Team Corally RDX Phi
#796
20wt is correct on brads setup
#797
Hey Everyone.. Just wanted to pop on here and say hope everyone is looking forward to the upcoming carpet season.. I hope to be on as much as i can to help out with the new car.. I just built my car for the upcoming races and hope to hit the track with it next week in preparation for the upcoming vegas races... If anyone has been running and has found some stuff they like at there track that makes a big difference please post it here so we can all get these PHI'S to the max speed....
Later
Mike Blackstock
Later
Mike Blackstock
Hi Mike - This car is SOOWWEEEEEET....!
Good luck to you at the IIC - I wish I could be there this year again but, I had already committed to the Nascar Race in KC this year w/my brothers... Last Year I went to the IIC - then the Nascar Race was the following weekend. Oh well maybe next year?
This is the setup I've been using the last few weeks with only a few variations.
http://www.corallyusa.com/setups/PHI_johnson1.pdf
28lb Spring in Front
25wt Oil in the back
Front Droop 2 - up
Front Ride Height 5
Rear Droop 1 - up
Rear Ride Height 4
Shock Pistons 1.3 - rounded
BTW... I'm running 4300 Brushless LiPo.. 1420g total weight.
The car has a ton of steering. I have the dual rate turned down to 67%. Carries alot of corner speed. Magenta's all the way around.
If you get a chance.... come to race with us in Omaha sometime. Jeff Brown & Brad Johnson came up to "The PLEX" HobbyPLEX Carpet Onroad Challenge last February and had a blast... The Next Big Race..November 1st-4th.
http://www.hobbyplexraceway.com/events/07mcoc.jpg
Track and facility pictures here...
http://www.hobbyplexraceway.com/gallery/index.php
BTW. I heard "The Plex" has submitted to be the host track for the Carpet Nats this year... so it might be a good opportunity to come check it out ahead of time?
#798
Here is the setup I have been running to get ready for Vegas and feel pretty good about it.
#801
Great day of testing today!!!!
I can't wait to get to vegas.
#802
What about a good setup for rubber tires on carpet?
#803
OutofCash - I would start with TJ Bradley's Reedy Race Setup. This should be a good starting point. Then make adjustments as necessary. I hope this helps.
Thanks - Brad
Thanks - Brad
#805
Schorr-
Brad and i have been talking about going back to that race ever since we left last year. that A main was awesome yari and i had a great battle going the whole main. as long as nothing comes up we should be able to make the race
#807
Guys,
With the beauty of this spool, who needs another?.....
bigger photo:http://international.corally.com/ima...frontspool.swf
Curious as to why people want to run the JP spool, the advantage over the corally one is....?
#808
Donīt think thereīs an advantage. Iīve got the Corally spool as well. Just wanted to try something different and itīs never wrong to have an extra spool in the pitbag.....
#810
I agree with you on the thrust bearing. Worst diffs I ever had to build. That was by far the longest part of the build too! I am NOT looking forward to rebuilding them!!!! I had to do a ton of sanding/dremeling to my chassis and bulkhead to get my 4200's in as well. Car is great when all is said and done though
I thought the build was very smooth and the diffs weren't too bad once I understood the methods for assembling them. I will say that the first diff took quite a while to get right! The second one was done in about 10 minutes or so.
