Old 12-09-2006, 12:22 PM   #1
c1 racin's Avatar
Send a message via ICQ to c1 racin Send a message via AIM to c1 racin Send a message via Yahoo to c1 racin
Default Stock Motor?
What's the best stock motor?
Co27
Core
Monster
Epic X
NeXusRacing.com
MurnanModified.com
MobileRCRacing.com
c1 racin is offline   Reply With Quote
Old 12-09-2006, 12:33 PM   #2
with out a doubt the co27 and the team brood version is the best you can get
Rasmus TbEvo IV is offline   Reply With Quote
Old 12-09-2006, 01:23 PM   #3
dakrat's Avatar
some motors doesnt work very well on some track. some motor has more torque than the other which makes it more suitable for smaller size track for corner to corner grunt. motors with higher RPM is suitable for larger track or lower traction. go to your local track and ask around on what they use.
dakrat is offline   Reply With Quote
Old 12-09-2006, 05:55 PM   #4
GUINT1's Avatar
Rasmus you have a PM...
Empire Racing/Maxy's fuel/Ko Propo
Motor. .21 FLASH/353 Race
Body. Zytech/P909
Tyres. Ky Red Box
GUINT1 is offline   Reply With Quote
Old 12-09-2006, 07:57 PM   #5
Grenade10's Avatar
Trader Rating: 37 (100%+)
My 2 cents - Both the X-Stock and CO-27 are very good motors. There are good points with both, 1/12 stock I've had good luck with the X-Stock. I have also tuned CO-27's for other racrs running touring car.
Both have a sweet spot, the X-stock is much smaller than the CO-27. The motor and gearing will be change for each track.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 12-10-2006, 05:08 PM   #6
GUINT1's Avatar
Grenade10 u have a pm.
Body. Zytech/P909
Tyres. Ky Red Box
Old 12-10-2006, 05:24 PM   #7
I would have to agree with the CO27. I have found it to be best on small to medium sized tracks. If you are on a large track with long straights and sweepers then I would say a higher RPM motor would be better suited.
Johnny9s is offline   Reply With Quote
Old 12-12-2006, 05:00 AM   #8
stephen hilton's Avatar
Co27
Core
Monster
Epic X
i have have also heard that co27 are the same as monsters with a tad more rpm and torque and the x stock has slightly more rpm that the roar
stephen hilton is offline   Reply With Quote
Old 12-12-2006, 06:44 AM   #9
Skiddins's Avatar
The CO27's are supposed to have more torque low down but I don't believe they have any more RPM.
The X-Stock is supposed to be a high revving motor but with lower torque.
Which motor is best to use would depend on the track.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-12-2006, 08:18 AM   #10
Skiddins
yep skiddins was right (checked it out on t-bangs site) but 90% of the time the best motor is the one that is regulary maintained eg skimmed and brushed and the one that is correctly geared stephen
Old 12-12-2006, 10:24 AM   #11
nagatahawk's Avatar
I would have to agree with Stephen,
I have a couple of p2k2's that are in very good condition, cut com, 767 brushes and all the normal motor tweaks. off the shelf from lhs. I ran one for oval and the lap times were very close to my cobalt. Big Jim Greenimeyer ( arguably on of the best motor builders) pulled the highest readingswith the p2k2.
My monster pulls the most amps and rpm on my aps motor dyno. but havn't been able to find the correct gearing yet. I will spend more time with it soon. It pulled more rpms and amps than my x, havn't run that yet.
as stephen said above, the best motors are the motors that have skimmed coms, seated brushes and maintained.
after all they all have 27 machine wound turns, and the cans are pretty much the same, except the cooling wholes and colors. I haven't looked but the arms are pretty close. how much is one less lamination or spacing between the rotors going to make the motor? 1 lap faster? I'm sure that there are subtle differencese in the motors other than their colors. but you can gear, brush and spring them all to achieve good results.
nagatahawk is offline   Reply With Quote
Old 12-12-2006, 01:24 PM   #12
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
believe it or not the vent holes have more purposes besides cooling the motor.
the shape determines how hard the next polarized magnet "grabs" and rotates the arm. the smoother the transition, the smoother the arm is rotated. the begining edge ( a harsh straight edge parrallel in relation to the arm) deals with the magnet field and how much magnetic drag there is. the harsher the edge, the more abruptly the magnetic field ends.
-Zac
Z.Hallett is offline   Reply With Quote
Old 12-12-2006, 03:12 PM   #13
also after time as you skim the comm down (providing you dont cook the magnets by over gearing) the motor should be quite a noticably quicker than from when it was new. some drivers do that at big compertitions skim the comm right down to get a quicker motor but it only then lasts 3-4 runs and is very expensive unless you are sponsored. but dont skim it below 2.70 as the copper will flake off during the run hope this helps stephen
Old 12-12-2006, 03:29 PM   #14
thecrow2k's Avatar
Anyone ever used a Epic GM3, I just bought one new because it was cheap. Will it be decent for a small indoor carpet track.
thecrow2k is offline   Reply With Quote
Old 12-12-2006, 06:30 PM   #15
Z.Hallett's Avatar
a word to the wise:
you should NOT cut the comm when it reaches that small of a size. the comm could (and will) peel right off. the lathe bit could get stuck in the separations between the plates and possible break off the cutting edge.
-Zac
ps: the comm size is 0.270" not 2.70"
Stock Motor Lot w/Trinity case and Much More Motor Mate Racer4Life R/C Items: For Sale/Trade 2 08-19-2007 09:04 PM
Method to run-in stock to higher turm motor? or a stock tune to a higher turns? micro80 Malaysian R/C Racers 0 06-16-2007 12:40 PM
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 11:22 PM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
trade 11x2 like new motor for stock motor BuggyMulisha R/C Items: For Sale/Trade 3 11-08-2004 03:16 PM
