Old 03-19-2009, 08:22 AM   #3106
You can try speaking with the guys at CorallyUSA.com they will ship to you. Or you can get from stormerhobbies.com
Originally Posted by maxrcp View Post
where can I buy Corallys out from Brasil?
I have hearding only good things about RDX PHI but here in my country is not easy to find chassi and parts...
MAx
PHI/BMI racer is offline   Reply With Quote
Old 03-19-2009, 05:50 PM   #3107
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
question for you guy's building my new car. front axle couplers. where do the shims go?? on the setup sheet that i am using it says 1.2mm shim for f coupler shim and r coupler shim. where the heak do you put them?? is it where the coupler meets the clamp?? or does it go under the clamp between the chassis. thanks jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 03-19-2009, 06:49 PM   #3108
imprsme's Avatar
Trader Rating: 74 (99%+)
Yep where the coupler meets the clamp, Is where the round shims go. They also have spacers that go under the clamp between the chassis and clamp..they are long and skinny.
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 03-19-2009, 06:52 PM   #3109
Moderator
J.Whiting's Avatar
thank you very much. i made the switch from tamiya. lots of new things on this car. hope i get them all right. jeremy
Old 03-23-2009, 10:36 AM   #3110
BJohnson's Avatar
Congratulations to Eli Ezrow and Mike McBride. Eli is the 2009 ROAR Carpet Stock Sedan National Champion. Mike McBride was the TQ of the same class finishing in a tie for first with Eli. The championship was decided by a mere tenth of a second. Both of these fantastic drivers were piloting Corally RDX Phi's. Hopefully these guys can get their setups posted on here as well as on the Corally USA site. Great job to both of these Corally drivers and to all of the Corally drivers that attended this years ROAR Carpet Nationals!
BJohnson is offline   Reply With Quote
Old 03-23-2009, 12:40 PM   #3111
1fastdude's Avatar
Trader Rating: 15 (100%+)
Thanks Brad, if needed I can post my set-up. I looked at Mike McBrides car and everyone probably won't believe it, but both our set-ups are almost completely opposite!!! I was using low roll centers and Mike was using high roll centers. Both our cars were really good however, probably our different driving styles.
★RCAmerica •Xray •Hudy •BSR •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is online now   Reply With Quote
Old 03-23-2009, 03:57 PM   #3112
Big Features's Avatar
Big congrats to Teamates McBrizzle and "The Beard"
Great runs guys!!
Mike Kling
Team Associated • REEDY Powered
JConcepts • TXD Skin Graphix • FDJ Sauce
Big Features is offline   Reply With Quote
Old 03-23-2009, 07:03 PM   #3113
B4james's Avatar
Hi Guys,
I have just tried the super short wheel base using 36t pulley front and rear with the Tamiya 415 efficiency belt. The problem I am finding is that the car is no where near as efficient as the standard pulley and belt set up.
Does anyone know how to get the belts looser by perhaps different diff holders or centre pulley/belt combo's. I have already tried stretching the rear belt and soaking it as well.
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 03-23-2009, 09:48 PM   #3114
Still Bill's Avatar
Originally Posted by B4james View Post
Hi Guys,
Mine loosened up after a couple days of running. What motor are you running?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 03-23-2009, 09:59 PM   #3115
Hi Guys,
Use 79703/79703 bearing blocks and 77137 rear belt. Dialed!
Mike Kling
Old 03-23-2009, 10:57 PM   #3116
B4james's Avatar
27 turn stock and I have run 10.5 motor in it for 5 heats and still not freeing up. I am comparing it to the standard PHI driveline which is super free and this is so much tighter than that.
I will get these bits and give that a try, cheers BF
Old 03-24-2009, 02:28 AM   #3117
Once your front belt get worn in, you may have to run the belt tensioner with about 5-7mm shins undernieth.
Mike
Mike Kling
Old 03-24-2009, 07:35 AM   #3118
MikeXray's Avatar
Trader Rating: 73 (100%+)
I have to say I was amazed at how many phi's there were at the nats, I'd have to guess at least 70% of the tc's there were a corally. Here is the setup I ended up with, I'm sure it could use a little work, but for me, the less than perfect driver, it was good. I was able to hit some good hotlaps only a few tenths off the amain guys, but they can do 10 of them
There were a few different setups going around, I didn't want to try it halfway through qualifying but those cars looked good.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-24-2009, 07:46 PM   #3119
Send a message via MSN to maxrcp
Default phi 2009
waiting for 2009 RDX phi
any date to release???
tks
maxrcp is offline   Reply With Quote
Old 03-24-2009, 07:50 PM   #3120
Mark506's Avatar
Trader Rating: 42 (100%+)
I dont want to act like this is a dumb question, but i know the norms of shock oil are usually 60,40. I noticed that your running 35 I'm the rear, and i have seen that with some others lately as well. What does that all do when you soften the rear up? More on-power steering? Thanks
Mark506 is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
