Old 08-27-2010, 01:18 PM   #3346
J.Elliott's Avatar
Trader Rating: 21 (100%+)
Originally Posted by dynamic_e View Post
I'm totally new to this touring car thing and the traction hasen't come up yet on these new tires, but driving a touring car seems a bit easier then my WGT car. Only thing is my times aren't as fast yet as when I run WGT(still crappy), but think it's more an issue of the traction not coming on the tires yet. Still get 2-3 more packs until these tires are broken in. Running sweep spec tires BTW.
Few questions:
1) Whats the recommended doping setup for the car? I forgot to ask the local pros this one. On WGT, I do the entire rears and inner half of the fronts. I just realized when I got home that I doped up all of the tires when I ran them today, front and rear.
2) Recommended neutral noob friendly body for it. It currently has a ltc-r on it i think, but based on my driving, it wont last too long =) I run rubber tire carpet 17.5.
3) Trying to find the smaller diameter pullet that will fit the one way off a 07. The 07 looks like it runs a larger diameter inner circle then the 08's and just want the right PN before I order...or if anyone has a bunch of used bits and bobs they want to get rid of =)
An observation, when running rubber carpet, the tires pick up a ton of crap and residue after the run. My post run ritual is to wipe the tires off with a motor sprayed up napkin until no black comes off and then dope with sticky fingers or my kingsford/mineral oil sauce, then hook up to the charger.
Other then that, not a bad first time with a touring car for me!
Depending on what compound tires you are running, generally it only takes a couple of runs to get them working. I ran jaco greens or RP 30s and the break in procedure was goop/dope everything run for a couple minutes, then rotate and goop tires, run for a couple more minutes, rotate back and I was good to go. Once the were broke in, I only did a small strip on the inside of the front tries and all the rears, because if did all fronts and rears the car would push/understeer.
I ran an LTC-R for a bit, then switch to the Parma RTB GBS or a Mazda 6 and they last a couple months.
If you are looking for a good over all set up, go to Corally's USA site and get Brad Johnson's Cleveland set up from 11/09. That is a great starter set up.
Again, depending on which tries you use, if you get way off of the run line, your tires will pick up a ton of crap. Just like in World GT, if you get off of the run line you will have a lack of traction, same thing applies to rubber.
The car is very, very durable. I used to run 13.5 in the Madison, Milwaukee area and the car took quite a few big hits and kept going.
Race Director at Clark RC Park
J.Elliott is offline   Reply With Quote
Old 09-09-2010, 10:01 PM   #3347
Andrew Barr's Avatar
Trader Rating: 73 (100%+)
Does anyone know if the Tamiya TA05 front spool (53877) and/or oneway (53833) fits the RDX Phi.
Giant MTB
Andrew Barr is offline   Reply With Quote
Old 10-11-2010, 12:55 PM   #3348
Default pro red series brushless motor
Hi Gents
Has anyone used the Team Corrally Pro Red Series (Star) 17.5T brushless motors.
Looking at the specs it seems to have a notable amount of extra power.
I currently use Speed Passion LPF with a Novak Ballistic and it a Tein killer but was wondering if the Corrally motor is a better alternative...
Number 22
Number 22 is offline   Reply With Quote
Old 10-12-2010, 01:44 AM   #3349
PizzaDude's Avatar
Originally Posted by Number 22 View Post
Hi Gents
Number 22
If it's allowed RUN IT.
Gear up though to make use of the power.
PizzaDude is offline   Reply With Quote
Old 10-12-2010, 03:08 AM   #3350
Hi Gents
Number 22
I use the corally 17.5 in my PHi 09 and have the track record with it at my local track, cracking motor lots of punch out of the corners which is ideal for my local track as it only has the one long straight.
Best 17.5 motor i have used so far .
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 10-12-2010, 03:55 AM   #3351
Thanks Weekend Racer..
I currently use the Speed Passion LPF with 528 software. My Roll out is around 32 for a 168m Track with a good straight and fast infield. Would you say that I should try the same rollout for the Corraly or as it has loads more Torque, perhaps go up a few teeth.
Old 10-12-2010, 08:19 AM   #3352
Try it and temp it ever few minutes, i found the motor does not give any more after 140-145f temp range. Sorry can not be any more help but i use a black diamond speedo that just has 5 power settings and no laptop tunning lol.
Old 10-22-2010, 04:34 PM   #3353
gentleman81's Avatar
anyone know anything that should be done to the car setup when using the lipo tray on the phi '08?
do i need weights in particular places, etc?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 10-24-2010, 05:16 PM   #3354
J.Elliott's Avatar
I had weights on the tray to help keep the car balanced. Roar weight was 1420, but mine weighed at a hefty 1500.
Old 11-03-2010, 09:47 PM   #3355
idbdoug's Avatar
Trader Rating: 33 (100%+)
Team Corally RDX Phi parts support. I searched a few online hobby shops in the USA and it seems allot of parts are out of stock. I am looking at getting one of these cars and I was wondering just how good the parts support in the USA is going to be in the future.
idbdoug
idbdoug is offline   Reply With Quote
Old 11-07-2010, 12:27 PM   #3356
I also have an older car and have been grabbing what ever i can find. You can probably fond parts at the LHS level.
DIRTISFORWORMS is offline   Reply With Quote
Old 11-07-2010, 06:34 PM   #3357
dc661's Avatar
Trader Rating: 129 (100%+)
www.corallyusa.com still has Corally Phi parts.
-DJ Cranmer
dc661 is offline   Reply With Quote
Old 04-10-2011, 07:14 AM   #3358
mazmo's Avatar
Default Phi 2008 loose on power
I have a phi 08, kit set up.
Rear slides out on power, even when the slightest amount of throttle is applied.
Would appreciate any suggestions guys.
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 04-10-2011, 07:33 AM   #3359
soft rear springs would help. what are your diff settings? is the front of the car pulling you around the track or is the rear pushing you?? need more info on your current setup
Andy Laaaaaaaaaachance
evader-fan-69 is offline   Reply With Quote
Old 04-10-2011, 08:24 AM   #3360
MAD916's Avatar
We have a pretty nice supply of RDX, and Phi09 parts on the wall in our shop... just finished host the ROAR nat's a couple weeks ago, so if you need something in particular email me a [email protected]
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
