Old 09-05-2007, 10:55 PM   #856
Trader Rating: 8 (90%+)
Same here.
Johnny Carey is offline   Reply With Quote
Old 09-05-2007, 11:05 PM   #857
Still Bill's Avatar
Originally Posted by Johnny Carey View Post
Nice writing kiddo!
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 09-06-2007, 10:40 AM   #858
Jeff Brown's Avatar
Originally Posted by gone_wheelin View Post
Funny, I was just checking the Corally International site and it looks like Corally agrees and is replacing those crappy round ones with ones that have a square adjuster like the others.
Does anyone know if they will be including these in the new kits as well?
Depends on the inventory of the importer. All kits we currently have at CorallyUSA have the old style turnbuckles. I am sure the kits will eventually be coming with the updated style.
Jeff
Jeff Brown is offline   Reply With Quote
Old 09-06-2007, 03:50 PM   #859
Little bit off topic - I have a question regarding my RDX. Whenever I steer my car at 100%, while holding the car up and giving it some throttle, the inside tire vibrates very badly. I tried reducing it down to 90-95% but the inside tire gets pulled in to the maximum (knuckles touching the caster block) then vibrates. I hope you can picture my problem. Can anyone help? Thanks.
TANTA is offline   Reply With Quote
Old 09-06-2007, 04:14 PM   #860
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Prolly because your end points are not set correctly
Set your Dualrate to 100%, then adjust your EPA for Left and Right individually. If your Left and Right settings are way differnt, may have to measure our steering throw on a setup station to make sure your turnning left as much as right, once that is done, you can turndown your dualrate and eventually, the knuckle will not touch the caster block
I drive with about 65% Dualrate, So my knuckles are nowhere near touching anything.
Hope this helps
Ben..
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 09-06-2007, 04:21 PM   #861
Victor Vector's Avatar
Tanta, a bent drive shaft can cause that vibration.
Jacko
Jack Balchin.
Timezone Hooligan
IBEW Local 48-retired (Definitely, great pension.)
Victor Vector is offline   Reply With Quote
Old 09-06-2007, 04:29 PM   #862
Also check for broken wheel bearings and/or broken or out of round c-hub bearings/bushings.
Old 09-06-2007, 04:47 PM   #863
I appreciate everyone's suggestion. I will do and check per your suggestions. Also I want to add that when I take out the front tires, there seem to be very minimal vibrations that I can detect, if nothing at all. But once I put those front tires the vibrations happen again.
Old 09-06-2007, 08:22 PM   #864
Send a message via AIM to goop
what tires are you runnning
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 09-06-2007, 08:42 PM   #865
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Any chance you are running a spool?
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 09-06-2007, 09:00 PM   #866
Yes I am running spool with Sorex rubber tires. You think it could be the spool that makes it vibrate? Thanks.
Old 09-06-2007, 09:05 PM   #867
it may be contributing... My car does this too at full lock. I think it has something to do with the CVD, not just Corally ones, but all of them that are this design. I'm not sure of the exact cause, or if I'm remembering this correctly. This chatter has been talked about before.. You may try searching for that, or maybe someone else will have some more insight for ya.
Old 09-06-2007, 09:11 PM   #868
tbeardmore's Avatar
tbeardmore - So pretty much the same spare parts as with the RDX, spare arms and such? Thanks.
And most of the RDX option parts will fit the Phi right, i.e. bumbers, body posts, caster blocks?
Yeah... I also forgot to tell you to get the aluminum steering blocks (otherwise known as hub carriers)
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 09-06-2007, 11:37 PM   #869
OK, so with the car gone thru the set up station, turning circle is 4 feet !! Don't see much more than 25 deg each side of centre and the steering blocks are parked on the C hubs.
What've I done wrong or does it mysteriously turn like a demon when on the track. All my previous cars have turned in smaller circles.
Jacko
Jack Balchin.
Timezone Hooligan
Old 09-07-2007, 02:04 AM   #870
Big Rigg's Avatar
Lightbulb
Hanging arms at full lock will definately cause chatter with a spool... when it;s on the track under load it should be reduced (but generaly a good setup won't require 100% full lock steering). Also some black grease on the front blades is always a good idea
As for turning radius, I'd say if it handles the tight corners at speed, then don't worry about the turn radius when coasting... (that being said mine will turn a fairly tight circle at only 70-75% dualrate...). Double check your front toe settings and make sure you're using the correct ackerman hole on the knuckle... also if your servo horn is too short it'll cause reduced steering travel, but it sounds lke you are getting it to full lock...
good luck fellas
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
