Old 09-16-2009, 11:58 PM   #3241
Still Bill's Avatar
Originally Posted by Double D Donuts View Post
are you guys running the lipo tray with your car? i currently run the orion 3800mah 30c pack and it just squeeks in under the top deck. i kind of wanted to keep it so that the battery was right under there so it didn't throw off the suspension geometry but..i might have to. could you list some of the packs you use?
I have been using the tray with either the SMC5000 or TP5000 packs for a year. Both packs nicely balance out the car; but, can make it a tad slower on response...Not an issue for me.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 09-19-2009, 02:26 AM   #3242
blade072's Avatar
Trader Rating: 98 (100%+)
Originally Posted by MadBrushRacing View Post
Hi Bill
Thanks for the reply but I want the cheapest option to get the car running again. If I can get back on the pace after a 18 month layoff I will invest some more money.
Tony
you have to change 2 parts on the original diff
buy the sp12x us diff nut thrust washer (75926) and do away with the thrust bearing
and change one of the 1/4 x 3/8 bearings to a flanged one..(bearing has to be placed in the diff flange side facing towards adjusting nut so it doesnt fall out so it works in the same way as the o8 diff)
thats it mate hope this helps
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 10-18-2009, 11:17 AM   #3243
Jerzy JayRO's Avatar
Trader Rating: 38 (98%+)
Default high traction carpet & rubber tire
im new to tourning car, just started racing a phi 09. the set up that im running is working very well for my abilities, however at the end of the strt going into the big sweeper my car is rolling over alot. i raised the ride height but still happening. where should i start??? stiffer springs,shock fluid, sway bars?
thanks jayro
WwW.BOSSRCMOTORSPORTS.COM
BOSS POWER!!!!!!!!!!!
WWW.NJSlotSpot.COM
Horsham 2009/2010
CRUSH GRAPHIXS---CUSTOM VINYL LETTERING,ANY SIZE,ANY TIME.....
Jerzy JayRO is offline   Reply With Quote
Old 10-18-2009, 06:34 PM   #3244
Still Bill's Avatar
thanks jayro
What ride height did you have and what did you raise it to?
Old 10-18-2009, 07:49 PM   #3245
A Ilievski's Avatar
Trader Rating: 39 (100%+)
thanks jayro
Post up your set up and we will go from there
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is online now   Reply With Quote
Old 10-18-2009, 08:25 PM   #3246
thanks for your help.... a local racer has offered to help me, but in conversation it seems that i have to raise the roll centers. well see this weekend
WWW.NJSlotSpot.COM
Horsham 2009/2010
Old 10-18-2009, 10:25 PM   #3247
Bill
is it a noticable difference? i have a high speed chicane at my track and its my favorite area to gain ground because the car is so agile
Double D Donuts is offline   Reply With Quote
Old 10-19-2009, 05:48 AM   #3248
1fastdude's Avatar
Trader Rating: 15 (100%+)
thanks jayro
Did you get the car new or used from someone? Are you running foam or rubber tires and what compounds are you using? If you built it new and read the directions that came with the kit, I find it hard to believe that you are traction rolling with low roll centers!
★RCAmerica •Xray •Hudy •BSR/Jaco •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is offline   Reply With Quote
Old 10-21-2009, 06:14 PM   #3249
I recently picked up a used 08 Phi from a friend and I was curious...has anyone made an aftermarket that angles the battery mount slots like the LiPo tray does for this chassis? Our track has banked turns so it takes quite a beating on the transitions so I'm thinking ahead to when I'll need to replace it.
Old 10-23-2009, 08:15 PM   #3250
Scrad's Avatar
Anyone have a LIPO tray they want to sell? Please PM me.
Scrad is offline   Reply With Quote
Old 10-23-2009, 10:51 PM   #3251
Mark506's Avatar
Trader Rating: 42 (100%+)
If your looking for the specialized rc one that fits the PHI, Pm me. I have one. thanks
Mark Ament
l MOMO USA l OZ Racing l Willwood Brakes | Dunlop Tires |
The Raceway at Beaver: Forever In Blue Jeans
Mark506 is offline   Reply With Quote
Old 10-25-2009, 08:13 AM   #3252
Scrad's Avatar
Anyone else have a LIPO tray to sell?
Old 10-26-2009, 07:28 AM   #3253
I have the opposite problem as above, I can't get enough turn in on my Phi. Usually I would adjust the ackerman but this car just doesn't have enough.
I have the stock caster (6 I believe, sorry I don't primarily run this car) and I'm using shortest low rc for the upper front and both white shims are set to make the car as short as possible. the rear is set to the middle hole on the hub and the lowest outside hole on the tower. shock setup seems to be inside on the rear and outside on the front uppers. I'm using the softest spring in front from the black kit, and the 2nd softest in the rear with unknown oil. 1.3 sway bar on the front, no sway bar on the back (which should actually go back on now that I read that but our track went from no traction to decent recently)
Can I drill another hole for the ackerman farther forward or do any of you have some different advice? I thought about the 3 degree caster option as well.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 10-26-2009, 08:48 AM   #3254
sit your front shocks down, and put your backs up a bit. i run 1 set softer springs in the front than the rear (black spring set) and i do not have any sway bars... the RC is set to the middle spot, i believe and i too have 6* caster blocks.
one quick question, the 5 hardness arms would be the most forgiving of the bunch correct? i'm running the supplied 35s that i was given with the car, though i have broken 4 so far this season..im looking for something to make it a bit more durable
Old 10-26-2009, 11:11 AM   #3255
You will have too much flex with the 5 arms. The PHI is a very good car, but if you knock it it's usually an A-arm that breaks. Better that then a more expensive part. I use the 80 A-arms and only with a bad knock they break. Sometimes you just hit that sweet spot and crack it breaks. I have raced other cars in the past and have broken many parts... so far the PHI is most economical.
Corally PHI/PHI 09 TEAM DRIVER
BMI DB12RR TEAM DRIVER
TOP
LRP TC SXX, LRP SXX Ver. 2, LRP X12 Octa, Futaba 3PKS Spektrum Module, Protform.
SOUTH AFRICA :)
PHI/BMI racer is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
