116
Tsquare's Avatar
I do not notice any difference in the noise between the plastic and the graphite gears. The car feels to run free'er with the graphite, are probable a little truer and seem to have more durability.
Old 05-02-2006, 10:58 AM   #15117
tom235's Avatar
thanks guy now to pick your brain some more i am looking for a base set-up
im finding alot of drift set-ups but not alot of regular racing set-ups if you could help me that would be awesome
Old 05-02-2006, 11:02 AM   #15118
Tsquare's Avatar
What car are you running? and What service do you run on?
Old 05-02-2006, 11:06 AM   #15119
tom235's Avatar
my bad i run mr4tc sd ssg i run on asphalt med grip semi smooth 100 to 110 straits pretty tight infield and i run 19t (quad mag or a element )
Old 05-02-2006, 11:57 AM   #15120
Tsquare's Avatar
Try these four sites, should give you plenty to work with. Good luck.
http://www.yokomo.tk/
http://www.gearchart.com/index.cfm?f...n=home.default http://www.yokomousa.com/ http://www.cmldistribution.co.uk/tea....php?menu=TEAM
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
