Old 12-12-2008, 10:22 PM   #2806
R.Dalnogare's Avatar
Send a message via AIM to R.Dalnogare
Originally Posted by slow View Post
Will the AE or XRay wheel hexes work on the RDX?
Xray ones fit.
R.Dalnogare is offline   Reply With Quote
Old 12-12-2008, 11:38 PM   #2807
Originally Posted by R.Dalnogare View Post
Xray ones fit.
Thanks.
slow is offline   Reply With Quote
Old 12-13-2008, 11:40 AM   #2808
Big Features's Avatar
Originally Posted by aus jd 2703 View Post
ok are the pro's using tamiya shocks or the kit phi shocks?
Personally, I'm running the Tamiya Black TRF shocks. There is nothing wrong with the Corally ones; But like Lundsford turnbuckles, I have come to trust them over the years and they go on all my cars.
Mike
Mike Kling
Team Associated • REEDY Powered
JConcepts • TXD Skin Graphix • FDJ Sauce
Big Features is offline   Reply With Quote
Old 12-13-2008, 11:50 AM   #2809
Originally Posted by tc4me View Post
can some one please give me the part numbers for the low ratio drive train ..
I got the 36t pulleys I need a smaller rear belt, and from what i read different bearing holders.I am not using the short wheel base... Big thanks Vinny
Vinny,
YOu need the 260mm rear bearing holders (COR79702A/79703A) and short rear belt (COR79136).
This will work for the super short wheel base as well. Enjoy!
Mike
Mike Kling
Old 12-13-2008, 04:37 PM   #2810
Originally Posted by Big Features View Post
Vinny,
Mike
Thanks Mike!!! but I when i went to install the rear belt it was too big... I think i needed the 77137 belt
http://www.corallyusa.com/istar.asp?a=29
tc4me is offline   Reply With Quote
Old 12-13-2008, 08:47 PM   #2811
Trader Rating: 8 (90%+)
I will post mine and Frechettes setup after this weekend if anyone is looking for a high grip 17.5 setup.
Johnny Carey is offline   Reply With Quote
Old 12-13-2008, 09:07 PM   #2812
Yes, you are correct. Sorry, should have caught that!
Mike Kling
Old 12-13-2008, 11:44 PM   #2813
does any one know where i can get a phi lipo holder? the one for large packs?
cheers my local can get it
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 12-13-2008, 11:56 PM   #2814
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
http://www.corallyusa.com/istar.asp?a=6&id=SRC79863!SRC
Dustin Layne
smoke81 is offline   Reply With Quote
Old 12-14-2008, 12:27 AM   #2815
couple questions:
1: how long do drive shaft blades last with delrin spool?
2: how to i get the bearings out their holders?
3: how do i get the out drive support rings of the delrin spool?
cheers guys
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 12-14-2008, 12:44 AM   #2816
zacabrandy's Avatar
Hey Josh, how did you end up going today?
Is the car a good thing compared to the others you've run?
Cheers
Aaron
zacabrandy is offline   Reply With Quote
Old 12-14-2008, 07:22 AM   #2817
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
These three sites have real time inventory and are probably your best source for corally parts.
www.ampdraw.com
www.superiorhobbies.com
www.stormerhobbies.com
ChristopherKee is offline   Reply With Quote
Old 12-15-2008, 02:33 AM   #2818
couple questions:
cheers guys
1. Depends on a lot of things. When driving outside the blades stay in good shape for a long time. At least 2 days, after that I change just to be sure. When driving on a short indoor carpet track I have to change blades +/- 2 times a day. (when training approx. 15 runs)
2. When you get the retainingclip off it not that hard to get the bearings out. You can use a screwdriver or something like that to push it out from the other side. Don't push to hard, you can damage the bearing. And the bearing will come out easily, so you don't even have to.
3. Get a screwdriver or something behind the ring, than you can easily pull it out.
Rick Thomson is offline   Reply With Quote
Old 12-15-2008, 02:35 AM   #2819
Originally Posted by Kenny L View Post
Has anyone tried the new rear vertical ballstud uprights? Was wondering what to expect. I should have mine soon. Will post up my thoughts.
I've tried time a couple times now, and I really like them, you've got a lot more possibilities for your roll center, because you can add shims between the ballstud and the upright.
I'm using the standard Corally PHI shocks.
Old 12-15-2008, 05:04 AM   #2820
Holmenkollen's Avatar
Tamiya blades are a direct fit and seems to last a little longer. They΄re made of a stronger plastic than the Corally ones.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
