Old 03-02-2009, 04:52 AM   #3046
1rcracer's Avatar
Originally Posted by aus jd 2703 View Post
if it was shimming wouldnt be a problem
the hole bearing is moving in the hub as in slop around the bearing
hey...
hmm.. slop u mean horizontal play or vertical play...
well using the shims should help with the horizontal.....
in terms of the play around the circumference of the bearing....
i use a drop of loctight around the outside..let it dry ,that should help a little...BEWARE dont use too much you will lock tight the bearing hehehe
1rcracer is offline   Reply With Quote
Old 03-02-2009, 06:45 AM   #3047
s.nicholson's Avatar
Send a message via MSN to s.nicholson Send a message via Skype™ to s.nicholson
Hi,
Dont worry about the play, it does not affect the cars handling.
hey guys has any one else noticed slop in the rear hubs of the phi?
i just checked why i had slop in the axles and its the bearing moving in the hub.
any fixes? cars quite new bout 5 meetings old only running stock.
cheers guys just seems odd and very quick to develop slop
Team Yokomo/Panaracer/LRP/Xenon
Roche/Pro-Spec
Sanwa
s.nicholson is offline   Reply With Quote
Old 03-02-2009, 07:20 AM   #3048
Hiya,
As has been said you can shim for side to side play, i too have noticed the tiny bit of play on the bearings, but as Simon said, it does not affect the handling, Rather a bit of slop, than binding.
Dartanian is offline   Reply With Quote
Old 03-04-2009, 04:55 AM   #3049
1rcracer's Avatar
yeah aint no binding on dart's PHI
Old 03-04-2009, 06:31 AM   #3050
crabboy's Avatar
Trader Rating: 58 (98%+)
Over the last couple of race meets i have played around with the delrin and the duraluminum spool using the specialized steel blades.
The steel blades did slightly wear the delrin spool but i was not using any anti wear grease i was running it dry, i ran it this way for 1 race meet, and as i said it was only very minor wear.
On the duraluminum spool i used some anti wear grease and after 2 race meets the spool is holding up very well indead with no signs of wear at all.
So my advise to anyone running a spool would be to run the duraluminum spool with specialized steel blades with a small amount of anti waer grease.
Hope this helps guys.
Rhys
hey guys im running the delrin spool and am chewing through a set of drive shaft clips every 3rd run there has to be a better way any ideas?
yes im a rather poor driver im not blaming the car, but i wanna address the problem.
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 03-04-2009, 08:36 AM   #3051
True Dat
Old 03-04-2009, 10:41 PM   #3052
Rommel's Avatar
Now Available!
Interest/Questions PM or post on my thread.
Corally RDX PHI Chassis Protector For #79837, #79838 & #79839 Chassis.
Rommel is offline   Reply With Quote
Old 03-05-2009, 09:15 AM   #3053
1rcracer's Avatar
This is Spam Dude.....
___________________________________
Team Novice!!
TEAM CORALLY RDX Φ - ZA
Old 03-05-2009, 06:05 PM   #3054
hey guys does the rubber car come with 17pound springs all round?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 03-05-2009, 06:29 PM   #3055
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Yeah, every car comes with 17's all around (and either the full eu or us spring kit). So you actually get all the springs you need.
ChristopherKee is offline   Reply With Quote
Old 03-05-2009, 09:06 PM   #3056
Hey guys, thinking about getting a PHI and was wondering if any of the li-po`s fit the current PHI? Or do I need to get one of those trays angling out the side? I currently run the Orion li-po`s.Thx.
asfastasu is offline   Reply With Quote
Old 03-05-2009, 09:22 PM   #3057
dgdcustoms's Avatar
Trader Rating: 80 (99%+)
hey just got me a RDX.whats the diff between the regular RDX and PHI cars.can i convert mine.thanks aloy any info will help thanks
Schumacher-Team Tekin-Fantom Racing-Futaba-Savox
Emery's Kustom Painting
DiscountRCStore.com-for everything Schumacher!!
dgdcustoms is offline   Reply With Quote
Old 03-05-2009, 09:37 PM   #3058
Still Bill's Avatar
Default Cat's meow...
I originally ran my Phi with the Orion 3600/3800 lipos (with normal placement of the packs); however, having the extra voltage of the higher capacity SMC5000 packs is the best combo. You just plain have higher voltage towards the end of a 5-6 minute run making you more competitive. The pack being positioned outward towards the rear also nicely balances against the weight of a brushless motor. Cat's meow!
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 03-05-2009, 09:39 PM   #3059
Big Features's Avatar
The 3800s fit with some dremeling. I recommend the lipo tray because it works great and makes balancing your car a snap.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix FDJ Sauce
Big Features is offline   Reply With Quote
Old 03-05-2009, 09:43 PM   #3060
night and day, the only things that are the same is the suspension.
Chassis, towers, diffs, belts, bulkheads, and the like are all different.
Got for the PHI. Speed costs, but you wont regret it.
Mike Kling
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
