Old 02-17-2009, 06:30 PM   #3001
E-clip's Avatar
Trader Rating: 39 (100%+)
Thanks bill
Do you know parts I need to buy to change to the lower 1.71 internal ratio ??
E-clip is offline   Reply With Quote
Old 02-17-2009, 09:25 PM   #3002
Still Bill's Avatar
Originally Posted by E-clip View Post
Thanks bill
For the short or long wheelbase?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 02-17-2009, 10:45 PM   #3003
E-clip's Avatar
I think short wheelbase would be better a outdoor track ???
Old 02-17-2009, 11:54 PM   #3004
Still Bill's Avatar
E-clip,
I run the short wheelbase on my Phi everywhere...carpet and asphalt.
Parts needed:
Corally TC79670 Pulley 36 teeth for LW differential (rear)
Corally TC79671 Pulley 36 teeth for duraluminium spool / front 1-way
Tamiya TRF415 Low Friction Belt (Rear)
Use the standard Corally RDX Phi front belt with the above.
I also like the narrow steering blocks over the standard ones to gain more steering.
Bill
Old 02-18-2009, 12:48 AM   #3005
Big Features's Avatar
I agree, the supershort wheelbase is king on asphalt. I have a REALLY good technical layout set up if your interested.
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix FDJ Sauce
Big Features is offline   Reply With Quote
Old 02-18-2009, 01:36 AM   #3006
hey guys im running the delrin spool and am chewing through a set of drive shaft clips every 3rd run there has to be a better way any ideas?
yes im a rather poor driver im not blaming the car, but i wanna address the problem.
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 02-18-2009, 02:01 AM   #3007
crabboy's Avatar
Trader Rating: 58 (98%+)
My car does the same so i ordered some steel shafts and steel blades from specialized RC havent run them yet, but i think it will be better, will post the results after the weekend.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 02-18-2009, 03:15 AM   #3008
blade072's Avatar
Trader Rating: 98 (100%+)
Rhys
i used to use them but found they wear more...
and seem to bind the suspension travel when straight up and down (very tight fit)
So you might want to file the blades slightly to stop this
also i just got myself the dural phi spool, so far so good using the standard shafts and blades...
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 02-18-2009, 03:36 AM   #3009
Hey what motor class are you running. In modified you need a duraluminum spool and the steel blades do make a difference. Also are you using rubber or foam tires. I am in South Africa and we use foam 200 mm set-up, a lot more traction then rubber, this causes problems with a spool so we use one-ways.
PHI/BMI racer is offline   Reply With Quote
Old 02-18-2009, 04:03 AM   #3010
blade072's Avatar
i am only running a 10.5 but rhys is running 3.5 i think but not sure though!! but i do know he is racing mod
oh and rubber tires.....
David Randall
Old 02-18-2009, 04:55 AM   #3011
crabboy's Avatar
Yeah Im running rubber tyres, and 4.5 lipo, i found the duraluminium spool to be very brittle and broke very easily, so im running the delrin spool of late with good results.
Rhys Marshall.
Old 02-18-2009, 06:49 AM   #3012
We never had problems with the duraluminum spool in 10.5 or higher motor classes. On rubber it was ok in mod too, but if you have a bad crash it can break or bend like any other part so keep it on the black stuff
Remember using a spool does wear out the front drive parts more then a diff. or one-way, so you need to make sure all parts are lubed and checked regularly.
Good Luck
Old 02-18-2009, 07:52 AM   #3013
Still Bill's Avatar
Mike
Share Mike, share...
Bill
Old 02-18-2009, 10:15 AM   #3014
1rcracer's Avatar
Talking RDX PHI 09
Hey guys ,any idea when the 09 will be released.
any team drivers had a chance to test out the car....
reviews.... let hear it biys...
1rcracer is offline   Reply With Quote
Old 02-18-2009, 10:17 AM   #3015
Trader Rating: 38 (100%+)
I've read next month.
or8ital is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
