Old 01-06-2008, 09:06 PM   #1456
timmay70's Avatar
Originally Posted by BigDaddyT View Post
Hey Guys,
Myself and another one of our drivers seem to be extremely unlucky with the stock steering blocks on carpet. We're just looking to do the right upgrades.
Are most of you running the aluminum knuckles and Specialized bumpers? Are there other solutions we should be aware of (aside from not crashing ).
Thanks.
T
I use the aluminum knuckles with the bushings, the bearings are so small that they aren't worth it. It will only take a couple of crashes, and the bearings will turn to bits. I also don't think that the bearings add anything to the chassis in terms of performance; how often do you wish that your steering was that little bit free-er? I'd also make the investment in the aluminum knuckles for another reason, if the plastic ones break, a lot of times they have the nasty habit of taking out other parts with them. Definitely worth the added cost.
The specialized bumper is definitely worth it's weight in gold. I hardly ever pile drive a corner. I am more the type that will graze apexes. Therefore, the kydex is only deflecting the blow. It takes quite a few impacts for me to put a permanent bend into the kydex. If you like to (or not) pile drive boards, well, you may have other problems that a kydex bumper cannot solve.
good luck.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 01-07-2008, 11:35 AM   #1457
RCFREAK's Avatar
Trader Rating: 17 (100%+)
Josh H!! great finish at Novak!!
Anything different on your setup since you posted it last here??
THANKS!!
RCFREAK is offline   Reply With Quote
Old 01-07-2008, 03:00 PM   #1458
Trader Rating: 1 (67%+)
THANKS!!
Thanks rcfreak
I did change some stuff on my front end because of the very high traction. I'll try to get a setup sheet done in the next few days and have Jeff post it on the site when he gets a chance
Josh Hohnstein is offline   Reply With Quote
Old 01-07-2008, 03:09 PM   #1459
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Josh is awesome. I don't care what Brian said about you sir. Nice run.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 01-07-2008, 03:22 PM   #1460
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
back off, I claim josh as my own, not sharing boys...
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 01-07-2008, 03:27 PM   #1461
I would love to join in on all the man love talk............but after sitting next to Brad for a week i'm all burned out
Old 01-07-2008, 03:29 PM   #1462
I see where we rank compared to Brad now
Old 01-07-2008, 04:04 PM   #1463
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
You have such perfect bedside manners.
Nice job by the way.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-07-2008, 05:39 PM   #1464
stiltskin's Avatar
Trader Rating: 102 (100%+)
Anyone have a part number for the tamiya 3 hole piston? Anyone have them in stock? Thanks.
(Now back to your bedroom talk)
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-07-2008, 06:01 PM   #1465
tcian's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to tcian
try superior hobbies they norally have them
tcian is offline   Reply With Quote
Old 01-07-2008, 06:03 PM   #1466
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
TAM53573
JamesArluck is offline   Reply With Quote
Old 01-07-2008, 09:03 PM   #1467
mtbboy's Avatar
Originally Posted by eddie10 View Post
i tried running blackstocks setup today with dbl pinks on all four corners.i found on corners the inside wheel would lift.i tried no compound and it was still lifting,but the steering was awesome.is there anything you can do to prevent this,i would still love to run dbl pinks all around but the lifting and odd traction roll doesnt make sense.can i hear everyons opinion. thanks!!!
any one care to answer this post for this gentleman please?
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 01-07-2008, 09:09 PM   #1468
lifting the front, rear, or both inside tires?
Old 01-07-2008, 09:21 PM   #1469
Trader Rating: 26 (100%+)
frt and rear,but more in the frt
eddie10 is offline   Reply With Quote
Old 01-07-2008, 09:35 PM   #1470
eddie- Did you use CA on the sidewalls of the tires? Did you run as much camber as Mike did? Also, I know Mike said the traction was high, but it was not as high as traction can be on older style carpet. If you are running on really high bite carpet you need to adjust for the higher traction with less front dope, higher spring rate, etc.
Larry Brown is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
