Old 12-08-2006, 04:36 PM   #1
Send a message via AIM to $rusty$ Send a message via MSN to $rusty$
Default Comm Lathe Help!!!!
Ok I have cut a comm before, but this time the whole thing flew off.. I can't seem to figure out why? any suggestions?? (I did search before this too)
Rusty Andersen
thercbarn.com
$rusty$ is offline   Reply With Quote
Old 12-08-2006, 04:59 PM   #2
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
OK rusty,
First What flew off? the copper on the comm? the wire off the stacks? the comm off the lathe?
Need to know what problem we are fighting here.
If its the copper coming off, then your comm was too thin and you need a new armature.
If the wire has come loose from the armature, same result, replace the Armature.
If the comm is bouncing around then you have either balance issues or your plates aren't square.
I hope I helped a bit..
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 12-08-2006, 05:19 PM   #3
Sorry, it's the whole armature part..thanks for putting that though.
Rusty Andersen
thercbarn.com
Old 12-08-2006, 05:39 PM   #4
Speedie's Avatar
make sure the motor is spinning the correct way.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 12-08-2006, 05:42 PM   #5
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
As far as I know the cutting tip should set a hair above the centerline of the comm. We all have our own theories. Did the commrotate inthe right direction? Did you use more than 5 volts to power the lathe? Back track all your steps and I'm sure you will find your problem, good luck.
RC America - Xray - Hudy - Gravity RC - KO Propo - Super Rad Graphics
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
F. Mendoza is offline   Reply With Quote
Old 12-08-2006, 05:43 PM   #6
I used a mini battery. What way is it supposed to turn? That might be my problem.
Rusty Andersen
thercbarn.com
Old 12-08-2006, 05:59 PM   #7
Speedie's Avatar
what type of lathe are you using. Most lathes spin clockwise looking at it from the right side.
Old 12-08-2006, 06:11 PM   #8
I'm using the Team Cobra Pro Com..
Rusty Andersen
thercbarn.com
Old 12-08-2006, 06:19 PM   #9
RCpurplecow's Avatar
I have the Team Cobra lathe and the motor should spin away from the lathe. so counter clockwise. hope it works!
TEAM SRU
FT TC5
NoVak
rematch batteries
RCpurplecow is offline   Reply With Quote
Old 12-08-2006, 06:44 PM   #10
Speedie's Avatar
the cobra lathe should spin clockwise from the right side. The cutter is facing downward so that when the comm spins up to the bit the force of the cutter going into the com holds the comm in the lathe. Like he said tho from the front the comm should be spinning away from you. Over the top
Trinity Tru Lathe Motor Comm Cutter Lathe maximum R/C Items: For Sale/Trade 4 05-14-2007 04:56 PM
Hudy comm lathe and Fantom comm lathe ACEDEAN R/C Items: For Sale/Trade 0 05-02-2007 11:27 AM
XIPP Super Lathe 3 / (pics) comm lathe diamond bit evostyle R/C Items: For Sale/Trade 8 12-01-2006 12:53 PM
Trade EXTREME COMM LATHE(Hudy)for MUCH MORE COMM LATHE JoeyE R/C Items: For Sale/Trade 0 05-07-2006 09:49 AM
Tire Lathe, Motor Dyno, Comm Lathe For Sale 17Mark71 R/C Items: For Sale/Trade 8 06-05-2005 01:07 PM
