Old 12-12-2006, 09:07 PM   #1
Default Touring Car Question
Hello all, new to these forums and I am looking for some help getting my TC4 to go a little quicker...Currently I run on a oval carpet track...I use the stock 27t trinity monster motor that is required by the track I race at...Currently I cannot get my car faster...The question that I have for you guys is what brushes and srping combo's do you recommend to get the most top end speed out of a stock motor...Thank you and any help or suggestions would greatly be appretiated
jeffbhhs is offline   Reply With Quote
Old 12-12-2006, 11:53 PM   #2
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Most important thing is to make sure teh brush hoods are aligned. but after that, F-brushes and i would say Purple + and Red - Springs. If you want more torque, go with a Red + and Red -/Red + Green -. But you are shooting for top end speed, so a Purple + and Red - should do that for ya
Ben
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 12-13-2006, 09:36 AM   #3
Ben
How do you align the brush hoods? I saw some tools on tower hobbies sites, but the details were lacking... thanks
Old 12-13-2006, 09:44 AM   #4
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
Originally Posted by jeffbhhs
How do you align the brush hoods? and is there a certain setting that it should be on? thanks
Several companies make brush hood alignment tools, like Muchmoore, Trinity, Brood, etc.
Mucmoore here
The tools are very easy to use. Just loosen the screw and spring post, insert square bar through bush hoods and round bar through bearing / bushing. Once aligned, tighten the screws and post and your done. There should be a slight pinch when pulling out the sqaure bar.
You can also "tweak" the timing of a stock motor using one of these. When adjusting the hood, cock the endbell clockwise slightly, and it will advance the timing.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 12-13-2006, 11:14 AM   #5
Mucmoore here
How do you know that you are correctly aligned?
Old 12-13-2006, 12:29 PM   #6
The tool will only go in if the motor has general alignment. Basically you are just making sure the bushes / hoods are centered on the com with this tool.
Even after using a brush hood tool, it is best to break in the motor for a short time, and check to make sure the brushes are wearing evenly, and adjust the hoods as needed.
You can also check out this site for more tips and tricks on tuning motors - http://www.motortuningsecrets.com/
Retired from RC....
Old 12-13-2006, 02:30 PM   #7
sinisterRC's Avatar
The tool will onyl go in if the motor has general alignment. Basically you are just making sure the bushes are centered on the com with this tool.
Even asfter using a brush hood tool, it is best to break in the motor for a short time, and check to make sure the brushes are wearing evenly, and adjust the hoods as needed.
very informative site thanks!!
MUGEN Tekno - MBX6TE TEKIN
Custom Nitro Pro Mod
MRX6 under construction..
sinisterRC - High Performance R/C
sinisterRC is offline   Reply With Quote
Old 12-13-2006, 05:49 PM   #8
Trader Rating: 27 (100%+)
You can also get some more straitaway speed by puting a 0 degree block on the back of the car. If the rear starts to come around on you after that, try softer rear spring or if you can afford to loose a little steering add front sway bar. I ran carpet oval w/ sedans for a long time. A good thourogh cleaning will help keep your car as smooth as possible. every little bit helps on the oval, where you got 4 second laps versus 11 second as compared to onraod
convikt is offline   Reply With Quote
Old 12-14-2006, 09:38 AM   #9
I am currently running a sway bar in front, yesterday I was finally able to gain a lot of speed, and it was because of my new matched battery, I was not a believer until I saw it for myself... I just bought a pack of ib4200 matched cells(in sidexside shrink rap though) and it was a huge improvement over the venom 4200s that I had been running, initally I was having handling problems because I was not expecting so much power lol...
Touring Car ESC Wire Gauge Question wdm80 Electric On-Road 22 11-27-2004 01:23 PM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 09:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 12:46 PM
Nitro touring for electric touring iflybyu R/C Items: For Sale/Trade 1 09-28-2003 11:44 PM
