Old 12-17-2006, 12:08 AM   #1
Default Question about Charging on ICE (FALSE PEAKS)
I just bought a matched 6 cell IB4200 pack, and I ran it about 3 times total prior to today...So today was my race day, I charge it up for the first heat and no problem, after the heat I discharge with my Reactor 20 and then let it cool a little and throw it on my ICE charger, and after about 4-5 mins ice said that it peaked...I restarted and about 5 minutes or so later it did it again, I looked at the graph on the ice screen and noticed that there were a TON of spikes on it...It false peaked about 5 times during the charge...After the second heat and preparing for the main I discharged the pack again and then put it back on the charger, got one false peak after about 5 mins and then it finished up ok...Do you guys have any idea what could be the problem here, I tried my ice on other batteries in between and they worked fine (graphs were smooth) PLease any help that you can provide would be greatly appretiated
jeffbhhs is offline   Reply With Quote
Old 12-17-2006, 04:47 AM   #2
hobbipro's Avatar
Trader Rating: 21 (100%+)
Did you try a higher delta peak? Maybe a cell is going bad. You can try to discharge the pack, then use a meter on each cell to see if there is a weak one. Are you sure all cells are being fully discharged?
hobbipro is offline   Reply With Quote
Old 12-17-2006, 05:15 AM   #3
NZ Xray Racer's Avatar
It is quite common for the ICE to misfunction
but if your other packs are charging fine then it must be something to do with your 4200s.
1 cell could be stuffed that screws all the rest and also the new intellects do not like to be discharged more than .9 v per cell other wise it stuffs them, have you gone more than this?
Xray XB808'10 | RB Concept Engines | KO Propo | Savox | VP Pro Tyres | Byron Fuels |
| THC- Taranaki Hard Core |
"Drive it like you stole it"
NZ Xray Racer is offline   Reply With Quote
Old 12-17-2006, 07:29 AM   #4
Kings Kid's Avatar
Trader Rating: 35 (100%+)
My two cents, I don't totally discharge my IB's between heats. I use the temp sensor and set my delta peak to top off at as close to 125 degrees as possible.(about 7mila amps) at the end of the nights use I discharge on my spintech battery manager. Never have had a false peak to date.Batteries are allways very stong for heats and the main
Kings Kid is offline   Reply With Quote
Old 12-17-2006, 09:41 AM   #5
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
don't forget there is a "peak lock-out" function on the ice...I think it defaults to 3 or 4 mins - but can be set to 10 minutes...
I didn't notice this feature the first couple of times i used my ICE - once I found it, I set it to the max for all my profiles
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 12-17-2006, 11:11 AM   #6
I didn't take the cells lower than .9, I used the integy reactor until the lights went then let it cool and then charged it...Hopefully a cell isent bad since I only used the pack 3 times...That would be terrible lol...I tried other stick pack 4200s on the charger in between charges of the matched cell and it did not false peak at all...Any idea? what I should do?
Old 12-17-2006, 11:42 AM   #7
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Maybe for you...
Turbo Joe is offline   Reply With Quote
Old 12-17-2006, 05:37 PM   #8
the integy indi isnt considered as an equalizing/discharger unit. You need a tray and use it before charging.
by the way the indi will put the voltage below .9v incase you dont know. i just use it for 2-3 mins. then continue the process on my equalizing tray.
skamolly is offline   Reply With Quote
Old 12-17-2006, 05:41 PM   #9
hobbipro's Avatar
I'd tray the pack, let it rest, then take a meter and read each cell. If one cell reads lower than all the rest you know its a bad cell. You can replace it with a new cell, but the pack wont be matched anymore. My bet is a bad cell from what you are describing.
Old 12-17-2006, 06:10 PM   #10
tc4
tc4's Avatar
I have used my ICE on many different types of batteries and it has never misfunctioned.
-Corally RDX PHI
-Johnson 540!
tc4 is offline   Reply With Quote
Old 12-17-2006, 06:20 PM   #11
jak43's Avatar
Trader Rating: 15 (100%+)
I had a buddy of mine's brand new Ice do that the other week. We did a couple of things to fix it. First he was running the tamiya plug with the aligator clips and the large aligator clips going to the power supply. I go rid of both of those. The problem was fixed. He does not tray his batteries before charging and I think that is where most of the problem is. The sloppy connectrions just amplified the problem some. He now trays them and has no problems. So check your connections and get a battery tray to take each cell to .9volts. I've had my Ice for a year and have never had a problem, but I do tray my batteries before charging.
Hope that helps.
John
jak43 is offline   Reply With Quote
Old 12-17-2006, 06:48 PM   #12
My problem is that the pack looks like this one http://www.horizonhobby.com/Products...rodId=SUM4200B
It has clear shrink rap covering the battery bars, do you guys think it would be alright to simply cut away the shrink rap? Thanks and please let me know what you think Jeff
Also do you think the Trinity DPD would do the job (the tray part) if I used that to get the cells down to .9 each(assuming if i cut the rap off the pack)? I am considering purchasing the DPD...
Old 12-17-2006, 09:58 PM   #13
What is a good tray out there to use?
Kevin
KevinL is offline   Reply With Quote
Old 12-17-2006, 11:06 PM   #14
flying G.E.O.'s Avatar
The indy is not good for discharging. It will bring other cells down below .9v even though it cuts off at 5.4v for the whole pack. Buy a cheap tray like novak smart or you'll ruin your cells. My ice rarely false peaked compared to my eagle cdc.
www.3dgallery.co.nr
flying G.E.O. is offline   Reply With Quote
Old 12-18-2006, 09:33 AM   #15
I think I am gonna buy the Trinity DPD, but for now would the ICE be any better to discharge at 10amps with? I mean would this be better than the indi reactor
True or False Handling Question? eds24 Electric Off-Road 1 07-04-2007 03:11 PM
Charging Question - help rcfordummies Malaysian R/C Racers 74 01-03-2007 07:31 AM
charging question Chris08527 Electric On-Road 15 10-22-2005 02:11 PM
got charging question cyba888 Electric On-Road 4 02-17-2004 03:36 PM
