Old 01-05-2009, 11:55 AM   #2926
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
Originally Posted by Dhartman03 View Post
Regarding the new diffs, do they use the thrust bearing assembly? or use the flanged bearing, cone washers, and metal nut that just comes in the new diff kit packages?
correct no thrust bearing assembly, just use the stuff in the 08 diff package.. Just make sure you install the flange bearing correctly, or the diff will just fall apart.. It took me several attempts before the light bulb went off in my head..
ALBERTO is offline   Reply With Quote
Old 01-05-2009, 12:01 PM   #2927
I can see initially how its confusing. I was just piecing the parts together and the assembly only made sense once i put the flanged bearing in through the area where the metal nut is, not where the ring seats on the outdrive. Thanks!
Dhartman03 is offline   Reply With Quote
Old 01-05-2009, 07:37 PM   #2928
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
Default asphalt setup...
here follows a great setup for asphalt w/ rubber tires and superstock motor........
lots of steering and great stability.................
running front pro dive and with readjusted bumpsteering the car rotates very well and consistently, under breaking and on throttle.......
for mod racing I'd use more rear toe-in only...........
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 01-06-2009, 07:13 PM   #2929
Default rollout for carpet
what rollout's are people running for 10.5 and 13.5?
Old 01-07-2009, 04:00 PM   #2930
cholawa's Avatar
hey kenny where can i get the hubs because on the site it shows up as the old 1s and wat about the new chassis? let me know
Kyle Cholawa
Johns BSR Tires-RC Madness-Team Corally-Team CRC-Rikter Designs-Team Hurricane-Gotham Graphics
www.rikter-designs.com
www.rcmadness.com
www.teamhurricane.net
cholawa is offline   Reply With Quote
Old 01-07-2009, 04:08 PM   #2931
code is 79299A
Salvadori Racing
Old 01-07-2009, 07:19 PM   #2932
cholawa's Avatar
thanx for that .... are they universal because it only has rr ie right rear? and wats the shim part #
Kyle Cholawa
www.rcmadness.com
Old 01-07-2009, 07:37 PM   #2933
they are 0, so they work on both sides.......
for the shims you can use any shim with 3mm inned diameter, most common is "3x6xthickness"
you also will need ball studs like 79264 and/or 79264 to be able to play with roll center fine adjustments. any 4.3mm ball stud longer than the stock one will work as well.......
Salvadori Racing
Old 01-08-2009, 08:23 AM   #2934
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Which shock towers do most run for Carpet Rubber. (Standard or Low)
I recently ordered the standard rear shock tower and realized, once I received it, my car has the "Low" front and rear shock towers. Could explain why my shock collars are all the way up in the front at 5mm ride height.
Christopher
ChristopherKee is offline   Reply With Quote
Old 01-08-2009, 09:27 AM   #2935
imprsme's Avatar
Trader Rating: 74 (99%+)
Christopher
Chris- I run the std. Tower for rubber (asphalt or carpet).
As for the collars being all the way up at 5mm RH, you can do one of two very simple things or as I have done in the past both. LOL
You can unscrew the bottom eyelet out about 3-4 turns or you can get some AE shock retainers. They are not as "deep" as the Corally ones which will let the spring sit lower giving you more adjustment.
Hope this helps!
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 01-08-2009, 02:17 PM   #2936
Thanks Imprsme. I think I just need to throw the standard shock tower on the front. Using the low front tower doesn't allow me to set the droop I want without starting the compress the shocks.
New question. I really like the RPM ballcups, is there a way to get them less stiff? I see them on a hand full of cars and wonder how they can use them when the are so tight. Wouldn't that extra binding mess with the suspension?
Old 01-08-2009, 02:21 PM   #2937
imprsme's Avatar
Chris- the turning out of the bottom eyelet will allow you to get droop better set also.
I know in the past when running the lower tower some guys were cutting the shock shafts I think something like 3-4mm but I found that just by unscrewing and running the AE retainer I got the settings I needed.
As for the RPM's never ran them so I can help on that.
AwesomatixUSA
eXpress Motorsports
Old 01-13-2009, 04:59 AM   #2938
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Hi All
I ordered the alloy narrow steering blocks for the Phi. Now the wheel hexes wont tighten enough so theres heaps of movement with the cvds.
Do i need to get other hexes now to fix the play ?
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Old 01-13-2009, 06:40 AM   #2939
imprsme's Avatar
Originally Posted by kid TT-01 View Post
Hi All
With the shorter knuckles you also need shorter axles and longer cvds.
You will need part numbers:
COR79184A
COR79182A
AwesomatixUSA
eXpress Motorsports
Old 01-13-2009, 06:44 AM   #2940
Hi All
What difference does the narrow steering blocks make?
kobiwan is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
