Old 12-16-2006, 08:07 AM   #1
stephen hilton's Avatar
Default ride air remover RP600
hi guys anyone used one of these if so any tips thanks stephen
stephen hilton is offline   Reply With Quote
Old 12-16-2006, 08:19 AM   #2
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
I could be wrong, but if it is the shock tool you are talking about. I haven't used it. I think it is a gimmick like some other products out there. Just tap the shocks to get air bubbles to rise. Before assembling them slide shock stroke up and down, air is gone. Less bulk in your toolbox is better. Just my opinion.
RC America - Xray - Hudy - Gravity RC - KO Propo - Super Rad Graphics
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
F. Mendoza is offline   Reply With Quote
Old 12-16-2006, 10:30 AM   #3
If it is the shock pump, I've used it. It will drive you CrAzY! you can pump the thing 100 cycles and air will keep coming out. Does it work? Not really any better then doing it the manual way.
gezer2u is offline   Reply With Quote
Old 12-16-2006, 11:20 AM   #4
yes it is the shock pump. when i rebuild my shocks i can hear a squeeking noise.even though i have been slowly pumping the shocks for 30mins i can ever seem to get all the air out and was told that this is what the top guys use to get there shocks smooth
Old 12-16-2006, 01:15 PM   #5
i have been using one the last few months and i found that it helps speed the process up but i still have to move the shock shaft up and down and rotate it to remove all the air.
SPC Racer is offline   Reply With Quote
Old 12-16-2006, 02:12 PM   #6
sohlman's Avatar
Trader Rating: 89 (100%+)
Just my 2 - I have found the shock pump to be the best device to date to fully bleed shocks of all air. I've used it with all types of shocks with perfection every time. If you over pump the device, air will leak through the shaft seals and you will continually have air bubbles. This is my process:
1. Partially fill the shock body
2. Plunge shock shaft up and down by hand to remove large bubbles
3. Fill shock body to factory spec with piston down
4. Place all four shock in the shock pump
5. Pump 4-5 times...you will see the shock bodies bubbling
6. Wait 5 minutes or until all bubbles are gone
7. Remove shocks and plunge again by hand
8. Repeat 5 thru 7 twice more
Done
This may seem like a lot to do just to get perfect shocks, but they also last longer and operate smoother. Hope it helps.
Steve Sohl
sohlman is offline   Reply With Quote
Old 12-16-2006, 02:48 PM   #7
ok thanks i will try that
Old 12-16-2006, 02:51 PM   #8
scottwk1's Avatar
where in the states has anyone been able to find these?
scottwk1 is offline   Reply With Quote
Old 12-16-2006, 05:26 PM   #9
sohlman's Avatar
Tamiya Usa sells one: RC Damper Oil Air Remover #53710
Steve Sohl
Old 12-17-2006, 02:42 AM   #10
oh sorry i got mine from precision rc in hong kong
Old 12-17-2006, 03:08 AM   #11
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
go to any chemestry lab in any high school and they'll have a vacume. Big glass bell over a metal plate and it'll suck the air out of that chamber for as long as you want. I have access to one at my college. I go to the chem lab to build my shocks, I made a jig to hold the open, oil filled shock bodies and flip on the machine....few minutes later, the oil is almost white because there's so much air and air particles coming out of it. Then you put it back together, BUTTAH smooth shocks....that's my experience atleast...
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 12-17-2006, 07:43 AM   #12
thecrow2k's Avatar
Hes got a vaccuum in his shocks. KABOOM!
thecrow2k is offline   Reply With Quote
Old 12-17-2006, 10:45 AM   #13
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
only placed i have found in the US that sell them are
www.speedtechrc.com ( stock if limited)
and
http://www.rckenon.com/public_html/s...alog/index.php
i got mine from rckenon.
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 12-17-2006, 05:48 PM   #14
scottwk1's Avatar
thanks guys.
Old 12-17-2006, 06:06 PM   #15
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
thanks guys.
try rc-toro thats where i got mine
WTB: Ride shock air remover tool rraden R/C Items: Wanted to Buy 6 01-16-2008 06:34 AM
Brand-new RIDE Shock Air Remover nolan_racing R/C Items: For Sale/Trade 1 01-07-2008 02:22 PM
ride air remover TomB Australia For Sale/Trade 4 12-27-2006 06:33 AM
RIDE Shock Air Remover - LIKE NEW CONDITION koabich R/C Items: For Sale/Trade 4 08-05-2006 09:35 PM
***Ride AIR Remover (NEWIN BOX)**** Ko Racer R/C Items: For Sale/Trade 0 03-10-2004 09:42 AM
