Old 12-06-2006, 08:58 PM   #1
Jochim_18's Avatar
Default What Lipo Charger to use?
What kind of charger are you guys using to charge your Lipo packs. I've seen a lot of charger but I'm mainly looking for charger that can safely charge your lipo packs and balance/matched it at the same time and cost less.
Can you guys list some charger and their prices.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 12-07-2006, 01:57 AM   #2
Stein Tumert's Avatar
Much More Cellmaster
Team Orion Advantage
probably not cheap either of them....
Stein Tumert is offline   Reply With Quote
Old 12-07-2006, 02:05 AM   #3
If you think the Much more Cell master or the Orion Advantage is expensive, you can get Duratrax's ICE charger. Just as good for charging LiPo...
Ben.C is offline   Reply With Quote
Old 12-07-2006, 03:57 AM   #4
Take a look at the Pro-trak charger-
I bought mine 7 years ago, I have just updated for the 2nd time (for a nominal sum) to now handle Li-Pos. How many other chargers can you say that about. It will do everthing you require and more with the accessories available.
Second hand units sometimes become available - but are snapped up like gold dust - and go for a good price (something to think about if you want to sell it later).
Try them at: http://www.pro-trak.co.uk/
Phil, who is Pro-Trak has been making chargers for many years, and what he doesnt know about batteries/charging isn't worth knowing as you'll see on his site.
SagaMike is offline   Reply With Quote
Old 12-07-2006, 07:56 AM   #5
adamge's Avatar
Meeting your requirements are the
FMA Cell Pro
http://www.fmadirect.com/detail.htm?...116&section=45
$60
DN Power
http://www.xushobby.com/servlet/Detail?no=168
$80
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 12-07-2006, 08:00 AM   #6
Lonestar's Avatar
as of now perfectly happy with my Orion avionics advandced... $100 well spent, also charges NiMH at 5A... tiny, robust package. Treats my 4800mAh very well so far.
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 12-07-2006, 08:13 AM   #7
rampal's Avatar
Send a message via MSN to rampal
I have the duratrax ICE and the Multiplex LN-5014. You can find both of them on Tower. The orion avionics is "exactly" the same as the multiplex or the ripmax and so on...
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 12-07-2006, 09:37 AM   #8
MrBlack's Avatar
The Multiplex and Ripmax are made by a different manufacturers then ours.
Our Avionics Flight Charger is made by the same supplier that makes our Advantage Advanced Charger which took the past two IFMAR World TC Champs to victory.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 12-07-2006, 09:39 AM   #9
MrBlack's Avatar
I personally ( but I am biased) thing the Advantage Flight Charger:
http://www.teamorion-avionics.com/Ad...Flight+Charger
Is the best all around charger out there and can be found for about $60-70 if you look around.
Features:
• Capable of charging and Discharging:
- NiCD/Ni-MH 1-14 cells
- Li-Io or Li-Po 1-5 cells
- lead acid (Pb) batteries 1-6 [2V per cell]
• Adjustable charge current (0.1A-5.0A)
• Adjustable discharge current (0.1A-1.0A)
• “Zero Delta V” peak detection for NiCd and Ni-MH batteries
• “Constant current/discharge voltage” charge method for lithium-Ion/Po and Pb batteries.
• Compact & portable size
• Cycling (Charge to Discharge / Discharge to Charge)
• 2 line, 16 character blue backlit LCD Screen
• Button control - “Surface panel type”
• Warning sytems prevents improper voltage
• Super durable aluminum case
Old 12-07-2006, 03:21 PM   #10
Trader Rating: 44 (100%+)
i believe the cellmaster's "lipo profile" current is not high enough to charge most lipos?
YOKObori MOkei
wyl03 is offline   Reply With Quote
Old 12-07-2006, 03:31 PM   #11
Send a message via Yahoo to LaxRacer
I was wondering can older integy chargers be sent in for an update ? say a 6x7v5 ?
LaxRacer is offline   Reply With Quote
Old 12-07-2006, 03:57 PM   #12
LasagnaCat's Avatar
Trader Rating: 143 (100%+)
Send a message via AIM to LasagnaCat
That's correct... the Cell Master has a 1 amp lipo charge limit. It's okay to charge lipo tx/rx packs or some micro packs, but that's about it. Couple that with how loud they are (not a performance issue.. just annoying) and it's a pretty poor lipo charger but is great for nimh packs. We've been using the Orion Avionics Advanced Flight Charger mentioned above with good results. I haven't used it with nimh packs so I can't comment on how capable it is in those regards, but it's been great with the lipo's. The only drawback with that specific Orion charger is that it has a five amp charge limit. If you stick with recommended charge ratings it's good for most lipo packs out there... if you're ever in a hurry to charge a pack or are one of the people that charge over the 1C limit for packs like the Orion 4800's you'll be SOL. It's small, quiet, does most things you'll need a lipo charger to do, and the price is right. Doesn't have the balancing feature mentioned in the original post, however. Also doesn't have charge profiles, but it's not difficult to change the charge rate manually and for the price it's still a good value.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 12-07-2006, 04:58 PM   #13
Jochim_18's Avatar
Thanks guys for all the info....
Old 12-07-2006, 05:04 PM   #14
rampal's Avatar
that's why I said "exactly" but thank you for clarifying my doubt. Nevertheless, the menus look pretty much the same....
Old 12-07-2006, 06:37 PM   #15
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
FMA Cell Pro
$60
I have the FMA Cell Pro and I am really happy with it.
Just an FYI, they also have this charger: Scorpion 2s Charger
Royal Rumble Racing
minicooper is offline   Reply With Quote
Hyperion Lipo Charger and (2) 3s Lipo Batteries RcOneNitro R/C Items: Wanted to Buy 4 05-23-2017 12:09 AM
JRXS GTB 4300 13.5 lipo charger lipo AMB joaquinriviera R/C Items: For Sale/Trade 22 09-12-2008 01:43 PM
LIPO CHARGER LIKE HYPERION AND LIPO BATTS AND MAYBE CHEAP 12TH SCALE jslider R/C Items: Wanted to Buy 1 02-16-2008 07:55 AM
wtb orion 3600 lipo and a lipo charger nikkon R/C Items: Wanted to Buy 13 02-13-2008 10:43 AM
Lipo charger with power supply and 2 cell lipo pack fweemindan R/C Items: For Sale/Trade 3 01-03-2007 11:51 PM
