Old 12-28-2007, 07:24 AM   #1381
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
Hmm so I assume the EU version has the standard length shocks that were on the RDX? If so I'd just need to get shock towers and use a set of shocks from my current car... So I think i'll buy the US version with a extra one way and shock towers if I want to run some rubber...
Thanks for the help.
Dustin Layne
smoke81 is offline   Reply With Quote
Old 12-28-2007, 08:55 AM   #1382
Trader Rating: 1 (67%+)
Don't forget the castor blocks.......and unless you run on very high bite you will want the thinner chassis
Josh Hohnstein is offline   Reply With Quote
Old 12-28-2007, 09:30 AM   #1383
Kenny L's Avatar
Trader Rating: 16 (100%+)
I'm looking to start rubber tire car myself was wondering a couple of things. What setup,body,and are people running full shorter car like with short belt & clamp moved forward?
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 12-28-2007, 10:04 AM   #1384
Dave Bowser's Avatar
Trader Rating: 51 (100%+)
i would start with TJ's set up on the Corally site as far as bodies go i would use the Protoform Mazda 6 or speed 6
RCAmerica, X-Ray, Hudy, Ko Propo, Protoform, PRS, Jaco, JConcepts, SXT, RC3 Grafix, Kool-Aid, P-Nut, NEXT, www.SuperiorHobbies.com
We're going to skate to one song and one song only!
Dave Bowser is offline   Reply With Quote
Old 12-28-2007, 10:23 AM   #1385
carpet or asphalt??????
Old 12-28-2007, 10:27 AM   #1386
Kenny L's Avatar
Carpet
Old 12-28-2007, 10:33 AM   #1387
just the standard short....not full short with belt and pully change.
Rob's setup on corallys site is a good place to start. Some changes to his setup that I feel improved laptimes are no sway bars, 19 lb front spring in the outer hole on arm, low roll center in the front (low-med bite).
bodies are mazda6 or speed 6
Old 12-28-2007, 11:06 AM   #1388
tcian's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to tcian
Originally Posted by Victor Vector View Post
Once again please, in Engrish !!
jacko
ok first u take the trust assembly out and rebuild the diff rings,balls,etc, next instead of putting the trust rings and balls in and the berring at the bottom, 1/4 x 3/8 flanged same as a 1/12 rear bearing in the bottom instead of the stock one, then u take 1/12 rear axel shims and spce it out like 2 or 3 of the shims put it in and break it in and ull be good, i like the feel of it but we run it in brushless, i did a test with it with a co27 it did bring me down like a tenth or so but not much if u have anyother q'
s feel free to ask
tcian is offline   Reply With Quote
Old 12-28-2007, 03:10 PM   #1389
smoke81's Avatar
We'll be running on fairly good traction (gets pretty high if we spray), but I don't think the thicker chassis will kill me to much.. I've actually been running the 4mm chassis on my rdx for rubber tires for awhile, and liked it over the thinner chassis. Not sure if I like the fact it doesn't tweak as often or how it handles
Dustin Layne
Old 12-31-2007, 03:49 AM   #1390
29TC's Avatar
Send a message via ICQ to 29TC
Hey guys need advice.
What adjustments do you usually do to get more steering entering a corner?
My phi handles great on sweeping turns and chicanes. Mid and exit steering is great. But on high speed straights into a hairpin, i need to really slow the car down to make tight turns. I always get over taken or knocked from behind at that point.
Any tips on getting more initial steering and a better tighter turning radius?
By the way, my setup is stock(EU spec kit) with front ball differential.
29TC is offline   Reply With Quote
Old 12-31-2007, 04:59 AM   #1391
stuey's Avatar
spool
stuey is offline   Reply With Quote
Old 12-31-2007, 05:04 AM   #1392
Losi Motor Man's Avatar
Send a message via AIM to Losi Motor Man Send a message via MSN to Losi Motor Man Send a message via Yahoo to Losi Motor Man
I totally agree Spool is the way to go. If your looking for that Hot off the straight Turn in it gives the car more bite into the turn .
Losi Motor Man ( [email protected] )
Carpet Is For Vacuums, Dirt is For Men ! ! !
"When you can leave black marks and smoke from the entrance of one turn to the exit of another then you might just have enough power ! "
http://www.armbell.com/losimotoraman/
Losi Motor Man is offline   Reply With Quote
Old 12-31-2007, 05:14 AM   #1393
Difference Between a Spool and a Limmited Slip Diff:
Spool:
A spool limits differential rotation to exactly zero. A spool consists of a pinion & ring gear only, the centre is solid, the axle is one piece. A mini-spool is similar, replacing the usual differential centre with a solid piece, retaining the factory axles. Technically a spool is not a differential at all, but is used to achieve a similar effect to an LSD on some street & race cars
A limited slip differential (LSD):
is a modified or derived type of differential gear arrangement that allows for some difference in rotational velocity of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an automobile, such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity.
The main advantage of a limited slip differential is found by considering the case of a standard (or "open") differential where one wheel has no contact with the ground at all. In such a case, the contacting wheel will remain stationary, and the non-contacting wheel will rotate freely– the torque transmitted will be equal at both wheels, but will not exceed the threshold of torque needed to move the vehicle, thus the vehicle will remain stationary. In everyday use on typical roads, such a situation is very unlikely, and so a normal differential suffices. For more demanding use however, such as driving off-road, or for high performance vehicles, such a state of affairs is undesirable, and the LSD can be employed to deal with it. By limiting the velocity difference between a pair of driven wheels, useful torque can be transmitted as long as there is some friction available on at least one of the wheels
Hope this helps the new guys that do not understand the diffrence in the two.
Old 12-31-2007, 06:04 AM   #1394
ooliganRC's Avatar
Send a message via MSN to ooliganRC
Personally i would have used a one way for more entry corner steering,
Corally RDX PHi, Novak Brushless, Futaba 3GR, KO Propo 2413, E-Power 4500, Full Throttle Motorsports.
"You aint going fast enough, if you aint Full Throttle"
Currently slow due to : Bad thumbs and no motors :P
ooliganRC is offline   Reply With Quote
Old 12-31-2007, 09:37 AM   #1395
stuey's Avatar
hey pete
have you used the car on carpet yet as you have seen a spool is by far the best option in the corally to be honest bud i think ive forgot how to take it out
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
