Old 10-31-2007, 05:22 PM   #1036
Trader Rating: 26 (100%+)
on a med bite smooth carpet track,what shock pistons and oil is a good starting point and with the new prism jacos is it still common to run dbl pink on all 4 corners. thanks let me hear everyones comments
eddie10 is offline   Reply With Quote
Old 10-31-2007, 09:15 PM   #1037
Korey Harbke's Avatar
Not sure if anyone noticed, but Jeff updated the website with Chris Tosolini's Mod Foam IIC setup and Robbie's Carpet Rubber setup! Also a godo race report of the IIC
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 10-31-2007, 09:25 PM   #1038
RBLove's Avatar
Trader Rating: 72 (100%+)
Originally Posted by Mike Blackstock View Post
Hi all.. It is awesome to see how the PHI is doing so great on the track... I am going to try and get on here every couple of days and do my best to help out anyone who might have any questions regarding the car... I will do my best ...
So if there are any questions ask away....
The diff issue is a known issue and hopefully they have fixed it with the new parts you have seen on here...
Mike Blackstock
I McLove Mike Blackstock
RBLove is offline   Reply With Quote
Old 11-01-2007, 08:29 AM   #1039
eddie10... Not sure if you are running mod or 19t or stock.. But here are some suggestions....
For Stock most everyone is running between 50-70 wt in the front with either a 1.1mm or 1.2mm 3 hole or 2 hole piston. And 20-40 in the rear.. Depending how much you want the car to dump onto the front end the lower you go in the rear but watch out it get's very steery... i would start at 60-30 and go from there...
Modified and maybe 19turn... I currently am running a 50 wt front with 2 hole 1.1mm piston and 40 wt 3 hole 1.1mm piston in modified... This has been good but i would like to play with heavier dampening and bigger hole pistons and see what that do's...
As for Tires.. Yes we are still using the same tires front and rear.. Right now with Jaco's new line of tires the best combination for me is Pinks all the way around. But stock you might want to try dbl pink, Megenta or pinks and see wich one suites you
Hope this helps..
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 11-01-2007, 08:37 AM   #1040
tbeardmore's Avatar
I will be experimenting with installing a "Set Screw" In the side of my diff nuts to see how it works....... hmmm--might work?
I'll keep you all posted as to the results
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 11-01-2007, 08:44 AM   #1041
Default Mod Setup...
I have had quite a few pm's for a mod setup to be posted on here .. So instead of sending out pm's i will post my current mod setup on here that i used in Vegas and The Holloween race..
Front....
Small pulleys for the 1.71 ratio..
Short wheel base in front and rear..
Front shocks oil 50wt 1.1mm 2 hole piston or tamiya
Front shock spring 33 pound front spring
Front shock position on the tower... 1 Hole in
Front camber link ... Down and short
Caster 6 degree's caster
Front hinge pin height 8mm up from chassis
Front Camber -1.8 deg
Front wishbone or Arm . CF5
Shock on arm inner hole
Front track width 188mm
Ride height 4.5 mm
Droop 1.5mm above ride height
Rear Shock oil 40 wt 3 hole 1.1 mm or tamiya
Rear Spring 19 pound.
Rear Shock position 1 hole in from top ..
Rear shock on arm is outside hole
Rear Arms are 80%CF
Rear Camber link low and short on tower with specialized rc rear hubs with 1.5mm under ball stud..
Rear Toe 2 degrees.. shim according.
Camber 3 degree
Ride height 5mm
Hinge pin height is 8.0mm from chassis up measure in the middle of the pin..
Top deck is a 2.9 mm thick
Jaco Pinks all the way around cut to 56.8mm
If there is anything i left out please ask...
Mike Blackstock
Old 11-01-2007, 02:42 PM   #1042
Thanks Mike!
Old 11-01-2007, 03:12 PM   #1043
Where do the 3 hole 1.1mm pistons come from? I thought all the Corally pistons were two hole.
automator is offline   Reply With Quote
Old 11-01-2007, 04:11 PM   #1044
Victor Vector's Avatar
This is a hot idea. Locally, we've been cutting the 1/12th scale nut down to fit. But the set screw !! Brilliant.
Thanks,
Jacko (of the crunchy diff)
Jack Balchin.
Timezone Hooligan
IBEW Local 48-retired (Definitely, great pension.)
Victor Vector is offline   Reply With Quote
Old 11-01-2007, 05:27 PM   #1045
Hey, does the PHI come with the diff nut wrench or do you have to buy that seperately? Is it worth buying?
DOTMAN is offline   Reply With Quote
Old 11-01-2007, 05:33 PM   #1046
turboxrayt1fk05's Avatar
Trader Rating: 27 (100%+)
a 9mm open wrench from craftman would do , you can get it at sears
SERPENT S811 AND S811T, FUTABA 4PKS , viper rc solutions
OS SPEED WORLDS EDITION 21 , OS 2060 PIPE
BYRON %30 FUEL , PROTEK 2300 LIPO RX PACK
SAVOX SERVOS 1268MG HV , 1267MG HV
turboxrayt1fk05 is offline   Reply With Quote
Old 11-01-2007, 05:35 PM   #1047
I'm guessing then it doesn't come in the kit?
Old 11-01-2007, 05:55 PM   #1048
Jimmy Morris's Avatar
No, but its inexpensive and super kool. Worth the money.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 11-01-2007, 06:01 PM   #1049
Thanks, I just ordered one
Old 11-02-2007, 05:14 PM   #1050
Automater.... the 3 hole pistons are tamiya's... Sorry...
Mike
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
