Old 05-23-2003, 11:17 PM   #1486
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Has anyone run the square titanium axles yet, how durable are they actually?
Old 05-24-2003, 01:57 AM   #1487
sosidge's Avatar
Originally posted by tones
droop at one end of the car affects weight transfer to the other.
so for more rear traction out of a corner, you'd want more front droop, not rear.
what's the setup you have on the car atm?
Setup is all over the place, I'm trying so many different things, so I was looking for someone elses starting point for me to work from.
I've found someone else with the same problem - he changed from a Monster to an Orion stock and solved it - perhaps too much power in an extra-free transmission has been the problem? We'll see...
Old 05-24-2003, 09:37 AM   #1488
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Thanks for the spur gear info!
Any thoughts on what CVD's work on the SD? Want to build this thing up right...going to be a great kit.
Jeff
Jeff Werner is offline   Reply With Quote
Old 05-24-2003, 09:43 AM   #1489
The MR-4TC CVD kits should work on our car, at least that's what everyone has told me so far.
Old 05-24-2003, 09:45 AM   #1490
utieh's Avatar
Default CVD
you can use the MR4TC rear CVD at all four corners on the SD .
ref is 1470 for normal, 1472 for shiny, 1339 for aluminium
utieh is offline   Reply With Quote
Old 05-24-2003, 10:39 AM   #1491
Trader Rating: 47 (100%+)
darkseid I am planning on purchasing an SD here in the near future, so hopfully I can help you out a little at mikes. I was kind of in the same boat as Jeff, and after going to the invite race and chatting with Tosollini, and wathcing his car perform I am sold.
porter is offline   Reply With Quote
Old 05-24-2003, 11:12 AM   #1492
porter- man your car looked great in tulsa. Good to meet and race with you. We will have to come up and race with you guys this summer...esp if we are both running yokomo's...
utieh- thanks for the info...will order mine today!
Jeff
Old 05-24-2003, 11:34 AM   #1493
VenomRcR's Avatar
Send a message via Yahoo to VenomRcR
Cool RE:CVD
Thanks Utieh for posting the cvd info I appreciate it. I was going to measure cvd's at the hobby shop
My car is down for a bit to an unfortunate board hit where the front right cvd sheared and the oneway drive cup magically disappeared on me. I've been watching Speedtech and other stores but apparently the wait for that little part will be awhile. Sooo I'm about to break down and order from Japan.
Big kudo's and thanks to all of you guys for posting such great info on here!!! Now I think I'll go back to my lurking whilst I longingly stare at my SD and dream of racing it this weekend...
VenomRcR is offline   Reply With Quote
Old 05-24-2003, 11:42 AM   #1494
utieh's Avatar
I broke a right front CVD too...
i've just odered Tobee alloy shaft since MIP's were a little bit too pricey for me
Old 05-24-2003, 12:10 PM   #1495
Regional Moderator
Darkseid's Avatar
Porter: Well, I got the car running well now. My biggest problem was with my stock motors. Since I wasn't planning on running stock there this year, I didn't bother to take care of them. But since the guys seem to be dragging their feet on the 19turn thing, I just got mine rebuilt so they should be performing much better. Even with the motor weaknesses, my last two races out at Mike's with the car have been nearly flawless and fast.
Jeff: heres what I have been running at Mikes. I'll just list the things I changed from the kit set up.
-Front end-
-Shocks: 70wt oil, stock piston, long shock ends, 64mm length
-lower shock position: one hole out from stock
-droop: 6mm
-ride height: 5mm
-Rear end-
-Shocks: 70wt oil, Yok no. 1 piston, 61mm length
-lower shock position: one hole in from stock
-droop: 5mm
-ride height: 5mm
Remember, this is only stuff that I changed. Anything you don't see here is stuff I left as stock. Also, this is the dual diff setup. Once the one-ways become availible, I will try it out and see what set up I will run.
-other stuff of note
-motor: Peak Hellfire
-gearing: 70t spur/22t pinion=final:7.48
-Tires: Take-Offs C22 (it was pretty cool outside)-No additive-
-Speedcontrol: GT7
-Body: Protoform Altima
Hope this helps when its time for you to pay us a visit out at Mikes.
TLR 22...Tamiya F104...
Old 05-24-2003, 01:12 PM   #1496
forty6's Avatar
Default Re: CVD
So four rear CVDs Dang, that will be around $55 for a shiny or alu set.
forty6 is offline   Reply With Quote
Old 05-24-2003, 03:59 PM   #1497
I believe Sheldons Hobbies has them for $25 a set, not bad at all...
Old 05-24-2003, 04:11 PM   #1498
forty6's Avatar
I don't believe they sell a set of 4 rears, do they? All I've seen is pair for $26, so front and rear is about $52 + tax.
Old 05-24-2003, 06:43 PM   #1499
Sorry, meant $25 a pair, still pretty cheap for CVD's...
Old 05-24-2003, 07:58 PM   #1500
sounds good Jeff, I don't know about my car looking good in tulsa, it had its good and bad moments I guess. I'm just ready for somthing a little different, been running the tc3 for almost 3 years now
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
