TC3 Setups
Im going to run indoor carpet this winter. Got a FT TC3 with the nitro steering mod. Looking for setups, likely stock motor. thanks.
is this for the new belt car?
no, its the old tried and true shaft driven car
Front
rear shock tower on the front copper spring 50 wt oil F-0 front block shock as upright as possible .5 toe out 6 degree caster blocks camber inner top hole -1.5 degree camber Rear red spring 40 wt oil shocks as upright as possible F block and 3-2 block camber link outer in lower hole inner in inside upper hole -1 degree camber battery in the front i hope this helps any Q's pm me |
thanks, i gotta get some foam tires for it. I guess the best thing to do is see what the other people at the track use but the track is an hour away. Id hate to show up and not be able to get any from the shop. do these use the 26mm rims? double pinks the good ones?
Tire wise you can go with: * In no certain order, ABC order!
Jaco Rims- Double Pink Orange (Front) Double Pink (Rear) Orange/Purple (Front) Purples (Rear) Parma Rims- Cyan (Front) Magenta (Rear) Ingios (Front) Magenta (Rear?) Plaid (Front) Purple (Rear) Trc- Cyan (Front) Magenta (Rear) Plaid (Front) Purple (Rear) That is the typically tire choices for indoors on carpet. These are all 28mm tires. If you have questions regarding any of these compounds please pm me or post here. I check the boards at least 3-5 times a day. Best of luck to you! |
Originally Posted by mach51
Do these use the 26mm rims? Double pinks the good ones?
I BRS
Double Pink Orange (Front) Double Pink (Rear) |
thanks for the info, heres my FT TC3
http://img.photobucket.com/albums/v4...2_01_06012.jpg |
