Old 01-07-2008, 09:44 PM   #1471
Trader Rating: 26 (100%+)
i never used ca on side walls,i ran -2 frt and rear camber 33lb frt springs and 22lb rear
eddie10 is offline   Reply With Quote
Old 01-07-2008, 10:04 PM   #1472
stiltskin's Avatar
Trader Rating: 102 (100%+)
Originally Posted by JamesArluck View Post
TAM53573
Thanks James.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-07-2008, 10:06 PM   #1473
eddie- Well, maybe Mike can chime in about what he does with CA on the tires. It can make a significant difference on front end bite (and rear, to a lesser extent), keeping the outside edge of the tire from rolling over and digging into the carpet and creating excess grip. This is ESPECIALLY important if your carpet is high bite. I suspect this is the biggest contributor to your problem, but there may be other factors.
Tire diameter is also important- the bigger the tire the more tendency to roll. Don't know what Mike ran for tire size. Plus Mike had custom holes in his shock pistons, affecting the weight transfer characteristics in corners. If you didn't drill your shock piston holes to 1.2 mm then you had something different than Mike. Look over his setup sheet and see if there are any other deviations.
The more information you can post about your setup AND traction conditions the more meaningful advice the forum can offer.
Larry Brown is offline   Reply With Quote
Old 01-08-2008, 12:43 AM   #1474
stuey's Avatar
or it could be down to driving style maybe you throw the car into the apex harder than mike upsetting the ballance
stuey is offline   Reply With Quote
Old 01-08-2008, 04:07 AM   #1475
guinnes.s's Avatar
hello,what the different numbers on the wishbones stand for?the stock are 35 but i got some 75 as spares.what is the difference?
thanx
Salvo
guinnes.s is offline   Reply With Quote
Old 01-08-2008, 05:01 AM   #1476
stuey's Avatar
thanx
Salvo
stiffness
5 shore soft
35 shore med
80 shore hard
Old 01-08-2008, 05:42 AM   #1477
guinnes.s's Avatar
do you guys find the 35 one very easy to brake in compare to the hardest one?
i am keeping breaking them at any slight impact on the front wheels ,and one of the upright did broke in three pieces too,is getting very annoying,
thank you
Salvo
Old 01-08-2008, 05:49 AM   #1478
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
ahhhhhhh props to Blackstock!
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 01-08-2008, 05:50 AM   #1479
stuey's Avatar
to be honest ive only eve broke 1 35 shore wishbone and that only happend cos a piese of the box section used to lay the track was sticking out at the end of the main straight.
Old 01-08-2008, 06:44 AM   #1480
Trader Rating: 25 (100%+)
Default lipo
Can anyone advise what Lipo packs fit in the Phi car?
fred kellner is offline   Reply With Quote
Old 01-08-2008, 06:47 AM   #1481
stiltskin's Avatar
Pg 48 of this thread shows my car with the Orion 3600 installed. I sanded the chassis so that my NRG cells fit flush and the Orion dropped right in.
Tony Rumple
Old 01-08-2008, 06:48 AM   #1482
stiltskin's Avatar
I have the Euro kit if that helps also.
Tony Rumple
Old 01-08-2008, 06:57 AM   #1483
guinnes.s's Avatar
i am at the forth wishbone,nearly a wishbone for every race i been to and the impacts are so ridiculously no hard at all that it start getting on my nerve.
will try the 75 one
if no luck will stick it on ebay
Old 01-08-2008, 07:06 AM   #1484
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
thank you
Salvo
Do you have the superhard bumper and kydex? It seems to be a must for every car.
Dustin Layne
smoke81 is offline   Reply With Quote
Old 01-08-2008, 07:19 AM   #1485
Budman's Avatar
Trader Rating: 22 (100%+)
The bumper would be the first thing to do. If you are going to change arms you need to go with the softer 5% arms. That will give you more flex and less braking. It will also give you more steering.
Cooper Motorsports, Team Trinity, T-Rex Racing, GFRP, MSA, VBC Racing, Track Attack, Tekin and Frost-bite Graphics
Budman is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
