Old 12-14-2006, 07:15 AM   #1
stephen hilton's Avatar
Default hudy all in one setup system
hi i have the all in one set up system but i dont know how to use all of it could somebody tell me if 1.5 degree camber points the wheels to toe out and if 2.0 points them out even more wierd question i know thanks stephen
stephen hilton is offline   Reply With Quote
Old 12-14-2006, 07:47 AM   #2
Stein Tumert's Avatar
Camber and toe are different things....
Do you have the instruction book from Hudy that comes with the setup kit?
It includes good descriptions of the different things
If you don't have it, have a look at the Hudy website
http://www.hudy.net/xhudy/products/p...3&kategoria=64
Stein Tumert is offline   Reply With Quote
Old 12-14-2006, 09:12 AM   #3
thanks stein dont you ajust toe and camber by turning the turnbuckles?
Old 12-14-2006, 09:31 AM   #4
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
It depends on the chassis that your are running. In most cases, camber is adjusted by the turnbuckles, the exception is a pivot ball suspension car (usually only the front).
Front toe is also adjusted by turnbuckels, normally connect to your servo / steering block.
Rear toe depends on the chassis. Some cars will use pivot / hinge pin blocks, some use spacers / shims, some use different rear hubs, and some cars will use a combination of all of the above.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Hudy All in one Setup system 1/10 Fred Perkins R/C Items: For Sale/Trade 4 12-17-2006 04:15 PM
Hudy Setup System and Digital Weight Monitoring System racer rich R/C Items: For Sale/Trade 16 02-23-2005 07:56 AM
WTB: Hudy Setup System Roadsplat R/C Items: Wanted to Buy 2 12-13-2004 01:36 PM
new hudy setup system tc3 racer sc Electric On-Road 19 09-07-2004 07:44 PM
FT: Hudy MP 5 or 6 setup system for touring car setup system AQuionIV R/C Items: For Sale/Trade 1 05-30-2004 02:08 AM
