Old 12-10-2006, 02:58 AM   #1
Default Spektrum > Switch on > Full Throttle
I got a problem with my Spektrum when switching on the car.
It takes a second to find the transmitter signal and in that period the ESC gives full throttle. Very annoying with a 19T Stock motor. But with my new LRP X11 5.5 Brushless it's a big problem!
It is possible to switch off the transmitter and have the ESC turn to neutral. I had this in my TC last year. But with my 1:12th I have the same problem, but with a different ESC.
So I have three cars, with three different ESCs. All are working fine. But only one of the stays neutral when the transmitter is off or the second between switching on and finding the transmitter signal.
I never had this problem with my old radio system (both PCM on and off), only with the Spektrum I get this problem.
Does anybody know how to fix this?
MBreve is offline   Reply With Quote
Old 12-10-2006, 06:45 AM   #2
d4_racer's Avatar
Send a message via MSN to d4_racer
ummm, throttle trim? check your radios throttle setup and reset your speedy. it might have something like novaks 1 touch setup.
\____
==\_\___===___ | *HPI Baja SS kit;*
==(@)\_______\(o) +UNDER CONSTRUCTION+
out of racing, but a proud marshall, lol
d4_racer is offline   Reply With Quote
Old 12-10-2006, 07:08 AM   #3
Trader Rating: 198 (100%+)
Try binding again. You need to set the fail safe portion of the spectrum. This is normal if you bound the units. Then adjusted your esc.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 12-10-2006, 08:14 AM   #4
Jmccormick's Avatar
dodgeguy is correct when you first turn on you cars reciever it automaticly goes to failsafe while it searches for the signal from your transmitter. A simple way to check your failsafe settings is to turn on your radio and then your car wait for the signal to set during this process the LED's on both trans and rec will flash rapidly when they are set the LED will be on continously then while you car is supported with the wheels of the ground turn your transmitter off then the green LED on the reciever should go out indicating that the reciever has gone to failsafe mode. If your cars drivetrain starts moving when in failsafe mode then you need to reset your failsafe settings with the throttle trim on your radio and ESC in the neutral position or if desired with some brake dialed in it's your choice. Then rebind the system and you should be all set.
Jmccormick is offline   Reply With Quote
Old 12-10-2006, 09:41 AM   #5
Thanx guys, re-binding did the trick indeed.
Never thought about the fail-safe setting.
MGT won't stop going full throttle? jatoattack Rookie Zone 6 04-23-2008 10:06 PM
full throttle cut out lowndsie Electric Off-Road 4 05-12-2005 02:50 PM
full throttle btuner Electric Off-Road 3 04-02-2004 10:17 AM
car going to the right when going full throttle alucard13 Nitro On-Road 14 05-08-2003 02:38 AM
