Old 11-13-2001, 05:33 AM   #1
zxt
zxt's Avatar
Default TRF chassis vs. FRP chassis
I already posted this at TA-03 thread but I cant wait to have my question answered.
Which chassis is better and why...
zxt is offline   Reply With Quote
Old 11-14-2001, 04:03 PM   #2
TFR
TFR's Avatar
TRF is carbon fiber chassis
and FRP is composite chassis i believe
That really depends on your application...Carbon chassie is stiff and FRP chassis has flex...
as for most ppl, they will go for Carbon fiber....
why??...i dont know....it looks better...
TFR is offline   Reply With Quote
Old 11-14-2001, 07:05 PM   #3
zxt
zxt's Avatar
Default Hey TFR!
I noticed that we have both Z's as our Avatar...but almost 2 decades apart. Do u like Z's too? Do u have one?
Back to the topic...so TRF is more expensive? Because its carbon fiber? But FRP doesnt have as much flex as the tub right?
Old 11-14-2001, 08:16 PM   #4
TRF-Powered's Avatar
TRF stands for Tamiya Racing Factory. It does not nessarily mean it's Carbon- Chassis. But it usually is. For example, the F103LM TRF consists of Carbon-fiber chassis plate and a FRP motor plate.
FRP stands for Fiber-Reinforced Polymeric/Plastic material.
FRP material is pretty strong, I do not believe it has more flex than a tub chassis if the tub chassis is made by plastic only.
TRF-Powered is offline   Reply With Quote
Old 11-14-2001, 08:19 PM   #5
TFR
TFR's Avatar
the new Z is NICE>...
um....FRP chassis should have more flex than the Tub chassis...
What are you working on?
some project??
or just want to clear something out??
Old 11-14-2001, 09:31 PM   #6
zxt
zxt's Avatar
Default okay who's telling the truth here?
FRP has more flex or not?
I'm not working on any project...I just want to know the diff bet the two...I'm thinking of getting another TA-03...and I wonder which is the better chssis and why...
If the FRP has more flex than the tub then why will ppl get the FRP? Dont you think the tub has more flex already?
TFR: You didnt answer my question...do u have a Z?
Old 11-14-2001, 09:43 PM   #7
TFR
TFR's Avatar
I think you should go for a graphite chassis on a TA03...
FRP chassis is good on a Tamiya F1 car with flex....
I mean FRP is ok on the TA03 too since you got a upper deck to balance it out...
And to answer your question...nope...dont got a Z...
Old 11-14-2001, 09:53 PM   #8
zxt
zxt's Avatar
Default K thanks
because someone is selling his TA-03F for 2,500 pesos...around $49 with lots of aluminum hop ups and includes an FRP chassis
Old 11-14-2001, 10:02 PM   #9
TFR
TFR's Avatar
wow.....at $49....
killer deal man...go for it....
Old 11-14-2001, 10:20 PM   #10
FRP material does not provide more flex. FRP means FIBER-REINFORCED Ploymer/Plastic. Which is much stronger than regurlar plastic. So of course it's stiffer than regular plastic.
if you are interested in different materials, search on the web. it will tell you who is telling the truth.
Old 11-14-2001, 10:40 PM   #11
zxt
zxt's Avatar
Default Great deal?
Heres the list of the hop up parts
TAO3F with HPI Lancer Evolution VI body with full ball bearings,
*tamiya aluminum hub carrier,
*tamiya aluminum rear upright,
*tamiya aluminum steering arms,
*front and rear upper turnbuckles,
*FRPchassis
*flourescent sway bars,
*tuned shock springs,
new tires
and all extras from the kit
He starts at $78 then $60 now its only $49 and I still plan to bargain it at $45...
Also he's selling Micro RS4 for $87 with one servo, now its down to 68. Maybe I'll get both for $107...
TRF Powered: Thanks...
I'll give him a call now and lets see if he'll agree on th e$107 deal...
Okay...Does RS4 a good kit? I know its better than mini-z but in terms of fun and value...does it worth it?
Old 11-15-2001, 06:43 AM   #12
zxt: I prefer the rs4 sport for racing instead of the tamiya ta03.
All: With all the talk about tub, FRP and graphite having more or less flex, I would like to know how do you guys determine if the tub, FRP and graphite has how much flex? Is it measurable? Only when we can get some actual measured data we can make a conclusion decision. After that, we'll have to determine if flex is good or not. Anyone?
Ivan is offline   Reply With Quote
Old 11-15-2001, 07:42 AM   #13
zxt
zxt's Avatar
Default my bad
I meant Micro RS4 not Sport...
I have a Sport myself...
About the flex maybe they measures it how stiff and hard it is...the harder and stiffer the less flex...
I wonder where did Porky went? Been 8 days now...
Old 11-15-2001, 11:39 AM   #14
The way to determine if a chassis has more flex or not, is to look at the material it's made of, also the structure of the chassis itself.
It's hard to say which one has more/less flex by just looking at it since FRP chassis is usally a flat chassis, and tub chassis, you know, like a tub. Structure wise, Tub might provide less flex. However comparing the material of the chassis, the difference is very obvious.
FRP = Fiber Reinforced Ploymer/Plastic which is much stronger than Plastic. There are many different ways to make the FRP chassis, for example, the lay out of the fiber could be waven, or multi-stitiched, or cross weft, or the combo of all, true multiaxial. Generally, they are all pretty strong, however, the more complex their molecular structure is, the harder/stiffer it is, since the there are less space inside it's own molecular structure for it to flex.
Generally, FRP material are about 6 to 10 times stronger than Aluminium, and 7 to 11 times stronger than steel, per GPa/g/cm^3, depend on it's structure.
Plastic is weaker than Aluminium and Steel. Even with it's Tub chasis design adventage, It is not stiffer than FRP material, consider that it's molecular structure is much weaker than FRP material.
Hope this helps.......
Old 11-15-2001, 02:22 PM   #15
TFR
TFR's Avatar
Ha, i think TRF powered answered all...
ESP Clodzilla IV Chassis for sale (Monster Truck Chassis) BloodClod R/C Items: For Sale/Trade 5 08-31-2013 08:48 PM
FS/trade TC3 Rolling chassis w/motor bodies and ESC w/extra chassis and extra's TC3guypgould R/C Items: For Sale/Trade 17 07-08-2007 02:00 PM
TAMIYA MSX fully loaded 3mm chassis, DJ pro module, full MS chassis Patriiick R/C Items: For Sale/Trade 0 12-19-2005 08:38 AM
Does the TC3 Graphite Chassis Kit come with droop screw adjustment arms and chassis? ixlr8nz Electric On-Road 4 04-13-2003 10:34 PM
1/12 trinity switchblade rolling chassis for sale/trade for 1/10 touring chassis largabaynus R/C Items: For Sale/Trade 1 03-03-2002 01:58 PM
