Team Corally RDX Phi >
Old 06-14-2007, 10:01 AM
  #631
Does anyone have a good rubber tire carpet setup for low bite track?
rcprocenter is offline
Old 06-14-2007, 10:06 AM
  #632
Trader Rating: 40 (100%+)
Start with Nelson's Novak setup, throw a spool in and it should be really good. Once the bite comes up, the one-way seems to work, but when bite is low, the spool gets me into the turns much better.
brians11 is offline
Old 06-15-2007, 12:58 PM
  #633
rcgen's Avatar
Default Alum Steering Blocks
Anyone having problems with the aluminiun steering blocks binding up with the c-hubs? I bought the steering blocks with the bushing instead of the bearings.
rcgen is offline
Old 06-15-2007, 03:28 PM
  #634
XRC
Trader Rating: 33 (100%+)
Mine were pretty snug as well. I just took a light file to the C-hubs and they're fine. You don't need to take off much at all. NO Dremel .
XRC is offline
Old 06-16-2007, 03:56 AM
  #635
acesix00's Avatar
My kit arrived yesterday and i am still amazed by the quality. Nice and easy to work on and very light! Just one question, have the shocks changed at all from the RDX kit? I spent a while building the shocks on the last kit with tamiya pistons.. Just wondered if I would be missing something out if I swap the shocks over from RDX to phi ?
Thanks.
acesix00 is offline
Old 06-16-2007, 09:10 AM
  #636
tbeardmore's Avatar
Thanks.
Same shocks... 1.3 mm holes
tbeardmore is offline
Old 06-16-2007, 07:42 PM
  #637
Originally Posted by Jeff Brown View Post
Like brians11 mentioned, I would start with Mike Nelson's setup for the PHI.
Mike's car had the 2006 COMP SPEC chassis and CENTER POINT TOPDECK on the car, which makes the original RDX, the same as the PHI. It moves the batteries back and changes the steering.
Jeff
You mentioned the batteries are moved back,is the car more evenly balanced now? I have an RDX and the best balance I could come up with is 53.2% on the front and 46.5% on the rear.
outlandr91 is offline
Old 06-16-2007, 09:00 PM
  #638
wallstreet's Avatar
Trader Rating: 20 (92%+)
Guy the batteries being moved back help the car to rotate more.... Its a very noticable change and a very good one. Cuffs when he ran for corally had a carpet foam tire chassis he used and had the batteries moved back on it.
wallstreet is offline
Old 06-17-2007, 12:09 AM
  #639
Hey Wallstreet:
the the chassis he used the compspec chassis for the RDX (79337B)? Doe's anyone know anything about this chassis? Was thinking about getting one just to hold me over for another season w/my RDX.
Electro-MAX RC is offline
Old 06-17-2007, 08:44 AM
  #640
Outofcash's Avatar
Trader Rating: 19 (100%+)
Does everybody use the Corally diff lube or is there another that works as well or better? I just got my kit and there was not any in the box.
Outofcash is offline
Old 06-17-2007, 11:29 AM
  #641
XRC
Corally or Niftech, I usually use the Corally.
XRC is offline
Old 06-17-2007, 06:13 PM
  #642
TeamPink91's Avatar
Myself and some other guys have luck with Associated Stealth lube on the main rings and balls, then Associated Black Grease on the thrust.
TeamPink91 is offline
Old 06-17-2007, 06:50 PM
  #643
Thanks for the info,I'm trying to decide whether to but the PHI.I really like my RDX but there are a few areas where it could be improved.
Old 06-18-2007, 05:41 AM
  #644
imprsme's Avatar
Trader Rating: 76 (99%+)
If you like your RDX you will love the PHI.
imprsme is offline
Old 06-18-2007, 08:30 AM
  #645
BJohnson's Avatar
Guy - You cant go wrong by getting the PHI. Let me know the next time you will be at the track, and you can drive mine.
Thanks - Brad
BJohnson is offline
