Old 01-20-2009, 10:53 PM   #2956
Still Bill's Avatar
Josh,
I did find a certain size of plastic shrink wrap would fit over the openings to ward off dirt.
If you want, I can send you a couple of the older Phi diffs that built out pretty well...I won't use them. Just PM me.
When you can, buy the 08 diff and put your troubles behind.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-20-2009, 11:30 PM   #2957
Originally Posted by Still Bill View Post
Josh,
Bill
thats mighty kinda and i do appreciate it but i have to order the lipo holder so while im at it ill get and 08 diff.again thanks alot for the offer.
whats different exactly from the new diff to the old diff?
cheers guys
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 01-21-2009, 01:22 AM   #2958
Quick Question
Do the RDX and the Phi fit 30mm zero offset tires on the rear?
kiwirevo is offline   Reply With Quote
Old 01-21-2009, 10:10 PM   #2959
Still Bill's Avatar
cheers guys
Josh,
The new 08 diff is better engineered. It has larger ring plates (smoother) and the works are more enclosed (stays cleaner). For me, the old diff was questionable for the dealing with the torque of brushless motors, the new one is more than capable handling the extra load.
Whereas, I was rebuilding the old diffs way too often (I usually did all four at a time), I got by with only a single one of the 08 diffs in my two Phi cars. In both cases, I used ceramic balls.
Old 01-22-2009, 04:42 AM   #2960
ok so can some one straighten this out for me. does the 08 diff have thrust balls in them? and which ceramic balls work best the old diff ones the 08 ceramic balls or another brand?
also when running short wheel base do i have to change the upper shock mounts or inner camber links? ie move them forwards 5mm? if so how?
cheers guys
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 01-22-2009, 06:34 AM   #2961
MikeXray's Avatar
Trader Rating: 73 (100%+)
cheers guys
The thrust bearing is an actual sealed flanged bearing, like a 12th scale wheel bearing, so you could replace the entire bearing with a ceramic one, but I don't think that's necessary.
You mount the shock tower on the opposite side that it is mounted for the long wheelbase setup. (front side).
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-22-2009, 08:10 AM   #2962
Still Bill's Avatar
Oops! I forgot to mention that. Good one Mike.
Yes, the old ceramic diff balls (non-metric) fit better into the spur gear holes than the new balls (metric). The metric balls are a bit tight.
Bill
Old 01-22-2009, 11:07 AM   #2963
BJohnson's Avatar
Guys - When building up the 08 diff, make sure you are using the older size ceramic diff balls. You also need to make sure you are only using the outside row of holes only on the 42T diff pulley gear. You only need to use both rows when racing modified.
Thanks - Brad
BJohnson is offline   Reply With Quote
Old 01-22-2009, 07:11 PM   #2964
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
Bill
the holes can be drilled to 2.60mm.........
that makes the balls roll smoothly and also prevent the ring from rubbing against the pulley........
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 01-22-2009, 10:37 PM   #2965
hey what belt do i need to run the stock rear diff 21t centre pulley and the super short wheelbase? cheers guys
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 01-22-2009, 11:13 PM   #2966
also what the opinions of this short wheel base set up can you see any thing wrong?
cheers again
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 01-22-2009, 11:53 PM   #2967
Still Bill's Avatar
cheers again
Josh,
Yep...you are missing the bearing holders and diff...LOL. Looks like it could be a wrong rear belt; but, I cannot quite tell. What tooth pulleys will you be using?
It would be most worthwhile for you to scan through this whole thread (all 99 pages) to get the answers to 99% of the questions you are asking. This thread has been my "bible" for Phi upgrades over the past couple years. You will not be disappointed.
The similar Australian-based thread is great for the setups used on certain asphalt tracks in your country. Simon N had a lot to say about his "standard" setups...
Cheers!
Bill
Old 01-23-2009, 04:05 AM   #2968
Atomix's Avatar
Josh,
Cheers!
Bill
Both Simon & Ari use the standard wheelbase. The set-ups both post on various threads are exactly what they run. Simons car in particular tends to be very close set up wise from track to track, maybe a spring rate here or there is all that generally changes.
Atomix is offline   Reply With Quote
Old 01-23-2009, 04:49 AM   #2969
ok ive spent an hours searching through this thread and i cant find the answer.
what rear belt do i need to run 21t centre with 42t pulleys and the ultra short wheelbase?
all i wanna know is which belt?
cheers
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 01-23-2009, 09:50 AM   #2970
Trader Rating: 8 (90%+)
cheers
If you leave the diff towards the back, you just use the stock rear belt.
Johnny Carey is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
