Old 07-11-2007, 05:46 AM   #706
Nuno Gancho's Avatar
Default Optional parts
Hello i saw that Corally have new optional parts for Corally PHI, is the new block totaly diferent from the new car? my Corally PHI is the european version, is the blocks diferent? Thanks.
Nuno Gancho is offline   Reply With Quote
Old 07-11-2007, 10:39 PM   #707
Default diff
i have the euro version, and have a question.the kit comes with a thrust bearing set but has no instrutions on were it goes this is a option part in the parts section does this take the place of something else in the rear diff if i were to use it?and i was under th impression that the car came with a motor guard and sway bar set,am i missing mine or did i misunderstand from the pictures.having a alot of trouble with assembly of the rear diff it seems to loose i hold the 2 out drives and move the pulley and it moves.
imber is offline   Reply With Quote
Old 07-11-2007, 11:34 PM   #708
jdm19turn's Avatar
check your kit for a black cone washer stampled to the white paper on the diff instructions revised with the kit it should go behind the nut in the diff this will keep the diff from loosing up on you
jdm19turn is offline   Reply With Quote
Old 07-12-2007, 12:02 AM   #709
Default diff
thanks,i guess it helps to look at the insert page,i was just looking at the manuel, went together easy after that with out being loose anymore.
Old 07-12-2007, 12:07 AM   #710
JayBee's Avatar
Trader Rating: 31 (100%+)
imber-
Since you have a new ride are ya coming out to run with us more
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-12-2007, 01:06 PM   #711
Default rdx
soon jaybee.
Old 07-13-2007, 02:54 PM   #712
Glowster21's Avatar
Trader Rating: 116 (100%+)
Anyone have any issues with the battery getting hung up on the metal insert for the top deck on the battery side in the back? Mine is very snug and the insert pushes back the shrink wrap on my cells. Anyone else had this issue?
Glowster21 is offline   Reply With Quote
Old 07-13-2007, 02:57 PM   #713
a sponsored driver told me you need to dremel that thing down when you build the car so the batts will clear
DOTMAN is offline   Reply With Quote
Old 07-13-2007, 06:20 PM   #714
edseb's Avatar
Yeah, with the CG and top deck so low it can be a problem. Dremel down the head and check to see if your battery slots might need a little extra too. Its very common.
edseb is offline   Reply With Quote
Old 07-17-2007, 10:54 AM   #715
MSB
MSB's Avatar
Send a message via Yahoo to MSB
Default Phi Steering Blocks duraluminium
Anyone knows if Corally changed the steering blocks duraluminium from the old Assassin/RDX to the new RDX Phi.
Or, by other words: what are the changes in changing the ackermann in the new Phi, reducing the angle of the turnbuckles.
If someone has a photo would be nice
MSB is offline   Reply With Quote
Old 07-17-2007, 11:32 AM   #716
Big Rigg's Avatar
Not sure what the angle differences are, but the phi is a single bellcrank system and the rdx was a dual... the single bellcrank defianely has more angle on the inside tire (just from visual refference).
Big Rigg is offline   Reply With Quote
Old 07-17-2007, 04:19 PM   #717
MSB
MSB's Avatar
Thanks Big Rigg, but what I mean is: when you see those long (38mm) turnbuckles in a slightly angle, is there any possibility to put in parallel or inverted angle?
Old 07-17-2007, 06:34 PM   #718
Trader Rating: 8 (90%+)
There is no way to make them parallel. The car felt better to me then the RDX. BTW, that is a pretty car!
Johnny Carey is offline   Reply With Quote
Old 07-17-2007, 06:50 PM   #719
Trader Rating: 15 (100%+)
Default setup help
Bill if you need help setting up your car i can help since Juan is no help.
AARON YOUNG is offline   Reply With Quote
Old 07-17-2007, 07:50 PM   #720
Big Rigg's Avatar
Wink
Ahhhh I gotcha now... I've seen a guy with a carbon fiber plate that he screwed onto the end of the bellcrank. But it just spaced out the ball studs (for shorter links)... perhaps someone could make one to extend the length of the crank by about a mill or 2.
I anyone know the team tamale guy? This may be worthwhile option...
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
