Ko Vfs 2000 Esc
Old 02-25-2003, 06:03 PM
bruisedwillis's Avatar
Ko Vfs 2000 Esc
Is it good? How good? Thanks
bruisedwillis is offline
Old 02-25-2003, 06:22 PM
Brian McGreevy's Avatar
Well Chris Doseck used it to win 12th scale mod at the Cleveland Indoor Champs...that should be enough.
Brian McGreevy is offline
Old 02-25-2003, 06:32 PM
Trader Rating: 75 (100%+)
Axiom is right. They are great speedo's. I use them as well, but I also race with Chris every week........
RBLove is offline
Old 02-25-2003, 06:38 PM
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Talking Great Speed'O
The VFS 2000 is a awesome one....
I have 2 of them work flawless
-Dave
JDM_DOHC_SiR is offline
Old 02-25-2003, 07:37 PM
peter_robinson's Avatar
Trader Rating: 21 (100%+)
they represent the newest technology in user adjustable throttle frequency, which means that you can do the smae things right at the speed controler that other poeple might need a technican to do for them.
peter
peter_robinson is offline
Old 02-25-2003, 08:05 PM
peter
Can I use it without the setting adapter? I'm interested in buying one ((Tamiya TRF 2002 version) but would prefer not to buy the setting adapter.
itchynads is offline
Old 02-25-2003, 08:13 PM
sadly, that's the chink in the armor.
to adjust the drive frequency, you do need the setting adaptor. but have no fear, the stock setting in the speed control (if the TRF version is the same settingas the VFS version) is right down the middle of the road, and is most times great in both stock and mod
peter
Old 02-25-2003, 08:15 PM
sorry forgot...
the drive frequency is adjustable from 1 - 32 , and the stock setting is 17, just in case you were wondering
peter
Old 02-25-2003, 08:43 PM
sorry forgot...
peter
Thanks Pete. Not being able to adjust the drive frequency is not a problem for me as long as i can set the ESC for the transmitter (brakes and throttle) without the setting adapter it should be ok. I can always buy the setting adapter later. I like the idea of the external solder posts, so much easier to solder the wires onto it.
What's the lowest turn motor it can handle?
Old 02-25-2003, 09:35 PM
TRF-Powered's Avatar
No limit~!
I have both VFS and TRF version of the ESC. They are both GREAT!!! (well, they are the same!). However if you have a 7.2 V digital Servo, you might want to go with the VFS instead of the TRF version. The TRF version doesn't come with the extra wire that connects to the 7.2 V servo. And you do need that wire to make the servo work properly.
If you are a Hara Fan. Hara is working on his own lines of RC parts for HPI and also, you will soon see a Hara Version of the VFS speedo. From what I have heard, that Ko has OEM the speedo to Hara. And when the Hara version comes out, it will have different base setting, where it would be pre-set to what Hara use most often.
It's a great Speedo!!!
TRF-Powered is offline
Old 02-26-2003, 12:59 AM
Cole Trickle's Avatar
Originally posted by TRF-Powered
... The TRF version doesn't come with the extra wire that connects to the 7.2 V servo. And you do need that wire to make the servo work properly...
The FET-wire aint nessecary - KO 7,2 volt servos comes with a little manual, that shows hows to connect them directly to the battery.
Cole Trickle is offline
Old 02-26-2003, 05:11 AM
There's an option to the setting adapter: PC Interface. It's not as handy, but depending on price, needs and if you maybe got a protable PC....
KO Propo VFS
Old 02-26-2003, 05:15 AM
Default Rocket Max
Another ESC with variable drive frequency is the CS-Electronic Rocket Max.
It automatic changes the frequency, depending on how fast you pull the trigger. It dont require an adapter, yet it's adjustable.
Rocket Max
Old 02-26-2003, 07:20 AM
lee82gx's Avatar
hmm so many of the same thing
so the tamiya trf ESC id actually a KO VFS2000?
i might be interested in getting that..they look like the next hot thing.the PC interface..does it come free?how can anyone resort to the PC interface and still say it's cheaper/more simple than a setting adapter?
lee82gx is offline
Old 02-26-2003, 08:51 AM
TFR
TFR's Avatar
Where would I be able to pick up one of this nice speed control??
TFR is offline
