Old 10-26-2007, 11:33 AM   #1006
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Originally Posted by 74VWTECH View Post
Is anyone running a 13.5 brushless and what size spur are you running to get the right fdr.
Ryan, you probably want to use a 100 or 104.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 10-26-2007, 11:40 AM   #1007
74VWTECH's Avatar
Trader Rating: 19 (100%+)
What's up Brian you been doing any racing. Is that spur size for when you run rubber tire or foam.
Thanks Ryan
Fantom Racing * CB's Custom Cut Gears * 92zero Designs * Stiky Liks Racing Concepts * Leisure Hours Raceway * Trackside * Race'em RC
SC5M, B6, T5M, RC10 Worlds
74VWTECH is offline   Reply With Quote
Old 10-26-2007, 12:19 PM   #1008
Korey Harbke's Avatar
Originally Posted by Victor Vector View Post
Thanks Jeff.
I got a major problem keeping the plastic diff nut intact. And find they shift during a race causing inconsistent drive. Really frustrating !!
What's the secret ?
Some locals are using the older RDX pieces, but there must be a better way.
Jacko
What you can try is take some medium or thick ca... and put a little bit on the threads of the diff half. Make sure you wipe any excess off with a towel, and let it dry before you put the diff nut on again. All you are looking for to put a really really light coating of ca glue to make the threads a little tighter on the nuts.
Mark Panye, the 1/12 guy that does all of those cool little how to build stuff on his blog does that on his corally sp12x, and it's to make the diff nut hold on better. It's a very similar design concept on the rdx phi diff. So if you want some pics of how it's done check out his web blog. Hope that helps bud.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 10-26-2007, 12:32 PM   #1009
Thanks Ryan
That's the spur I'd use if I were running 13.5. I normally run a 110 spur.
I'm hoping to get home once before Cleveland, but we'll see how my school schedule goes.
USVTA Member #211
Old 10-26-2007, 02:29 PM   #1010
Trader Rating: 1 (67%+)
get the 100 and run 40 - 43 depending on track layout
Josh Hohnstein is offline   Reply With Quote
Old 10-26-2007, 04:10 PM   #1011
Default shock tower braces
can anyone tell me the part number for the stock tower braces
jongsxr is offline   Reply With Quote
Old 10-26-2007, 09:11 PM   #1012
tbeardmore's Avatar
<---- Yeah! I heard there's gonna be a "Rock Star" showing up to race!!!!
Originally Posted by Jeff Brown View Post
I will be working on these in the next couple days. I do need some drivers to still send in their setups.
Brad and I are heading out to Omaha next weekend for their big carpet race. If you are close to there you may want to check it out.
http://www.hobbyplexraceway.com/
Jeff
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 10-26-2007, 11:30 PM   #1013
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
I'm running 84/39 on a medium sized carpet track with foams. Motor is about 130 degrees and very fast.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 10-27-2007, 06:47 AM   #1014
Since you have the PHI just switch the gear ratio to the smaller gear ratio. It's not that hard. Then you don't have to get some of the bigger pinions.You need a new rear belt, front and rear pulleys and two other parts to hold the diff in the correct position( sorry I don't know the correct part but it is explained in the gear chart section).I'm running the stock spur gear with either a front and rear diff or this weekend I'm trying a spool up front.I just run out doors and no carpet.Forgot this is my 13.5 .
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 10-27-2007, 07:35 AM   #1015
....Never had a tight fit from day One......????
Boy, you've got some seriuos problems!!!!!! LOL
Juan Aveytia is offline   Reply With Quote
Old 10-27-2007, 07:37 AM   #1016
It sounds like it's easier to just buy new pinions.
Old 10-27-2007, 09:04 AM   #1017
Trying to find the 48 pitch pinions I wanted is hard to find and impossible from Kimbrough.Before I had to use Brand X 41-43. Now I'm getting the same gear ratio with 30-33. So it's easier to find pinions.I've been running anywhere from a 4.90-4.30 overall with my 13.5. I just got a 13mm rotor and it says to start around a 4.00.My big race in Daytona is under rain delay for today at 11 am. My team mate has a 3.14 in his car ready for practice.Only he is using the standard set-up with a 52 spur and a 33 pinion.Until I get there tommorrow and run side by side and compare I don't know what set-up will be better- I'll let you know.
Old 10-27-2007, 07:53 PM   #1018
cujo's Avatar
I've been running a 96/38 on my local track with good results.
cujo is offline   Reply With Quote
Old 10-28-2007, 11:57 AM   #1019
74VWTECH's Avatar
Thanks guys I really appreciate the info.
Old 10-29-2007, 04:27 AM   #1020
Well my team mate ran his RDX and that was it .He again was using a 52 spur gear with a 3.14 overal gear ratio. I ran mine with the 1.77 overall set-up with a 31= 4.30 gear ratio. The spool is diffently different and I'm not used to it.All I've driven is a double diff in both the RDX and the Phi until this weekend.I'd say for this Master the double diff is better(smoother ) But can see the Spool better fore most.I also ran the lipos (3200) with no problem and the 13.5 Novak.Also discovered why my car keep loosing the suppension parts.I was never told about the washer and screw to install in the front and rear clamps.They're done now and that problem won't happen again.This is an easy car to work on. Now it's time for somemore wheel time.
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
