Old 12-10-2006, 06:35 PM   #1
Default 12th scale stk motor tuning
Can some shed some light on tuning and gearing ect. for carpet onroad I can except the fast always fast but what do they look at specifically? Lets use the monster stk.as a example. Thanks
impdog is offline   Reply With Quote
Old 12-10-2006, 07:02 PM   #2
Send a message via AIM to $rusty$ Send a message via MSN to $rusty$
Ok nevermind, for rollout charts go to gearcharts.com..and the rest EA pretty much said it.
Rusty Andersen
thercbarn.com
$rusty$ is offline   Reply With Quote
Old 12-10-2006, 07:11 PM   #3
not really my son has raced successfully for 19 years (electric) were looking for motor info. and gearing /rollout info. for 12th scale onroad carpet racing.
Old 12-10-2006, 07:31 PM   #4
Trader Rating: 23 (100%+)
I believe he is looking for things such as
What ampdraw should the motor be tuned to at what voltage?
Whats the best brush?
Drops?
CO27 vs. Monster?Any cuts (hole, slots, filed edges)
Break-in Procedures?
impson is offline   Reply With Quote
Old 12-10-2006, 10:07 PM   #5
TEM
TEM's Avatar
Drops?
It's been a LONG time since I did 12th stock but heres what I remember doing: New monster; polish bushings, align hoods, diamond true the comm, shimm armature, install new brushes (I like 767's, with either a single slotted or small hole in center for 12th scale), red and green springs +/-. Oil bushing, run in for 2 mins on 3 volts with fan blade, true comm again(optional, and I do it sometimes), should pull around 10amps at 3 volts no-load on a Turbo35 charger.
Gearing? Varies on battery performance and track layout. Something like 46-50mmpr rollout on tight track start low and go up is good idea. It's hard to say for stock sometimes; some folks like to gear to the moon and beat the crap out of their motors to go fast just cause new batt's got the muscle to do it!
TEM is offline   Reply With Quote
Old 12-10-2006, 10:32 PM   #6
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Bill,
Our setup for the Champs on 12th scale was the following:
Co27, F brushes with .010 off the trailing edge and a 2mm hole in the face. Break in at 2 volts with a fan and a liberal amount of Zubaks speed juice for 300 seconds. It should pull 7.0-9.0 amps like this. After break in spray out with motor cleaner and then lightly skim comm. Re-break in for 300 seconds with the speed juice at 2 volts and then spray out again without removing the brushes or springs. Put in car, 4 drops of juice down each hood and roll out at 1.80-1.95 depending on amp draw...Roughly 1 tooth per amp on the original build (7.0 amps=1.95 roll out). Amp draw will go down slightly after skimming the comm but this will allow you to run the motor in 12th scale 4-5 times without rebuilding it and it will keep getting faster. Just spray out after each run and then break in for 30 seconds. Re-apply drops and go again.
We used this at the Champs and TQ'd and won 12th stock, Won 19 turn 12th scale and TQ'd TC Stock. The only difference we do in TC is no hole and we do not tear apart and skim the comm after breaking in the first time.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 12-11-2006, 06:09 AM   #7
Thank you for the help EA.
"we need to do at least 11.2 km/s to break earths orbit or almost the speed as Cam's car"
Neil Armstrong 1968
Cammer is offline   Reply With Quote
Old 12-11-2006, 08:37 AM   #8
Thanks EA....That is great information for all of us!
Old 12-11-2006, 09:05 AM   #9
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Wrong thread...
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 12-11-2006, 10:56 PM   #10
Thank you for posting your setup on the motor. I would like to hear what others think? Also, what indications to look for in a 19T motor? Lets say Komodo Dragon motor.
Mr. Shookie:
Since you said this is the wrong thread, where is this being discussed?
GhostRacer06 is offline   Reply With Quote
high end charger, 12th scale tires, motor lathe, tire truer primusblowsgoat R/C Items: Wanted to Buy 14 02-04-2009 02:19 PM
motor tuning and gearing for co27 in 12th 2056dennis Electric On-Road 1 08-30-2007 07:04 PM
for sale 12th scale, revo 3.3, neo motor, jammin cr ft, t2-007us, and aps dyno/charg ditchpickle18 R/C Items: For Sale/Trade 51 06-10-2007 10:48 PM
Mod motor tuning for 4 cell 12th scale? TEM Electric On-Road 5 03-29-2007 10:36 PM
Looking for cheap ESC for 1/12th scale. 4-7 cell, no motor max!! DennisNyholm R/C Items: Wanted to Buy 3 03-01-2002 05:52 PM
