Old 12-31-2007, 10:22 AM   #1396
Originally Posted by 29TC View Post
Hey guys need advice.
What adjustments do you usually do to get more steering entering a corner?
My phi handles great on sweeping turns and chicanes. Mid and exit steering is great. But on high speed straights into a hairpin, i need to really slow the car down to make tight turns. I always get over taken or knocked from behind at that point.
Any tips on getting more initial steering and a better tighter turning radius?
By the way, my setup is stock(EU spec kit) with front ball differential.
I'm having the same problem. The first time I ran the car it was great then the next week...same car, same setup, same track, the car pushed like a dump truck. The only difference was the traction was a little less after the rains. It went from a 9 on a 1 to 10 scale to about a 7.5 which is still good. Here's my setup;
FRONT:
spool
stock castor blocks
2 degree toe out
40 wt AE stock pistons (1.3)
arms back
5 droop
HPI yellow springs
inside hole on steering knuckle
coupler up front/down rear
cambler link low short (I also tried high mid as well)
REAR:
stock toe
arms mid
4 droop
HPI pink springs
coupler up/up
camber link low short
shocks both mounted one in from outside
ride height 5mm all around
the rear also want s to come around a little on power. I tried flipping the rear coupler to give some anti squat but that didn't do anything.
Any help would be appreciated.
DOTMAN is offline   Reply With Quote
Old 12-31-2007, 10:36 AM   #1397
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
FRONT:
spool
stock castor blocks
2 degree toe out
arms back
5 droop
HPI yellow springs
REAR:
stock toe
arms mid
4 droop
HPI pink springs
coupler up/up
like Bowser said try TJ's set up it works really well or Jeff Brown's set up either one are really good
Old 12-31-2007, 11:31 AM   #1398
Send a message via MSN to _RDX_
Have raced my Phi since August now. Must say that its the best car i have ever had! Finally got some spare time over, so i could take some pics and here they are! Feel free to comment
Team Corally RDX Phi-dsc01505.jpg   Team Corally RDX Phi-dsc01504.jpg   Team Corally RDX Phi-dsc01503.jpg   Team Corally RDX Phi-dsc01501.jpg
_RDX_ is offline   Reply With Quote
Old 12-31-2007, 11:35 AM   #1399
syndr0me's Avatar
Trader Rating: 32 (100%+)
The dramatic lighting makes it look fast!
I'd also like to request that you don't sell smoke81 a Phi, he's too hard to shake already. Thanks.
syndr0me is offline   Reply With Quote
Old 12-31-2007, 12:32 PM   #1400
Is that the Tamiya setup or the base asphalt setup?
Old 12-31-2007, 12:35 PM   #1401
Super Moderator
Marcos.J's Avatar
Actually i ran the tamiya set up and it was really good, im going to try their base set up sunday.
Old 12-31-2007, 12:40 PM   #1402
question, under camber it lists two values...does that mean -1 on one side and -1.5 on the other?
Old 12-31-2007, 12:41 PM   #1403
Super Moderator
Marcos.J's Avatar
Yes but i ran -1.5 on both sides on my car.
Old 12-31-2007, 12:44 PM   #1404
that's interesting...is that because Tamiya has the hard left sweeper or does that have something to do with the car?
Old 12-31-2007, 12:52 PM   #1405
Super Moderator
Marcos.J's Avatar
probably just the track
Old 12-31-2007, 12:55 PM   #1406
Thanks, I'll test it out this weekend.
Old 12-31-2007, 01:03 PM   #1407
imprsme's Avatar
Trader Rating: 74 (99%+)
I ran a similar set up to the Tamiya one all summer...WOW! The car was a dream and was fun to drive. The more power I put in it the better it got.
The car was so good. When the season was up and we went indoors to carpet I took the car right off the track backed the droop screws out and backed the shock collors up and put it in a box for next season!!!
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 12-31-2007, 02:06 PM   #1408
Super Moderator
Marcos.J's Avatar
Same here i have Jeff's Tamiya set up with just a few changes and the car is really good.
Old 12-31-2007, 03:02 PM   #1409
just curious...what changes did you make, Marcos?
Old 12-31-2007, 03:22 PM   #1410
Super Moderator
Marcos.J's Avatar
from jeff's tamiya set up i changed the following:
front:
dropped to 30 wt oil and went to 2 hole pistons
front coupler down
no front or rear coupler shims
clamp shims 1mm
Rear:
dropped to 30 wt oil and 2 hole pistons
no front coupler shim
and moved the camber link in the middle top on the shock tower
i made these changes and it worked for me
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
