Old 12-14-2006, 11:32 AM   #1
TRFTIM's Avatar
Default Diff settings?
I have a 414 M2 and was wandering if i needed to have the diff settings the same tesion ? I run on fairly loose surfaces so so was wandering what is the best settings to use?
Thnaks
TRFTIM is offline   Reply With Quote
Old 12-14-2006, 11:42 AM   #2
pheyhoe's Avatar
R/C Tech Charter Subscriber
Diffs should be as free as possible but not slip with the power of the motor. Otherwise you will melt it.
Your rear diff should always be as free as possible. The front however can be adjusted for differnt handleing, mainly on high grip carpet...
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 12-14-2006, 11:44 AM   #3
TRFTIM's Avatar
Thanks for the quick reply
So if i am on loose stuff i need to have the diffs the same tension?
Old 12-14-2006, 01:22 PM   #4
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
i like the front to always be a little tighter than the rear. this way the front (in relation to the rear) is somewhat like a spool, and it helps to pull the front end around the corner. a looser rear will allow the rear wheels to independentally rotate easier, making the rear end more effiecent power delivery wise.
-Zac
Z.Hallett is offline   Reply With Quote
Old 12-15-2006, 02:50 AM   #5
t4m1y4niac's Avatar
diff setting is really depend how you drive your car, surface condition you must doing some trial & error to get the optimum diff setting. Fr tighter than Rear, Fr looser than Rear, the same tension loose or tight...
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Xray t2 Multi Diff Settings CREWMAN Electric On-Road 3 04-18-2008 09:36 AM
Diff settings [email protected] Electric On-Road 1 07-08-2007 03:01 PM
diff settings? i keep loosing control. Built B16A Nitro On-Road 18 01-04-2007 02:20 AM
DIFF SETTINGS wolfman76 Electric On-Road 3 08-02-2005 05:03 PM
Diff settings? Sleighty Electric On-Road 2 08-27-2003 09:30 PM
