Old 09-16-2007, 08:51 PM   #901
I am Scott but the Phi is sooooooooooooo much cooler! It has easy access diffs AND a cool symbol on the upper deck!!!
Originally Posted by vlvttch View Post
Come on Steve. Be happy with what you've got. It ran well once the kinks were worked out. You have a car thats 98% nicer than anyone at the track. See you in 2 weeks.
ASCI_Blue is offline   Reply With Quote
Old 09-17-2007, 07:02 AM   #902
Jimmy Morris's Avatar
RDX phi took tq, 1st and 2nd at this weekends state race at K Raceway in Kissimmee Florida. Only ones turning 27 lap runs. http://www.youtube.com/watch?v=XrvK88zb03M Video if anyone cares to watch it. (45 second mark)
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 09-17-2007, 07:29 AM   #903
rcgen's Avatar
Originally Posted by Jimbo Morris View Post
RDX took tq, 1st and 2nd at this weekends state race at K Raceway in Kissimmee Florida. Only ones turning 27 lap runs. http://www.youtube.com/watch?v=XrvK88zb03M Video if anyone cares to watch it. (45 second mark)
That was one great stock race the two of you had. It was so close.
rcgen is offline   Reply With Quote
Old 09-17-2007, 07:47 AM   #904
Thanks. It was a lot of fun.
Old 09-17-2007, 11:04 AM   #905
Just curious since I'm running my PHI alittle different outdoors. The first time running with the 1.71 overall gear ratio with double diffs using a 13.5 novak motor.Next month I going to try a spool with the same overall gear ratio.Any comments?
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 09-17-2007, 11:11 AM   #906
Don't run positive camber next time.
Old 09-17-2007, 11:12 AM   #907
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Old 09-17-2007, 10:43 PM   #908
RaceBucks's Avatar
I just sold off a bunch of my mid-range cars and am looking to get a top end car; most likely will be the Phi. I have some questions about what comes with the kit and which tuneing options are recommended. I'll be running on asphalt indoor and outdoor with a 13.5 brushless and 3200 LiPo.
1) Does the motor guard come with the kit?
2) What shock springs come with the kit? The Corally parts lists online lists 2 spring kits (6 pairs) Hard and Standard; do these overlap in hardness? Do I get both?
3) Does the kit come with sway bars? 1.3, 1.6, 1.9mm?
4) Does the kit come with all the shock piston choices? 0.9, 1.1, 1.3mm?
5) Is the 2.9mm chassis (US version) or 2.4mm best for asphalt? Does it really matter much if I occationally run carpet?
6) I'm hearing mixed messages about how the 3200 LiPo fits, is grinding required?
Thanks for your help.
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
RaceBucks is offline   Reply With Quote
Old 09-17-2007, 10:53 PM   #909
Trader Rating: 8 (90%+)
1) No
2) Hard set with the Carpet Spec **They dont Overlap**
3) No
4) Just the 1.1's I think.
5) I dont know
6) I dont know
Johnny Carey is offline   Reply With Quote
Old 09-17-2007, 10:56 PM   #910
rcgen's Avatar
Racebucks
1. No
2. Comes black springs but pick up the spring kit
3. No sway bars
4. One standard piston
5. Good question not sure????
6. 3200 Carbon edition will fit. You'll have to grind/sand a little extra especially towards the rear bulkhead.
I ran mine for the first time this weekend 13.5 bl and 3200 lipo. Car ran great all weekend. Great improvement from my original RDX
Old 09-18-2007, 10:54 AM   #911
Jeff Brown's Avatar
4) The kit includes 1.3mm pistons.
5) I would lean towards the 2.4mm chassis for asphalt. Yet, if you get either one it will be fine for carpet or asphalt. The thinner one would help more in high track temps during the summers.
Jeff
Jeff Brown is offline   Reply With Quote
Old 09-19-2007, 09:14 PM   #912
Just found this picture of Marc Fischers RDX PHI from the German Nationals. It looks like it has a Tamiya suspension setup on it and some other changes as well.
[IMG]attachmentid=268346&stc=1&d=1190257075[/IMG]
XCELL is offline   Reply With Quote
Old 09-20-2007, 05:33 AM   #913
OllieRDX's Avatar
Send a message via MSN to OllieRDX
He was testing tamiya pieces for the next evolution for the PHI.
So he didn't won teh german nationals with that car.
He won with the original PHI.
OllieRDX is offline   Reply With Quote
Old 09-21-2007, 06:32 AM   #914
Just curious what the difference between running a double diff set-up over a spool or one way for the outdoors. I'm running a 13.5 with either lipos or sub c's(1525 grams).I ran the double diffs on the older RDX. And last weekend I ran the double diffs on the PHI.
Old 09-21-2007, 11:49 AM   #915
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Running a spool or oneway would give the car much more on-power corner speed and steering.
With a spool the car would retain the braking of a diff, but will not turn-in very well.
A oneway turns in better than a diff, but as you know, no front braking. A oneway can be very fast because it gives you the on-power steering/speed and better turn-in compared with a diff. Basically, more overall steering...sacrifices rear grip off-power.
On most asphalt tracks, though, a spool is choice because it allows you to drive deep into corners once you get some of the turn-in lost back.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
