Old 12-12-2007, 06:04 AM   #1276
Dave Bowser's Avatar
Trader Rating: 51 (100%+)
whats up Bill these guys are shimming the bulkheads up .5 of a mm so the batteries fit better
to get a 4800-5000 lipo to fit you would have to shim the bulkheads up at least 4mm maybe more witch would throw everything way out of whack
RCAmerica, X-Ray, Hudy, Ko Propo, Protoform, PRS, Jaco, JConcepts, SXT, RC3 Grafix, Kool-Aid, P-Nut, NEXT, www.SuperiorHobbies.com
We're going to skate to one song and one song only!
Dave Bowser is offline   Reply With Quote
Old 12-12-2007, 07:51 AM   #1277
Still Bill's Avatar
Originally Posted by trf415ms View Post
I am trying to find an online shop/shops who are stocking the PHi? Mainly looking @ US/Asia areas.
Call Jeff Brown at Corally USA to check status on next shipment. You didn't say if you are looking for EU or US version.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 12-13-2007, 08:13 PM   #1278
anybody ever try not running the o rings in the diff?
Old 12-13-2007, 08:17 PM   #1279
Send a message via AIM to goop
yes actually the o rings can cause high spots in the biff i personally think that the diffs build super smooth without the o rings i know a lot of peaole that dont run them
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 12-13-2007, 08:43 PM   #1280
cool thanks goop i kinda felt the same way
Old 12-13-2007, 09:00 PM   #1281
Still Bill's Avatar
Hi goop,
Without the o-rings, do you get a certain number of runs before having to service the diff?
Thanks.
Bill
Old 12-13-2007, 09:07 PM   #1282
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
I initially built the diffs with the o-rings. My first try I ended up with a high spot in one, but after rebuilding it, that went away. When I rebuilt the diffs for the first time after a couple weekends of racing, I took the o-rings out. I built fresh diffs the first practice day at the Cleveland Indoor Champs, and only had to freshen up the front one near the end of the weekend. This was running both stock and 19t foam. I haven't seen increased degradation when not using the o-rings, and the diffs are very smooth.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 12-13-2007, 09:31 PM   #1283
Still Bill's Avatar
Thanks guys!
I will give it a shot.
Old 12-13-2007, 11:15 PM   #1284
Trader Rating: 8 (90%+)
I've been running the orings and havent had any problems with high spots, thats with running stock and 19t foam. I'll have to try it soon though.
Johnny Carey is online now   Reply With Quote
Old 12-14-2007, 01:06 PM   #1285
stiltskin's Avatar
Trader Rating: 102 (100%+)
I'm a little confused on all these optional belts. If I want to stick with the 42t pulleys and run the shortened wheelbase, what optional parts do I need to get?
BTW Corally. Beautiful car.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 12-14-2007, 02:53 PM   #1286
man we gave johnny the fast secret
Team Trinity
Old 12-14-2007, 08:57 PM   #1287
BJohnson's Avatar
Stilskin - If you look at the chart in the back of the manual, it breaks down the different size belts needed for the different final drives as well as for the different wheel bases. You might have to change your final drive in order to shorten the wheel base. You might also need the different diff cams that are centered in order to achieve the correct cvd angle. I hope this helps.
Thanks - Brad
BJohnson is offline   Reply With Quote
Old 12-14-2007, 09:24 PM   #1288
Still Bill's Avatar
Default Ohhhhhhh Juan
Juan,
I am looking at your setup sheet for this year's Reedy Race and cannot figure out one thing.
How did you get an overall 1.5 degree rear toe-in using only a .5 degree shim on the rear coupler? I could understand it if the .5 shim was on the front coupler (being 2.0 degrees minus .5 degrees).
Thanks amigo.
Old 12-14-2007, 09:30 PM   #1289
stiltskin's Avatar
Thanks - Brad
Actually, knowing that there is another diff cam just makes it more confusing. At the same time, I just learned something else about the car. This thing is awesome. No need to replace the car every year when you already have this much adjustability. Thanks for the info.
Tony Rumple
Old 12-15-2007, 12:43 AM   #1290
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
