Old 12-30-2008, 02:49 PM   #2881
tom235's Avatar
i just talked to corally to find out what i had and it looks like i have a couple of first gen and a couple of sec gen and parts for both so i may have been using the wrong nut we will rebuild and then give it a go
now i know why i own a corally the customer service is A+ and why i come to this site you guys are awesome
thanks
tom235 is offline   Reply With Quote
Old 12-30-2008, 09:37 PM   #2882
Scrad's Avatar
Trader Rating: 15 (100%+)
I haven't been keeping up with the latest stuff, so sorry if this has been asked before. But do I need the lipo tray for an IP 3800 running a 13.5? Last time I ran the car about a year ago I ran 6 cell and there was talk of using the offset motor mount. Do I need that or not running the 3800 Lipo?
Thanks,
Chad
Scrad is offline   Reply With Quote
Old 12-30-2008, 10:19 PM   #2883
Still Bill's Avatar
Thanks,
Chad
Chad,
I previously ran the Orion 3800 lipo with both motor mounts on my Phi cars for asphalt and carpet. IMO the offset motor mount ($95?) was a fairly minor improvement to the standard bracket. Depending on your electronics and their placement, you will need to have 105-115 grams of weight on the outer side of the 3800 pack to balance the car side-to-side.
Later went with the SMC 5000 and the OFFSET BATTERY MOUNT ($45?). This was a major improvement and has remained my best option to date.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 12-30-2008, 10:55 PM   #2884
BQRacer's Avatar
Trader Rating: 29 (100%+)
what do the new hubs look like ?
Jasper
My Sponsors Are Visa and Mastercard
BQRacer is offline   Reply With Quote
Old 12-31-2008, 08:17 AM   #2885
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
Default ultra short wheelbase with stock pulleys
hey guys,
is there any rear belt from other manufacturers that fits the 42/21 pulleys at ultra short wheelbase configuration (I think the belt should be 195mm or 198mm length according to my amateur measuring ) ??
thanks!
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 12-31-2008, 10:53 AM   #2886
Kenny L's Avatar
Trader Rating: 16 (100%+)
Here are a few pics of the new uprights
Tom,
I have to agree with Brad the 08 diffs are by far the best upgrade you can do. I built mine over two months ago with ceramic balls . Havent had to touch them and I run around 2 to 3 times a week. Have you installed a flange bearing and remove the old thrust in the older diffs?
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 12-31-2008, 11:38 AM   #2887
BQRacer's Avatar
Kenny thanks for the pics. Do you think the new hubs are stronger then the stock ones?
Jasper
Old 12-31-2008, 11:57 AM   #2888
Kenny L's Avatar
Way stronger they have about 1mm more material around them where they used to bend
Old 12-31-2008, 12:12 PM   #2889
tom235's Avatar
kenny i rebuilt the diff with the right nut and tested last night and it still came loose so im thinking of putting some rdx diffs in for now that i have in my box so i can at least finish a race.
i didnt know you could take that that thrust bearing out and replace it with a bearing do you have a size
Old 12-31-2008, 12:44 PM   #2890
I think the nylon lok of the M4 nut has gone.......
change it for a new one and if you want extra safety apply a drop of thread lock when building, but use a light thread lock and I suggest you to have the 7mm diff wrench otherwise you will suffer to take it apart next time........
Salvadori Racing
Old 12-31-2008, 01:02 PM   #2891
Kenny L's Avatar
Tom,
Use a 1/4x3/8 flanged with cone washer facing (nut after. You dont need to shim it like posted before found works much better without any shims between cone and bearing. As always coat thread with loctite then whipe off any extra that is over threads. Build diffs at least 6 hrs before racing to get best use out of loctite if not the night before. I ran my diffs like this in vegas and they where money before I switched to the 08 diffs.
hope this helps
Old 12-31-2008, 03:43 PM   #2892
BQRacer's Avatar
I have been running the stock diffs with the bearing and red cone washer with no problem for 2 yrs. I did put ca glue on the threds of the one side of the diff, I let it sit for about 5min then built them up. Try not to over tighten them or you will strip the diff nut.
Jasper
Old 12-31-2008, 03:48 PM   #2893
BQRacer's Avatar
I just started racing again I have the CEFX chassis and the Stock chassis Does Corally make a think foam chassis? I never put the CEFX Chassis on because I have the Corally weights and there no holes on the CEFX chassis for them...
Jasper
Old 12-31-2008, 06:34 PM   #2894
Corally foam chassis. http://www.corallyusa.com/istar.asp?a=6&id=SRC79838!SRC
Photo at this link. Post 11 or just search for specialized.
http://forums.radiocontrolzone.com/s...d.php?t=246679
JoelV is offline   Reply With Quote
Old 12-31-2008, 08:42 PM   #2895
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
There is a Specialized RC (SRC79295) version of these as well. They have a touch more material then the Corally version. I'm using those and can say I broke 4 ball cups hitting the boards and they haven't bent yet. I don't think they make them anymore though.
Christopher
ChristopherKee is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
