ORION ELEMENT/PEAK DYNASTY IN FOAM SEDAN >
Old 12-20-2006, 08:11 PM
  #16
AdrianM's Avatar
Originally Posted by brian cox
adrian- the rollout i run in sedan with the kd2 is around 27mm-----do you think the peak will pull the 33.5mm roll out?
Actually 33.5mm is pretty conservative...it will pull bigger gears on larger tracks outdoors. I have run FDR's in the 5.4-6.00 range depending on track size.
About the brush hoods. There is nothing wrong with the Orion standard brush hoods other than they are too precise. Brushes can vary in size from production run to production run. The Trinity XXX's I have now fit really tight so I have to open the hoods a bit. The good thing is that this reduces brush cocking for more power.
On my Trinity motors I spend a lot of time tweaking my brush hoods to get them straight and to tighten them up on the brushes. You don't have to do that to Orion or Reedy motors.
AdrianM is offline
Old 12-20-2006, 08:13 PM
  #17
Likely to be what the issue was. Thanks for clearing it up Adrian.
v0rtex is offline
Old 12-20-2006, 08:20 PM
  #18
brian cox's Avatar
Trader Rating: 81 (100%+)
just to give you and idea of track size --avg lap 10.9-11.0 lots of 180's
brian cox is offline
Old 12-20-2006, 08:29 PM
  #19
AdrianM's Avatar
I would start out 4 teeth higher than with a Komodo and you will probably be a little under geared. At our carpet track the Komodo guys run a 31mm roll out.
AdrianM is offline
Old 12-20-2006, 08:31 PM
  #20
brian cox's Avatar
adrian--thanks for the help, i'll give it a try!
Old 12-20-2006, 09:11 PM
  #21
Trader Rating: 44 (100%+)
thanks for the info .. u learn something new each day
wyl03 is offline
Old 12-20-2006, 11:36 PM
  #22
speedxl's Avatar
EA Motorsports F-Brushes with Trinity Red springs and a roll out starting around 2.00" or 50mm... and no i am not kidding. It can pull that gear easily.
Hector (SpeedXL) Garcia won the 2005 FL State Series 19T 1/12 class with an Element 19T.
wyl03 - Any of Trinity's non overhead springs will fit (like on Trinity mod motors).
Also Peak and Orion are pretty much the same company. Like GMC and Chevy. The Peak Vantage 19 and Orion Element 19 are the same motor.
Something Adrian and I will agree on is these motors are silly fast geared right! The main thing you'll notice is the magnets dont drop off.
I won back to back state championships with them in 12 scale,. Alsotq'ed a few races and won a couple in sedan 19t with Peak dynasties with regular laydown bushes. xxx's and blk springs! .
speedxl is offline
