Old 12-06-2006, 05:54 PM   #1
Default T2 ride height question
i cant get the front down far enough using the spring preloads, i got the car used and i dont think i received the eccentric suspension holders.......could this be affecting the height????
DotyThe8ight is offline   Reply With Quote
Old 12-06-2006, 06:54 PM   #2
Trader Rating: 18 (100%+)
The suspension holders are for roll center and anitdive etcetera. You should be able to get the proper ride height with either set. What height are you trying to get. And what springs are you using.
trilerian is offline   Reply With Quote
Old 12-06-2006, 06:58 PM   #3
Jerry P's Avatar
Trader Rating: 44 (100%+)
I'm having a similar issue. I setup the car with the basic foam tire setup. I have light blue springs up front. I got the ride height down to 4.75 mm but that was with the collar all the way up. I was shooting for 4.5 mm. The shock is setup in the inside hole per the setup sheet and the 3 hole on the shock tower.
Jerry P is offline   Reply With Quote
Old 12-06-2006, 07:02 PM   #4
What is your tire diameter? I always cut my tire to 58mm to start. I have never had a problem with ride height all the way to 4mm.
Old 12-06-2006, 07:15 PM   #5
stiltskin's Avatar
Trader Rating: 102 (100%+)
Make sure that the ball ends are screwed all the way onto the shock shaft. I think the book tells you to leave 1mm of threads. Also check to make sure you are using the correct ends. The kit came with two types and one of them two is longer than the other. If you have the long ones on, it will prevent you from running lower ride height.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 12-06-2006, 07:21 PM   #6
justin lessard's Avatar
Send a message via AIM to justin lessard
If you use associated spring cups you will be able to achieve whatever ride height you want to
justin lessard is offline   Reply With Quote
Old 12-06-2006, 08:32 PM   #7
Chris08527's Avatar
Trader Rating: 16 (100%+)
you could also order the team tamale spring retainers also to get the ride height you are looking for
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 12-06-2006, 09:29 PM   #8
Also make sure your spring cups are seated all the way on you ball ends.
RickD is offline   Reply With Quote
Old 12-06-2006, 09:59 PM   #9
Impulse_racer's Avatar
I had the same problem. If you look inside the shock retainers you will see a ridge. This ridge keeps the retainer from going but so far down on the ball ends. If you drill out the hole it will allow the retainer to seat lower on the ball end allowing lower ride height adjustments.
Xray T3 EU
KO Propo Helios
Tekin RS Pro/LRP X-12/Venom LiPo
Hudy
Litemodz CVS
Impulse_racer is offline   Reply With Quote
Old 12-06-2006, 10:42 PM   #10
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
perhaps droop screws are set so as not to allow the chassis to sit down enough?
Old 12-06-2006, 11:02 PM   #11
ottoman's Avatar
R/C Tech Charter Subscriber
You have the wrong lower shock mounts. The T2 uses short ends that are included separately in the kit... the ones on the shock parts tree are too long (05 style) and you cant get the car low enough. Some one just used the wrong ends
Just ran into this a few weeks ago with a guy at the track... easy fix.
ottoman is offline   Reply With Quote
Old 12-07-2006, 08:10 AM   #12
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
Xray springs are shorter than others. If you aren't using them, that's your problem.
RC America - Xray - Hudy - Gravity RC - KO Propo - Super Rad Graphics
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
F. Mendoza is offline   Reply With Quote
Old 12-07-2006, 08:15 AM   #13
pretty sure it was a droop problem, thanks for all the tips guys they helped a bunch!!!
Old 12-07-2006, 08:21 AM   #14
stiltskin's Avatar
Droop screws will not prevent you from lowering your ride height. They will prevent you from raising it.
Tony Rumple
Old 12-07-2006, 10:55 AM   #15
oops! Youre right. I misread his problem.
question about ride height thahookup Rookie Zone 11 02-18-2007 04:05 PM
Tweak and ride height question. RandomTask Electric On-Road 9 06-12-2006 10:27 AM
ride height question wild gopher Electric Off-Road 1 04-12-2004 11:35 PM
hyper 7 PBS ride height question.. neopumpkin Electric Off-Road 3 04-09-2003 10:12 PM
Tmaiya Ferrari Enzo Ride height question yoshi Rookie Zone 10 02-23-2003 02:05 AM
