Old 01-14-2007, 06:55 AM   #106
Trader Rating: 8 (90%+)
You would need all of the C/F, the bulkheads, the bulkheads for the couplers, and i think the layshaft. The diffs are just updated.
Johnny Carey is offline   Reply With Quote
Old 01-14-2007, 10:29 AM   #107
From the RCZONE DHI cup report
We've had a closer look at the Corally PHi prototype which is in action here at the DHI Cup, Marc Fischer, Jonas Kaerup, Federico Sala, Simo and Sakke Ahoniemi all drive the PHi, the latest touring car coming from Corally and to be released in early 2007. The car featured on the pictures is the prototype, the final version will be a bit different, parts will of course be refined. Noticeably different will be the rear to in blocks, the prototype uses shims, same as seen on the old car, whereas the final version will use blocks in different sizes, it will make it simpler and of course stronger as well. Working on the final version will be considerably easier, the prototype features many parts which are screwed together, these parts will be made in one piece.
The dampers will be all new in order to fit the lower shock towers, the shocks will be specifically designed for this changed setup and lower cg. The steering system will feature a larger possibilty for adjustments to the ackermann. Looking towards the rear of the car, a new differential which is a bit similar to what we know from 1/12 scale where 3 ball bearings are used, gone is the pain of working on setting up a traditional touring car type differential. The spool will be a new type as well and the ball bearings used for the spool and differential will have the same size, no need for changing any longer, loosen two screws and cange, that's it. The prototype features a permanent internal gearing, like all other touring cars, but the final version will incorporate the possibility of changing internal gearing to suit the different needs of racing types, ie modified benefits from one whereas spec and stock classes from others. There's a lot of new features built in to the new PHi, it's not just a revamp of the old version, but an evolution
It sounds like more parts are new then it appears in the photos.
Peter
http://www.rczone.net/modules.php?na...rticle&sid=777
Pedro 51 is offline   Reply With Quote
Old 01-14-2007, 03:01 PM   #108
rc-car-net's Avatar
Send a message via ICQ to rc-car-net Send a message via MSN to rc-car-net
i've got some pix too (from training in austria)
http://www.rc-car-net.at/gallery_ima...6/IMG_0441.jpg
http://www.rc-car-net.at/gallery_ima...6/IMG_0442.jpg
http://www.rc-car-net.at/gallery_ima...6/IMG_0443.jpg
http://www.rc-car-net.at/gallery_ima...6/IMG_0444.jpg
http://www.rc-car-net.at/gallery_ima...6/IMG_0445.jpg
[SIZE="1"][URL="http://www.Rc-Car-Net.at"][COLOR=RoyalBlue]Rc-Car-Net[/COLOR][/URL] [COLOR=Cyan]-=-[/COLOR] [URL=http://www.RC-FORUM.at][COLOR=RoyalBlue]RC-Forum.at[/COLOR][/URL] [COLOR=Cyan]-=- [/COLOR] [URL=http://www.racing-cars.com][COLOR=RoyalBlue]Schumacher USA[/COLOR][/URL] [COLOR=Cyan]-=- [/COLOR] [URL=http://www.fantomracing.com][COLOR=RoyalBlue]Fantom Racing[/COLOR][/URL]
:tire::sneaky:[/size][size="2"] ................................. :sneaky::tire:
:sneaky::tire:[URL=http://www.summerchamps.de][COLOR="DarkOrange"]GERMANY Summer Champs[/COLOR][/URL][/SIZE]:tire::sneaky:
:tire::sneaky: ................................. :sneaky::tire:
rc-car-net is offline   Reply With Quote
Old 01-14-2007, 03:13 PM   #109
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
That is an old RDX, not the Phi.
Kave is offline   Reply With Quote
Old 01-14-2007, 05:05 PM   #110
syndr0me's Avatar
Trader Rating: 32 (100%+)
Yea, old RDX with the newest chassis, topdeck and stiffening plate. That appears to be the same chassis the Phi is using.
syndr0me is offline   Reply With Quote
Old 01-15-2007, 12:21 AM   #111
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
there is no way that the phi can be using the same chassis... the bulkheads are way closer together where it sandwiches the diffs and the roll center blocks mount different.
lets hope the new car has some beefy suspension arms or something that can take a lil tap
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 01-15-2007, 01:01 AM   #112
syndr0me's Avatar
It's almost definitely the "2006 Competition Spec" chassis that was released for the RDX (w/stiffening plate) that's been drilled for the new bulkheads. You can tell by looking at it. You can see the stiffening plate mounted on it in some of the prototype pictures.
Pretty sure the car is going to use the "updated" arms. I mean I guess they could come up with new arms, but they just spent all that time getting the updated ones right. The prototype car appears to be using production updated arms from the existing RDX.
Old 01-15-2007, 01:11 AM   #113
syndr0me's Avatar
It definitely looks like they're still doing some development on the car. The top deck in the latest pictures of the car is changed from the older prototype pictures. I can't tell if it's the same length or not, but definitely a different shape. I'd be surprised if this car came to market as soon as they're saying, it sure seems like they're still doing a lot of testing. The fact that they haven't released any official product shots leads me to the same conclusion. It's an impressive looking car.
Old 01-15-2007, 01:33 AM   #114
it is a great looking car but thearms in my opinion are in desperate need of change! that is just my opinion
Old 01-15-2007, 02:49 AM   #115
They have always had alloy arms as an option if you want something that won't break, if you are hitting things hard enough to bend the alloy ones I suggest no arms are going to suit your driving style.
Cheers
Peter
Old 01-15-2007, 09:00 AM   #116
Send a message via MSN to _RDX_
Found some pics on the internet!
The new car looks awsome, it look like sit works nice to, 6 and 10 at DHI-cup!
/Daniel
Team Corally RDX Phi-co1.jpg   Team Corally RDX Phi-img45ab717ce3d16.jpg   Team Corally RDX Phi-img45ab7162e3d0b.jpg   Team Corally RDX Phi-img45ab71941b9f1.jpg
| Corally RDX Phi'09 | Sanwa M11 | Nosram |
_RDX_ is offline   Reply With Quote
Old 01-15-2007, 12:28 PM   #117
Cheers
Peter
i havent been braking to many arms but when i do give the pipes a tiny tap they just explode into pieces...
Old 01-15-2007, 03:39 PM   #118
raffaelli's Avatar
/Daniel
It doesn't look like the roll center blocks are easy to get to?
24ITA
raffaelli is offline   Reply With Quote
Old 01-15-2007, 04:11 PM   #119
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
is this an adjustable layshaft?
http://www.rctech.net/forum/attachme...hmentid=195193
Old 01-15-2007, 05:58 PM   #120
syndr0me's Avatar
They mount to a separate piece that screws into the chassis, from underneath, not directly into the bulkheads.
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
