Old 07-02-2007, 06:49 AM   #676
Hi
$8 for 1 coupling? , and you need 8, thats a bit pricey...
Also it states in the book that you can change internal ratios of the car, and that 1 ratio is best for stock, yet it does not state which one...
Also in the assassin book it states that the single belt design is best for stock, why wasn't this design covered over to the new rdx and phi ?, why was it change to the 2 belt only ?
Thanks Ya`All
MoonTrap is offline   Reply With Quote
Old 07-02-2007, 11:40 AM   #677
Send a message via MSN to _RDX_
can anybody tell me what the biggest/smallest piniong/spurgear that fits in the Phi?
Thanks/ Daniel
_RDX_ is offline   Reply With Quote
Old 07-02-2007, 08:33 PM   #678
Trader Rating: 8 (90%+)
Originally Posted by MoonTrap View Post
Hi
Thanks Ya`All
On the PHI, you do not need the low roll center blocks (79121) as the way the PHI is designed with the standard blocks (79120) down is the same as the RDX with the low roll centers down. Atleast that is what I remember being told.
Johnny Carey is offline   Reply With Quote
Old 07-02-2007, 09:46 PM   #679
rcgen's Avatar
Thanks/ Daniel
I have an 88 spur and could put a 58 pinion 64pitch. It's the largest pinion I have. You'll have to remove the pinion just to tighten the motor. I hope there will be no reason to go there
rcgen is offline   Reply With Quote
Old 07-03-2007, 01:11 AM   #680
If that is the case, then why in the phi manual does it list the 79121 as a tuning option for the phi for low roll center ?
Old 07-03-2007, 04:39 AM   #681
Watch out for those diff nuts they strip easy. Lucky I ordered some spares.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 07-03-2007, 08:09 AM   #682
thats the only weak point on the car is those plastic nuts, why not make em aluminum or steel ?, i mean one pays $480 for the car you'd expect better
Old 07-03-2007, 08:38 AM   #683
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
maybe it had something to do with the aluminum (soft) outdrive material...
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 07-03-2007, 11:31 AM   #684
XRC
Trader Rating: 33 (100%+)
I would have thought the same thing. After talking to guys at CorallyUSA, the plastic nuts are fine, just use a small amount of lock-tight on the diff nut. I've had my diffs apart 10 times (at least) and I'm still using the same diff nuts.
XRC is offline   Reply With Quote
Old 07-05-2007, 10:22 PM   #685
Jeff Brown's Avatar
No one makes a diff nut in that size. It is too short and no options available. It is a custom part as far as I know. If you are having problems, then something is not set right. Some of the early kits didn't have the coned washer included to lock them down. The local distributor and/or hobby shop should have been able to obtain them for you.
Jeff
Jeff Brown is offline   Reply With Quote
Old 07-05-2007, 10:23 PM   #686
Jeff Brown's Avatar
Only when used improperly.
Jeff
Old 07-05-2007, 10:25 PM   #687
Jeff Brown's Avatar
I think this is in part to the original design of the PHI. I do not believe it was originally to have such low roll centers out of the box. The optional holders will work, just in the up position which will really raise the roll center.
I think the change was made due to the fact that people did not want to purchase 8 individual roll centers to make it lower. So the stock option is to run the lowest roll centers and shim higher as needed.
Jeff
Old 07-05-2007, 10:30 PM   #688
Jeff Brown's Avatar
It depends who you talk with honestly. I have run the 2.0 ratio in the RDX of course the whole time. I ran the 1.7 ratio at the Reedy Race. I plan to use the 2.47 ratio at the ROAR Nationals next week. Hopefully I will know more from this all.
Some will say that the higher the ratio........ 2.47........ will give you more acceleration. Hopefully I can respond better to this later on.
Jeff
Old 07-06-2007, 11:27 PM   #689
jdm19turn's Avatar
is there any way i could get a copy of mike blackstocks reedy mod setup for the phi to try out if any one might have it thanxs ...
jdm19turn is offline   Reply With Quote
Old 07-07-2007, 11:20 AM   #690
Hi All
Why is the top deck on the phi tight? , even a few mates of mine their phi top decks are tight, you have to use a bit of force to get them in place, surely it tweeks the car?.
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
