Old 12-13-2006, 02:00 AM   #16
stephen hilton's Avatar
Originally Posted by Z.Hallett
a word to the wise:
you should NOT cut the comm when it reaches that small of a size. the comm could (and will) peel right off. the lathe bit could get stuck in the separations between the plates and possible break off the cutting edge.
-Zac
ps: the comm size is 0.270" not 2.70"
woops sorry i knew it was one of them yep that happend to me after i had been using the motor for ages. skimming away and then snap there goes my lathe bit good job i was using a carbide then though
stephen hilton is offline   Reply With Quote
Old 12-13-2006, 08:21 AM   #17
Grenade10's Avatar
Trader Rating: 37 (100%+)
Good note on the size of the com's.
Something else to watch, as I've see this several times on CO-27s lately.
When cutting the com, watch the first cut. Watch for one lamination being cut and not the others. This is a sign of it coming loose from the base material. We have a trintiy sponored driver who tosses me his used up motors for parts to repair other racers motors, Many Cudos CATO!! Anyway, even he had one separate. Once this happens the motor is almost toast. If there is enough thickness of copper, it can run, but days are numbered.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 12-13-2006, 08:29 AM   #18
jo90's Avatar
I have been using the Co27 and found it a good replacement for the Monster. Putnam is my choice of tuner and have found their motors to be excellent.
Give the CO a try, you might find the gearing is slightly different to the monster so check the motor temperature and adjust for the track.
Sponsored by SerpentUK, ModelTech & MTroniks
S400 / MTroniks IP6 / Team Brood / KO Propo = Loads of fun
jo90 is offline   Reply With Quote
Old 12-13-2006, 08:39 AM   #19
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Roar motor is the best
it just works every where
i can get the monster & co27t to work but for varied application the ROAR is my motor choice (so far)
as to which tuner is best none of them THEY are all good ,you tell them what the track is like where your racing & Bobs your uncle thye will guide you throught the mine field of tuning tricks
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 12-13-2006, 10:24 AM   #20
i have also found that the roar is fast everywhere. but i have also heard that they have stopped making the roars and the x is the replacement .
Old 12-13-2006, 01:14 PM   #21
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
that is true, the X is the next roar stock motor.
i like the X a little better tho.
-Zac
Z.Hallett is offline   Reply With Quote
Old 12-13-2006, 03:21 PM   #22
BigDaddyT's Avatar
Send a message via MSN to BigDaddyT
Hey Guys,
Stephen is right - the X stock fills the same niche that the EPIC ROAR used to. However, I'm pretty sure the ROAR's are still in production. Trinity usually keeps the popular motors around for quite a while - you can still get Green Machine's, P2K's, etc. if you like them.
My 2 cents is that the CO-27 is the first stock motor to have in your collection because it's the most versatile and tolerant of gearing mistakes and so forth. From there, you might want to look at adding a higher RPM motor like the ROAR or X for the situations that demand it.
That said, the EPIC ROAR is a more versatile motor than a lot of people have given it credit for. I ran it pretty much exclusively before the new motors came out and it did a great job on all kinds of different tracks for me.
For all the guys in the UK, the choices are a bit limited as the new motors are not BRCA approved. EPIC ROAR is probably a good way to go. Elsewhere, CO27 is a good starter, and maybe add an X or ROAR to experiment with on large tracks.
T-Bang Hobby Technology Inc. - www.t-bang.ca
Extreme Performance RC Motors and Racing Supplies - Vancouver, Canada
Team Corally - Trinity - Dekelz.com
BigDaddyT is offline   Reply With Quote
Stock Motor Lot w/Trinity case and Much More Motor Mate Racer4Life R/C Items: For Sale/Trade 2 08-19-2007 09:04 PM
Method to run-in stock to higher turm motor? or a stock tune to a higher turns? micro80 Malaysian R/C Racers 0 06-16-2007 12:40 PM
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 11:22 PM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
trade 11x2 like new motor for stock motor BuggyMulisha R/C Items: For Sale/Trade 3 11-08-2004 03:16 PM
