Old 02-20-2006, 06:58 AM   #14986
Moz023's Avatar
Trader Rating: 22 (100%+)
Default hi
thanks for the set up info about gearing i use 75 spur and 20 pinion and the motor gets real hot is there any way to get more speed with out loosing punch like a compromise between high speed and fast aceleration ??
Guess who's back.... Back again
Moz is back to hack again
Moz023 is offline   Reply With Quote
Old 02-20-2006, 07:04 AM   #14987
Hi,
if I'm correct that should be a final drive ratio of 8.82. What motor are you using?
Gear the motor so it reached the top speed after 2/3 of the straight.
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 02-20-2006, 07:13 AM   #14988
Moz023's Avatar
Default hi
i am using team brood stock/ trininty monster stock the straight at the track is like a u shape but first part about 25 metres then left turn 90 degrees then 30 meteres 90 degree left turn the 5 meters left 180 degree turn the mods just get to top speed down the longest section they have to back off on the first turn with stock you can mostly drive through the turn in you are alone in traffic you have to back off
looks like this
Old 02-20-2006, 07:16 AM   #14989
Hi,
for the gearing of this motors you have to ask someone other. In Germany the stock guys are using GM motors with a gearing around 5.0.
Cheers
Chris
Old 02-23-2006, 07:12 AM   #14990
TheRo0sTer's Avatar
Send a message via AIM to TheRo0sTer
Man I tell you guys I love this car! (LCG) But I hate racing electric cars! Most the tracks in our area are small so MOD is out of the question. If you were to sell your NEW LCG with maybe 5 race days on carpet what would you ask for a roller?
TheRo0sTer is offline   Reply With Quote
Old 02-23-2006, 07:37 AM   #14991
hurley081182's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to hurley081182 Send a message via Yahoo to hurley081182
how does everyone cut down the rpm ballcups and what part for the dremel do you use. i tried to cut it and the ballcups was not cut even. any ideas or help would be great.
Old School Stampede=FUN
hurley081182 is offline   Reply With Quote
Old 02-23-2006, 08:12 AM   #14992
MrUnlimited's Avatar
I use a X-Actoknife instead and a digital caliper to measure the length.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 02-23-2006, 08:14 AM   #14993
Why don't you switch to stockmotors? Selling your car so quickly is a wast of money!
Old 02-23-2006, 10:48 AM   #14994
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Arrow one way for sale
http://www.rctech.net/forum/showthread.php?t=102852
has not been used.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 02-23-2006, 11:19 AM   #14995
TheRo0sTer's Avatar
We run stock and well that is BORING! I a nitro kind of guy. There is more to my reasons for selling. One of the faster guys is leaving the State and well it would be even more boring taking turns with another driver. Basically the fun of racing would be going away.
Old 03-09-2006, 07:48 PM   #14996
i was wondering if anyone that had a cgm here would help me with something. i put some 28mm foams on my cgm and they are rubbing against the hub carrier. any suggestions/help would be great
Old 03-09-2006, 07:58 PM   #14997
seaball's Avatar
if you are running jacos, you'll need a .75mm spacer. parma tires will fit w/o a spacer as they are offset about that much more.
- ruben sanchez -
Old 03-09-2006, 08:24 PM   #14998
they are actually trc foams. by spacer what do you use?
Old 03-09-2006, 09:08 PM   #14999
You can use Tamiya spacers they come in assorted sizes. Or you can shave off 1mm using a hobby knife on your tire truer. Spacers would be the way to go.
pops is offline   Reply With Quote
Old 03-16-2006, 05:38 PM   #15000
aN4rK1's Avatar
any1 have any team suzuki parts? I am in desperate need of a TS-2102 the aluminum Upper Deck mount.
aN4rK1 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
