Old 12-17-2008, 02:32 AM   #2836
wide_mouth_frog's Avatar
Just thought you guys may be interested in some parts
http://www.rctech.net/forum/r-c-item...hi-spares.html
looking at about $310 for the car and a fair few spares... never run outdoors, grab your self a bargain
Team Wave - absdesigns.co.uk - Selections RC
wide_mouth_frog is offline   Reply With Quote
Old 12-17-2008, 03:13 AM   #2837
Originally Posted by kobiwan View Post
How did you change the set-up sheet so you could actually fill in the fields without having to print it and then write the info in the blanks?
Download PrimoPDF writer, you can fill in a PDF File, and than print it to a .pdf file. Check the readme of it for more instructions, it's free so it will save you a lot of money for not having to buy Adobe Pro.
Originally Posted by aus jd 2703 View Post
also what option do i have as far as body post? i cant find the hpi ones but i really need something my fingers are crying lol
Buy the Corally bodyreamer, with the rear end you can loosen and tighten the 'bodyclips' without pulling the skin of you fingers
Rick Thomson is offline   Reply With Quote
Old 12-17-2008, 08:29 AM   #2838
Kenny L's Avatar
Trader Rating: 16 (100%+)
Originally Posted by zacabrandy View Post
What is the SRC Chassis? Is there somewhere with pics and info, or is it a Corally part?
Cheers
Aaron
http://www.corallyusa.com/istar.asp?a=6&id=SRC79838!SRC sorry there is no pic
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 12-20-2008, 08:28 AM   #2839
Default Phi
I'm going to get into rubber tire carpet racing at my local track. Most of the fast guys are running the Corally. What should I look for in a used Corally for rubber tire carpet?
Does anyone have a car for sale? I've been racing offroad for 15 years and am looking to try something differant. Any help would be appreciated
CTEKTOOL is offline   Reply With Quote
Old 12-20-2008, 09:38 AM   #2840
Send a message via AIM to HenBeav
2.4mm chassis, short steering knuckles (would be a big plus not necessary), 35 arms, maybe some 5 arm spares, lipo tray, aluminum knuckles, hard bumper and kydex, diff rear, one way front for a small tight track with 17.5, if you have a large track with 13.5 motor you might want to try a spool or the oneway depending on driving style
[URL]http://www.fastlanehobby.com[/URL]
Support your local Lowe's, Walmart and Layne Machine Works INC.
HenBeav is offline   Reply With Quote
Old 12-20-2008, 10:20 AM   #2841
I would be interested. Is it setup for carpet, foam, rubber tire? send me a pm.
Old 12-20-2008, 05:40 PM   #2842
crabboy's Avatar
Trader Rating: 58 (98%+)
Just about every picture of a Phi i see lately the shocks are in the rearward pistion, can anyone please tell me the benifits of doing this.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 12-20-2008, 08:09 PM   #2843
The rearward mounted shocks are because they are using the super short wheelbase. (The clamps mounted in the forward holes in the back) Can't really say from experience but it seems like it is only for asphalt racing. Rubber tire on carpet still tends to use the standard wheelbase and just space the arm forward.
JoelV is offline   Reply With Quote
Old 12-20-2008, 09:00 PM   #2844
Jeff Brown's Avatar
You do not have to move the shocks rearward for the shorty wheelbase. You move the shocktower on the otherside of the bulkhead. I first tested this at the 07 asphalt nats. On asphalt I would highly recommend it.
Jeff
Jeff Brown is offline   Reply With Quote
Old 12-20-2008, 09:03 PM   #2845
Jeff Brown's Avatar
Rhys
Well, Tosolini tested this when he still ran for us. The idea is to get more weight on the rear to help with on power traction I think. I have not tested this but i would be impressed to feel that difference.
Jeff
Old 12-20-2008, 09:04 PM   #2846
Jeff Brown's Avatar
Originally Posted by Kenny L View Post
Sorry, I need to post to a pic of it. It is just a 3mm chassis with a few lowered sections.
Jeff
Old 12-21-2008, 05:59 PM   #2847
can anyone tell me where I can find a ceramic 4x11 flanged bearing for the new diff, or if anyone even makes them? I have tried acer racing, boca bearings, and avid rc but no luck.
kobiwan is offline   Reply With Quote
Old 12-23-2008, 10:53 AM   #2848
Lightbulb High Traction Foam Carpet setup
Can anyone provide a setup for high traction foam carpet for 13.5/10.5?
Dhartman03 is offline   Reply With Quote
Old 12-23-2008, 11:04 AM   #2849
Sal Amato's Avatar
R/C Tech Charter Subscriber
Trader Rating: 26 (100%+)
I use this at my Track at 360 Which has insane traction even during club racing
Front
50wt oil
tamiya 3 hole piston
30 lb spring
camber link up and out
shock in on arm 2nd hole in on top(from outside)
80 arm
roll blocks up 1 mm shim front & Rear(width)
6 * Caster
1mm above ride height
.5 toe out
4.5 mm ride height
camber 1.5
Rear
30 wt oil
tamiya 3 hole
camber link up and out on tower middle hole on hub
19 lb spring
shock middle hole on bottom 2nd hole in on top(from outside)
roll blocks low
1.5 toe
1.5mm above ride height
4.5mm ride height
80 arm
camber 2
Jaco Dbl pinks all around
protoform r9f
Track usually requires glue on front tires.
360 RC SPEEDWAY 2.0
AWESOMATIX USA-SANWA--BSR--TEAM SCREAM --SWEEP RACING USA--TQ WIRE--ROCHE USA--LRP
Sal Amato is offline   Reply With Quote
Old 12-23-2008, 11:13 AM   #2850
Trader Rating: 47 (100%+)
Send a message via AIM to smitty2802
What up man... long time no talk.... talk to X about his... i'm running most of it and I like it very well... or talk to Mo... those are the only 2 i've run...
-DC-
~Jconcepts~EA Motorsports~
smitty2802 is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
