Old 12-18-2006, 11:24 AM   #46
Nuno Gancho's Avatar
Default motor
Hello, have you peolpe run in asphalt with a 7x1 or 8x1
My motor goes very good in punch, but in 1 minute it starts to lose punch
why?
1 - the circuit is a fast one, i can not go full throtheel, if not the motor starts to scream a lot
2- if i gear down the final ration, to go full th i loss the punch
the brushes i tried both, normal one and the ones for 4minuts race, at the first one the wire chances color and in the second one the brush chance color.
Is the problem overheat? The brush? the final gear?
thanks for help
Nuno Gancho is offline   Reply With Quote
Old 12-29-2006, 01:11 AM   #47
S_fender's Avatar
Hello,
I've seen on webshop that there is "Team Checkpoint Hara edition".
What are the differences with the classic checkpoint series ?
Thanks.
S_fender is offline   Reply With Quote
Old 12-29-2006, 06:31 AM   #48
wallyedmonds's Avatar
this is good.
wallyedmonds is offline   Reply With Quote
Old 12-29-2006, 08:22 AM   #49
Jeff Brown's Avatar
why?
thanks for help
I would only use the Infinity brush with 7 or 8 turns on asphalt. I would also use the silver springs both sides. The brushes last about 4 or 5 runs before loosing spring tension due to them getting shorter, which can cause fade.
If the motor is screaming a lot down straightaways it means the motor is out of balance. If it was epoxied then it probably flung off. If it is drill balanced then the wires shifted due to high heat.
Depending on the track size, I would cut down the timing and gear up wit the motor to make it finish better.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 12-29-2006, 10:27 AM   #50
tantalus007's Avatar
Trader Rating: 17 (100%+)
is there a team checkpoint thread??? would like to ask people regarding their mod motors and stuff... thanks...
"para kang bata, nakahawak ka lang ng lapis kahit pader sinusulatan mo, magamit mo lang lapis mo..."
tantalus007 is offline   Reply With Quote
Old 12-29-2006, 11:05 AM   #51
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Originally Posted by RedRC
He can just wear the O'Donnell beanie in the meantime
Image from oOple
Marc's wearing a HB/HPI shirt!!! Is he going to run a thier sedans?
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 12-29-2006, 12:02 PM   #52
Snowy.
He runs HB/HPI for 1/8 offroad. He still runs touring for Tamiya.
trf_racer is offline   Reply With Quote
Old 12-29-2006, 01:14 PM   #53
Tek Nickal's Avatar
He better run Tamiya or they can just take his name off the 415 car.
Tek Nickal is offline   Reply With Quote
Old 12-30-2006, 02:16 PM   #54
pookat's Avatar
They already did!
pookat is offline   Reply With Quote
Old 12-30-2006, 08:42 PM   #55
Default MR no longer with Tamiya?
Pookat, where did you get this info from?
highflyer is offline   Reply With Quote
Old 12-30-2006, 11:29 PM   #56
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
I was curious if the whole brushless thing had anything to do with his change.. i had seen orion was working on a brushless system.. I had read the ae guys had been some what forced to run brushless.. with orion doing the brushless testing, i was curious if maybe the were going to force there guys to run them.. Might he have made the switch to keep from having to run brushless??
burbs is offline   Reply With Quote
Old 12-31-2006, 02:14 AM   #57
Stein Tumert's Avatar
Exclamation MR and Tamiya
Originally Posted by pookat
They already did!
Marc's father has confirmed on German website that Marc has signed again for Tamiya in TC...
The 415 MRE is/was a limited edition kit...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 12-31-2006, 06:31 AM   #58
I hope Marc Rheinard will continue to run for Tamiya......
They make good combination!!
Old 12-31-2006, 08:20 AM   #59
Thumbs up MR and Tamiya
This is the exact text from Marc's father from December 6th, 2006. (www.rcweb.de)
Basically he writes (for nonGerman readers) that Marc never had thoughts about leaving Tamiya and that he is very happy to be with Tamiya and looking forward to 2007 racing with his team members (Victor, Steen, Hupo). David Spashett will be consulting the team after he has now retired.
"Victor Wilck wechselt zu Tamiya !
Victor wird das europäische Tamiya-TRF-Team verstärken und sicherlich in diesem Team mehr Spaß haben als je zuvor.
Somit stellt sich die TRF-crew wie folgt auf :
Hupo Hönigl
Steen Graversen
Victor Wilck
Marc Rheinard
David Spashett hat ja den Sender an den Nagel gehängt, steht aber weiterhin beratend zur Seite.
Ich bin stolz, dieses Team auch weiterhin betreuen zu dürfen.
Und um Gerüchte um Marc´s Vertragsverlängerung aufzuklären :
es gab zu keinem Zeitpunkt Überlegungen, das TRF-Team zu verlassen. Marc ist bei Tamiya sehr glücklich und freut sich bereits auf 2007, um mit
diesen Jungs auf die Pirsch zu gehen.
Somit werden viele Neuigkeiten beim DHI-Cup, dem ersten großen Rennen in 2007, zu beobachten sein.
Lassen wir uns überraschen, was noch alles "neu" sortiert sein wird.
Dromi"
Stein Tumert
Old 12-31-2006, 02:59 PM   #60
pookat's Avatar
I never said that he left Tamiya!!
The car MRE was a limited run and the MSXX is on the way.
Rheinard running for Team Magic at the Worlds... or8ital Electric On-Road 8 08-10-2008 04:40 AM
NIB, Team Orion Rheinard 7x1 modified motor Kraig R/C Items: For Sale/Trade 2 12-26-2007 11:39 AM
Team Checkpoint 'Marc Rheinard Edition' motor Victor A Electric On-Road 16 11-25-2007 10:35 PM
Marc Rheinard Replica Mazda 6 Body - Tamiya/Checkpoint Anthony.L R/C Items: For Sale/Trade 7 06-08-2007 02:13 PM
Marc Rheinard joins TEAM CHECKPOINT! seri Racing Forum 0 12-15-2006 09:38 AM
