Old 08-01-2007, 09:55 PM   #751
rcgen's Avatar
Originally Posted by BullFrog View Post
I've got the 4800 coming for my PHI. should be in next week.
When you get a chance, can post up how the fit and if any mods have to be done. With the 3200lipos its a little tight on the rear bulk head. Just wondering how the 4800 will fit before I get one, since its a block.
rcgen is offline   Reply With Quote
Old 08-01-2007, 11:10 PM   #752
29TC's Avatar
Send a message via ICQ to 29TC
Can you post pics of the 3200 lipo in your phi. I was thinking of getting the 3200 pack. Thanks
29TC is offline   Reply With Quote
Old 08-02-2007, 09:14 AM   #753
Kenny L's Avatar
Trader Rating: 16 (100%+)
You have to sand precut slots down but after it fits very nice.
Kenny L is offline   Reply With Quote
Old 08-02-2007, 08:03 PM   #754
29TC's Avatar
Thanks for the pic.
Does the right rear bulkhead interfere with the battery connection hole? Looks like it in the pic.
Old 08-02-2007, 10:12 PM   #755
tbeardmore's Avatar
Originally Posted by 29TC View Post
Thanks for the pic.
No - Actually the positive sits inside the bulkhead. Using Corally connectors, it works perfectly.
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 08-03-2007, 03:30 AM   #756
Well I can tell you the 4800's from Peak/orion do not fit. It will either take a redesign of the plactic hard case or major work of the rear bulk head and top plate.Since I don't think that will happen I'll have to order a new 3200 and sell the 4800.Oh well back to the drawing board.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 08-05-2007, 05:29 AM   #757
Cookie's Avatar
Originally Posted by Glowster21 View Post
Anyone have any issues with the battery getting hung up on the metal insert for the top deck on the battery side in the back? Mine is very snug and the insert pushes back the shrink wrap on my cells. Anyone else had this issue?
Yes!
I found it was actually the counter sunk screw head not the bulkhead material. I replaced the counter sunk screw with a round head screw and problem went away!
Cookie is offline   Reply With Quote
Old 08-08-2007, 09:24 AM   #758
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Robbie, Jeff, can't wait till you guys get kits in on Friday
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 08-09-2007, 11:18 AM   #759
Cookie- the peak 4800 will fit if you change the screw? I just returned my 4800 and have a 3200 coming in today.OH WELL that's life.
Old 08-09-2007, 01:26 PM   #760
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Welcome back
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 08-09-2007, 06:32 PM   #761
29TC's Avatar
Hey guys, quick question.
On the manual - option parts page, there is an item "outer hinge pin spacers". Where and when do you use those? What adjustments uses these outer hinge pin spacers? I just built my PHI and can't figure out what this option is for, eventhough its not included in kit.
I was gonna order some "inner hinge pin spacers" than I saw the "outer spacers".
Thanks in advance.
Old 08-09-2007, 09:13 PM   #762
My guess, Correct me if I'm wrong.
I believe the outer hinge pin spacers are used to remove any movement of the carriers and spindles inside the arm. Stops the forward backward movement.
Hope I'm right and that this helps
kiwirevo is offline   Reply With Quote
Old 08-09-2007, 11:25 PM   #763
29TC's Avatar
That makes sense. So, its not really an option for adjustments.
Thanks.
Old 08-09-2007, 11:46 PM   #764
jdm19turn's Avatar
does anyone else have a good bit of play in there center lay shaft from side to side just wondering?
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 08-10-2007, 03:01 AM   #765
29TC's Avatar
Yes. When building my kit, there is play. I shimmed it about 0.4mm. The pulley still spins smoothly.
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
